Question about Eureka Altima Upright Vacuum Model 2996AVS Vacuum
Loud noise mieureka altima seems louder than befor. is it possible that it needs oiling?
  • campbell8403 Jun 24, 2008
    I have the Boss, Model 5893. When you start it up, the noise is so loud you can hardly bear it.
    Sergeant:
  • 209 Answers
Dear ahut
YIKES, please do NOT do that to your poor vacumn cleaner!!! That is probably the most dangerous question I have heard that relates to a hoover. (but heya friend, this is not your fault, its the fault of the your vacumn cleaners manufacturer/ vendor, as they dont make technology easy to understand. If they did, they would be out of business, as everyone would be servicing there own appliances/ vendor not making any money through the aftersale care plans)
Now the reason why oiling a vacumn cleaner is dangerous....Right, inside your vac, there is a very large, and very powerful AC motor that turns at high speed (which provides the basis for suction through the unit) and this motor will get HOT very quickly. Now the thing wth oil, when it warms up, it starts to displace itself (spread out/ expand over an area) and if continued to be heated, then it will CATCH FIRE.This is especially so, if either you apply the wrong oil or oil to the wrong part of a motor.
Now your vac is making some really weird noise, or it seems to be misbehaving (getting louder when it clearly shouldnt), then there is really only two things that can cause this kind of fault. Your first one is an exhaust block (air that is expelled through the vac, in order for the vac to "breathe" and not overheat. This can also be the same for a blockage anywhere else in the system, so i reckon you should start by giving it a thoroughly good clean, and use a dry cloth to clean out the exhaust areas and any other air flow within the vac. Now with the feeded hose/ pipe (the pipe that supplies the vac with the dust from your floor) can be removed and washed out in warm soapy water, then allowed to dry thoroughly before putting back into the vacumn cleaner. Once this is done, you have sucessfully carried out a 6 monthly maintenance of your vac appliance. (do this every 6 months or when there is a clear dirt buildup, whichever is sooner).
Now the second fault is a little harder to deal with, and this WILL require the consultation of an engineer (electrical/ electronic/ mechanical, as you may be looking at overhauling an AC motor.
Now normally AC motors witll have a set of brushes in them, these in affect form the basis of allowing the motor to turn, and these brushes can wear out over a period of time (not very common in newer appliances) and hence, will need to be replaced if the motor is to function properly and not end up condemned. You will need in effect, to strip down/ disassemble the motor unit to get at the brushes and then inspect them before changing them. Now this can be a very awkward job especially if certain manufactured models of motor are installed in your vac (generally speaking, Bosch are easy enough to strip down and rebuild, and parts are cheap too).
Now if your motor doesnt have brushes, then it more than likely will have a set of ball bearings in it (to make mechanical movement smoother and easier) and these bearings too can wear out. In addition to this, a vacumn cleanner is designed to pull dirt and dust into it, now any motor or motor windings (the copper core inside the motor) and bearings can quickly become damaged if the parts get fouled up or abraised by grit or large particles of dust. Now if you think that the motor unit is spinning up at over a few thousand revolutions per minute, it doesnt take much for a piece of grit to find its way into the motor area and start to ruin internal components, now any part of the motor or moving mechanical parts that start to decompose/ breakup inside the vac unit, will start to make noticable noise and vibration during use. When this occurs, the vac unit should be dismantled carefully and then the motor should be carefully taken apart on a white board (piece of white solid board) as so any foriegn objects or grit will be discovered. This will also reveal whether any internal components have been damaged. Now if there is damage, and in particular, if there is any copper wire, or copper material that has been digested by the motor, then the entire motor unit must be discarded as the windings are breaking up, and the cost of having the motor re-wound is not financially viable, and this evn has to be done by the manufacturer/ vendor of the motor, or by someone who really is quite qualified with these pieces of apparatus.
Now once the vac has been dismantled, and the motor has been dismantled on a white board, it is recommended to clean all of the components one by one, then put them all back into place (re-assemble) and then your vac should be as good as new once again.
Where possible, and of course cost permitting, any filter should be renewed, however a thorough good clean on the non-paper type should be sufficient unless the filter is worn out (which would explain why the vac is failing in the first place).
I hope that this information has been of use to you, and please feel free to contact me here anytime you like regarding this matter, and should you feel confident enough to perform all of these above processes yourself, then i can advise and instruct you on this too.
In the meantime, i bid you take care, and hope that you find this is the fixya for you, and please DO NOT oil that vacummn cleaner, unless it is just bearings or spindle.
Im here as said anytime you need more information or if you have a question/ comment.
yours sincerely
oz
Posted on Apr 14, 2008
Have a bagged Biss ll Powerforce vacuum that has started making a loud rattling noise under the base of the motor compartment. Noise is louder when using the hose. Suggestions? Thank you!
Something broke or got sucked in and is trapped in there. Put it up on a table and take the bottom apart, it's time to clean the roller anyway :)
Nov 02, 2016 | Vacuums
Vacuum works quietly and well when using the wand attachment, as soon as it is lowered into 'floor vacuuming' position it makes a very loud noise but doesn't seem to lose suction.
Hi Ismaias, it's Jack at Dyson.
The issue you're describing sounds unusual. If you think the noise coming from the cleaner head and brush bar is excessively loud, you might like to follow the steps shown in the video below to make sure nothing is jamming or obstructing the brush bar:
If you're confident there are no obstructions, but your machine is still sounding much louder than it should be, please do not continue to use your machine. At this point, it would be best to contact the Dyson Customer Helpline directly so we can provide further assistance. If a repair or a replacement part is needed, we can also confirm if this is covered under your Dyson warranty.
When you have your DC50 to hand, please give our experts a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Mar 22, 2015 | Dyson DC50 Animal Upright Vacuum Cleaner
MY Bissell vacuum cleaner clearview makes a loud noise...what could be the problem?
first thing is check the filters. then call Consumer Care at 1-800-237-7691.
Oct 16, 2014 | Bissell 1699 ProHeat Clear View Upright...
Vacuum is loud
Check for clogs starting with the air passageway at the bottom....
a piece of TV cable is great for clearing clogs there....check all
hoses...check for dirty filters. If you find no clogs remove the
brush bar and belt and start the vacuum...if the vacuum is no
longer noisy the problem is the bearings at each end of the brush
bar..... WD 40 may fix or you will have to replace. If after all this
the noise persists the the problem is in the motor. (If you use WD 40
make sure it is dry before you vacuum carpet)
Regards,
Dennis
Aug 15, 2014 | Bissell 4104 Bagless Upright Cyclonic...
I have a dyson dc17 animal. When you put the handle down, it is very loud
When you lower your DC17's handle into the vacuuming position, a second motor which powers the brushbar will switch on, which will make the machine sound a little louder than when it's standing upright.
However, if you're concerned that the noise the cleaner is making is unusually loud, I'd encourage you to get in touch with us directly - we'll be able to run through some troubleshooting checks over the phone to help resolve this.
You can reach us on 1-866-693-9766 - or if you email your contact details to askdysonUS@dyson.com, someone will be in touch as soon as possible to provide assistance.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Feb 25, 2012 | Dyson DC17 Animal Bagless Upright Cyclonic...
Why is my central vac. making such a loud noise. It sounds like jet getting ready for take off. It seems to be getting louder. I'm not using it because i'm afraid it's going to explode or...
The bearing or the motor is warn out they last 15 years in the case. In some rare case the brush ware out or the rely can catch fire, most central vacuum are not made to be oiled! Hot oil will catch on fire. Best to unplug the vacuum unit call a few shops and ask replacement motor cost, if you remove the Vac and take to them it will cost less.
Jun 25, 2011 | Vacuums
My vaccuum seems to clean, but makes a louder noise than normal
I would check and clean any of the filters also check the pipes for any blockages etc.
Regards
Alan Hood
ami-man
Dec 04, 2009 | Dyson Vacuums
Dyson DC07 is very loud, roaring from the motor
It usually gets louder as the filters clog up and eventually burns out. Try replacing all the filters and giving the bin and the vortex generator a good blow out with compressed air. Fluff can stay inside and cause the motor to strain hence the increased noise.
It must still be under warranty -used to be 3 but now 5 years -so if it doesn't improve contact Dyson and they will repair it free of charge.
Mar 17, 2009 | Dyson DC07 All Floors Bagless Upright...
Loud screaming noise when running
The vacuum is clogged. Disassemble it as much as you can and you will find the problem.
Ray
Dec 15, 2008 | Dyson DC05 Cylinder Bagless Canister...
Eureka Altima Upright Vacuum Model 2996AVS Vacuum Logo
198 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
