Question about Jwin JD-VD135 DVD Player
REPLACEMENT REMOTE WHERE CAN I GET A REPLACEMENT REMOTE FOR MY JWIN DVD PLAYER JD-VD135
  • 2,326 Answers
Check this site to find the remote control.
Posted on Apr 14, 2008
Does not spin
The laser pickup assembly is defective, overtime the laser becomes weaker until it can no longer track. The second common problem is the pladder motor that the dvd sits on has failed, it is far cheaper to replace the dvd player than repairing it.
Feb 22, 2011 | Jwin JD-VD135 DVD Player
Won't play DVDs from asia .. need region code unlock.. help.
try with the disc tray closed. and if that doesn't work turn player off by plug socket and turn back on and start from the setup menu part of the unlock code after turning player back on.
Aug 22, 2008 | Jwin JD-VD135 DVD Player
Code to configure the Universal Remote for my Jwin DVD player (VD141)
jWIN products do not have a series of uniformed universal remote codes, therefore, they can not be provided at this time.
Aug 03, 2008 | Jwin JD-VD140 DVD Player
No Power
Hi Rusty,
Open the cover , there must be a blown fuse, replace with another fuse of same value. If still not working take to service centre. This is a case of SMPS power supply failure.
Please vote for me if this is helpful.
Jun 08, 2008 | Jwin JD-VD135 DVD Player
No signal on tv
Manually change the TV to the relevant AV channel.
Also you don't need both the S-video and the yellow RCA connection. Use one or the other.
May 03, 2008 | Jwin JD-VD135 DVD Player
1- Open tray
2- Press setup
3- Press 1 3 8 9
4- Use Up/Down key from remote control to change the Region
5- Press setup
Apr 03, 2008 | Jwin JD-VD135 DVD Player
Nesesito un codigo para un dvd marca jwin grasias
Some unlock codes for Jwin DVD players are:
Jwin JD-VD100 / JD-VD703 / JD-VD753
1. Press SETUP
2. Press PREV CHAPTER, NEXT CHAPTER, PREV CHAPTER, NEXT CHAPTER, PREV CHAPTER
3. "VerX" is displayed (X=RC)
4. Select the RC with RIGHT and LEFT (255=Codefree)
5. Press RETURN
Jwin JD-VD120
1. Press SETUP
2. Press 1, 3, 6, 9
3. Current RC should be displayed
4. Select RC with UP, "DOWN" (0=codefree)
5. Press ENTER
Jwin JD-VD130
1. Method 1:Press SETUP
2. Press 1, 3, 6, 9
5. Press ENTER
1. Method 2:Open the disc tray
2. Press PROG
3. Press ENTER 3 x
4. A menu should appear.
5. Select RC with UP, "DOWN" (0=codefree)
6. Press STOP
7. Close the disc tray
Jwin JD-VD135 / JD-VD147
1. Open the disc tray
2. Press SETUP
3. Press 1, 3, 8, 9
4. Use Up/Down keys to change the region
5. Press SETUP
Jwin JD-VD140 / JD-VD501
2. Press 2, 8, 1, 2
3. Use the arrow keys to change the region (9 = multiregion)
4. Press SETUP
5. Close the disc tray
Jwin JD-VD145
2. Press 9, 7, 3, 5
3. Change the region
Jwin JD-VD200 / JD-VD203 / JD-VD500 / JD-VD503
1. (Open the disc tray)
2. Press SETUP
3. Press 1, 3, 6, 9
4. Press LEFT 3 x
5. Press RIGHT
6. A new menu entry appears (Version)
7. Select it and select RC (0=codefree)
Jwin JD-VD138 / JD-VD504 / JD-VD602 / JD-VD603 / JD-VD745 / JD-VD903
no known hacks
or you can try here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 18, 2008 | Televison & Video
JWIN DVD player horizontal control
I had this problem and pressed all the keys until I hit the SYSTEM button on the remote control. All was fixed.
May 20, 2007 | Jwin JD-VD135 DVD Player
Jwin JD-VD135 DVD Player Logo
198 people viewed this question
Top Jwin Televison & Video Experts
Henry  Thomas
Henry Thomas
Jaime Hernandez
romy sibug
romy sibug
Are you a Jwin Televison and Video Expert? Answer questions, earn points and help others
