Question about Philips Televison & Video
Model 9P5514 C101 Serial 45390840 Chassis #PTV 836 In the service mode-is there a list a factory presets? My tv has bad color and a friend of a friend came out to help. He didn't write down the settings and now I want to reset it to find out what it should look like. My father in-law said he has one that needed new bulbs. Maybe mine needs it. I get good sound, audio, and am able to make channel changes, just got a crappy picture, (red's are too bright, looks like an old 70's tube that is shot). What can I do?
How to reset factory preset picture emerson le391em4
To do this, you have to enter its service mode option. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Feb 24, 2014 | Philips 55PFL7705D 55" LCD TV
Philips 43p8341/37, ptv 914 chassis, led code blinks
Let's check and see if we can find the correct board with the problem. A good place to start is to disconnect the jumper jack 1516 [TV unplugged first]. Now plug in the TV, and power the TV on. If the tubes light up and shut down...then the small signal module is at fault. {this contains convergence ICs} Or it could possibly be the ssb [small signal board] is bad. Leave the set unplugged for a few days and plug in and power up this TV..It may work for a few seconds and go down again. These are two good places to start before you pull the boards out...and they are not easy!
Jan 23, 2010 | Televison & Video
Tuning a sony tv model KV 14 TIU SERIAL No.
Have you turned your tv to the av input mode?
Oct 15, 2009 | Televison & Video
OPERATING A MAGNAVOX TP3170 C101
i would try the magnavox website,just go to support or customer service and they should have a manual there.if not let me know how you make out.
Dec 07, 2008 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Rca tv model # p52770eb chassis # ptk169pabs.trys to turn on but wont clicks 4 times and shuts down will come on in service mode but has no sound in service mode.
There is a diagnostiv computer program that is available that can pin point any problem with that chassis just by clicking on its symptons and it only 25.99 at the following link. they email it and all you do is install the program. Its real user friendly and they provide free tech support by on lline instant messageing. I will post the link the program is listed in their TV diagnostic programs section They have the PTK 169 program. Its a good program to help diagnose and repair your set.
http://servicemanuals.vstore.ca/
Apr 14, 2008 | Televison & Video
Exiting service mode
All different brand of PTV has there way of excisting out of the service mode, panasonic don't list it, very hard to do, turn tv off then you see.
What about Bob
Mar 01, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Buttons won't work
You will probably need the service manual for both chassis to straighten that out. I am posting a link where you can purchase one manual that covers the entire series for magnavox PTV 836-PTV 835 it has 2,440 pages. It cost 19.99 and they will email it to you and provide you with free unlimited support that goes with the manual purchase. here is the link if interested in getting the service manual.
Jan 23, 2008 | Philips Magnavox 9P6034C 60" Rear...
RCA color tv,model 27F520T,Chassis M134C
On the tv panel push and hold volume down until volume is all the way down and keep holding, then push the info button on the remote.
Dec 21, 2007 | RCA TruFlat 27F520T 27" TV
Service Mode for Apex PF2720
On a standard PU1 chassis use the following:
1. Decrease the volume to 0
2. On remote press and hold the MUTE button till the color of MUTE displayed changes color. At the same time press MENU on the front of the Tv.
CH +/- to select
Vol +/- to change value
All other chassis:
Decrease the volume to 0, Press mute and video at the same time.
Adjust the TV with menu select buttons on remote.
Exit with the power button.
Hope this helps.
Bill
Nov 25, 2007 | Apex Digital PF2720 27" TV
Do you know the code for pacific tv model ptv 7004
If its not listed in the manual then it doesnt exist
Oct 28, 2007 | Sharp Aquos LC-32D40U Television
Televison & Video Logo
51 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
