Question about AEG B2100-4 Electric Single Oven
Fan ON Bulb On BBut no heat - AEG B2100-4 Electric Single Oven
  • 139 Answers
Hi
your problem could be two things but most likely it will be the element as 9 times out of ten it is the element.
easy to buy easy to replace
if not then you have a swtich problem but most likey the oven element..
there are most likely 4 screws to get to it and two fixing screws and two wires comming to it
hope this helps
cheers
the washdoctor
Posted on Aug 24, 2008
Model 944064576. Why doesn't it heat?
check for some grounded connections. thanks .
Mar 01, 2016 | Zanussi Ovens
No lights on oven, fan working no heat
No heat and fan working usually means the heating element has failed. Before you go down that road get the oven light checked as well in case there is a central problem. If by no oven light you mean the internal oven light is not on then that is just a bulb replacement. Make sure you get a heat resistant or original spec one though.
Jun 02, 2015 | Ovens
Looking for a manual for Whirlpool BS0801/WH oven
I have a paper copy of the manual - if you need to know anything more than the information below post a more specific question.
The function symbols on Knob F, clockwise from the top, are as follows:
  • 0 = Off
  • Lamp symbol = Lamp Only, no fan, no heating.
  • Fan + Drip Symbol = Lamp + Fan, but no Heating - this is for defrosting.
  • Fan inside a Circle symbol = Lamp + Fan + Oven Heating - this is the normal cooking position. The temperature of the oven is set on the Temperature Knob.
  • Final position = Grill. The temperature of the Grill is set on the Grill knob.
The red indicator light only comes on when the Oven is heating (not the Grill), and goes off when the oven has reached it's set temperature.
The bulb is 25W 230V Type E-14 300 Degree C.
The oven draws a maximum of 2300W so requires a 10A supply.
Nov 29, 2010 | Ovens
Hotpoint oven thermostat replaced again a few months ago now oven working but thermostat bulb not. Can this be replaced and how ? Thanks
Depending on which thermostat you are talking about , the main oven thermostat is complete with with sensing bulb, so is replaced as a complete unit.
The other stats, including over heating stat, and cooling fan stat do not have a sensing bulb, they are a bi-metal device, and can be replaced individually.
Nov 14, 2010 | Ovens
Fuse keeps tripping have checked and removed the inner bulb but cooker still trips the fuse, Fan and elements appear to be working
insulation breakdown on fan element will need replacing when heats up tracking down to earth tripping your rcd.
Jan 07, 2010 | Neff B1421 Electric Single Oven
AEG D2160 Double Oven - electrical fault
you may find that one arm of the oven selector switched has fused to its contact.
Sep 07, 2008 | Ovens
Duco4ss main oven not heating on fan setting
put test bulb on the two wires going to fan heating element,that will tell all,if bulb lights,its the fan element that needs to be replaced!good luck!!
Dec 17, 2007 | Ovens
Light
easy. unscrew bulb cover then unscrew bulb. switch off at wall first.make sure you use a heat-proof bulb to replace
Apr 22, 2007 | Baumatic B180 Electric Single Oven
AEG B2100-4 Electric Single Oven Logo
66 people viewed this question
Top AEG Ovens Experts
ashburton
Sal De
Steve
Are you an AEG Oven Expert? Answer questions, earn points and help others
