Question about Sharp Office Equipment & Supplies
Sharp AR 337 won't turn on
Where is the boot ram located. I was told by another site to replace this. Can you assist me?
  • 148 Answers
If you are not getting any lights when you plug in and turn on power switch. These would be the steps I would follow, make sure on/off switch is functioning, 15 amp fuse is good or any fuse on power supply board, make sure power is coming out of power supply board. Power supply is the board with the power cord coming up to. Hope this helps. Should have a tech familiar with this machine check.
Posted on May 28, 2008
Diagram Sharp SIM14?
Type # - interrupt - C - interrupt and clear the code with simulation 14 and then hit CA to exit. If the code comes back there is a problem with your fuser (dirty thermistors cloged with toner, or one of the lamps are out)
Apr 06, 2014 | Sharp AR-M237 Copier
Sharp ar-337 driver windows 7
This machine is to old. Sharp does not support drivers for these anymore. Try using an HP driver and configure the port to the IP address of the Sharp 337. You will not have any finisher functions, but you should be able to print.
Jul 22, 2012 | Sharp Office Equipment & Supplies
Due to a power surge, my Sharp AR-M277 won't turn
There is a 20A fuse on the AC power board it is most likely blown. Follow the power cable to the board the big white ceramic fuse is the main, check continuity with meter and replace.
Sep 02, 2011 | Sharp AR-M277 Digital Copier Copier
I have a sharp AR-337 copier, On the dispaly it reads: CALL FOR SERVICE. CODE:H4-00
H4 00 Heat roller abnormally low temperature
The fusing temperature does not reach 175C degrees within 30 sec of turning on the power, or the fusing temperature keeps at 140C degrees.
C/I/0/I code 14. If it doesn't reset probably a blown thermostat on those piece of **** fusers. Also have seen the lamps some, mostly thermostat. If it has many miles on it I'd just replace the fuser.
If the previous methid wont work..., Clear --> Density select --> Clear --> Density select is for service mode.
Check code 26-30 and set to 0 - CE mark support control OFF
Try surge arrest power source.
Hope helps
Apr 22, 2011 | Sharp AR-M237 Copier
Pleas can you help, when i turn on my Sharp Ar 337 i get this all the time earra cord H3-00. can you tell me how i can solve the problem .
H3: Heat roller high temperature detection
cause:-
  • Thermister defective
  • Control PWB defective
  • Improper connection of fusing unit connector
  • AC power supply defective
check and remedy:-
Check heater lamp operation with SIM5-2.
If lamp blinks properly:
Check thermister and its harness.
Check thermister input circuit of control PWB.
If lamp lights and stays lit:
Check lamp control circuits of AC
PWB and control PWB.
Clear the trouble with SIM14.
Jan 23, 2011 | Sharp AR-M237 Copier
Looking for a Feeder unit for a Sharp AR-337 ????
The AR337 comes with a standard document feeder with a model number of AR-RF1. If you're looking to purchase one from a 3rd-party or from Sharp you'll need to reference that model number.
Aug 13, 2009 | Sharp Office Equipment & Supplies
Hello, I have a Sharp AR-337 and I am getting a message: "Call for service. Code: H5-01" is there anything i can do to fix this?
Hello sir; I like you check the exit senser first see does it move freely, if yes, then do a reset procedure; press "program", "interupt", "clear", "interupt" then enter 14 press start, turn power off and back on.
Jun 12, 2009 | Sharp AR-M237 Copier
Sharp copier printer error: PostScrip printing not licensed for t
what is you OS? check you printer drivers. are they properly installed?, what is your connection between your PC to your printer?, AR 275 can be connected thru network, parallel port, and a USB... they have different printer drivers
Feb 01, 2009 | Sharp AR-275 Copier
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
