Question about Vidal Sassoon VSCL870 Hair Trimmer
My blowdryer has no power when plugged in. - Vidal Sassoon VSCL870 Hair Trimmer
    Genius:
  • 1,673 Answers
Most common causes are a failed power switch, motor, or fuse. If the fuse if blown, there may be a short with the heating element or the motor.
Jerry G.
Posted on Apr 19, 2008
  • Kathy Trujillo Aug 01, 2011
    It could also be the heat safety sensor, is the screen covering the fan blocked? This needs to be cleaned regularly with a small brush to maintain the cooling of motor through the airflow.
After washing my dirty coils, i guess water entered the control unit, i plugged back my unit and it beeped, but it did not show anythinhg and did not work. samsung 1hp window unit with model no AW09PKHEA
unplug it and let it set until you know for sure it is dry inside the control unit maybe even use a blowdryer to dry it be careful not to melt anything you might get lucky after it is dry it may start working again it may not
Jan 29, 2014 | Heating & Cooling
The tv turns on when i put blowdryer on the back of the tv whats be the problem and what do i have to change? they told me its power supply but which?
Try a few troubleshooting steps:
1) Plug TV directly into the wall
2) If TV is plugged into a power strip, change power strips (most cheap extension cords have 2 or 3 extra plugs in the end that will work for this step if you don't have another power strip lying around)
3) There should really be no reason the blow dryer would affect the ability to turn your TV on and off.
Kirk
Jun 05, 2012 | Televison & Video
Spilled juice into laptop
Let it dry real good before powering on...use blowdryer or sit by heater..u can pour a little rubbbing alcohol on it ...to remove juice. Let dry should be fine
Dec 20, 2011 | Computers & Internet
My brother washed it with soap and water now its not working at all.
wow, next time wipe it down with clorox disinfecting wipes they are like a $1.50, if it was recently wet, you could dry using a blowdryer, i dropped my iphone in the snow once and had to do use a blowdryer
Apr 11, 2011 | Video Game Consoles & Games
Dropped in water & windows cant access the device.. is it permently damaged?
If you haven`t already done it open the case up carefully and use a blowdryer on warm and low to thoroughly dry the insides out, before plugging it in or you could permenently damage both it and your computer.
Sep 06, 2010 | Verbatim SmartDisk Firelite Portable USB...
Seems like no power going to knob
check power at oulet blowdryer other apliance if no power reset breaker at panel to reset push breaker oppisite direction of other breakers than flip back in line with others good luck
Apr 14, 2010 | Maytag HAV2557 Top Load Washer
Fridge not cooling
In the freezer compartment on the back wall there is a panel , behind that panel is the evaporator coil and return air ducts that go up to the fridge.
these ducts freeze up, thus not allowing the cold air to circulate to the refridgerator. You can unplug the unit overnight and let it defrost on its own, or you can help it using a blowdryer for a couple of hours. just lay the blowdryer in the freezer area with the doors open and let it defrost.be sure to place an old towel on the bottom to catch the water.
Jan 16, 2010 | Zanussi ZI918 / 12K Bottom Freezer...
Hi, my freezer is plugged in, the motor is on, and the freezer setting is at 4. However, the food in the freezer is defrosting...not freezing or making new ice. What could the problem be?
sounds like a bad thermo sensor.see if the coils are frozen up. you will have to remove the access panel in the back inside the freezer. you can defrost it with a blowdryer
Aug 14, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kenmore upright freezer Model # C675-287140J Serial # 08462430AJ water is freezing in bottom tray and building up.
defrost drain may be plugged.shut freezer off,melt ice with blowdryer,and unplug drain.drain probably located behind inner back wall beneath coils.
Mar 08, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Vidal Sassoon VSCL870 Hair Trimmer Logo
Top Vidal Sassoon Health & Beauty Experts
Anglia Clipper...
jasiel murphy
Jerry Greenberg
Jerry Greenberg
Are you a Vidal Sassoon Health and Beauty Expert? Answer questions, earn points and help others
