Question about NetGear WNR854T Router (WNR854T100NAS)
Acquiring network address
Case # 6984675 - I am unable to get online due to the above message. I have tried rebooting to no avail. There is no problem other than the router. Please advise.
Will
    Novelist:
  • 144 Answers
Hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
Posted on May 06, 2008
Dell inspiron e1405 cant acquire a network address?
Call Dell customer support phone number 1-800-204-4427 to get online help for technical problems related to Dell computer, laptop, printer, scanner and tablet Dell Laptop Support Phone Number 1 800 204 4427 Tech Help
May 17, 2017 | Dell Inspiron E1405 Notebook
Only one screen will not go online, says cant find ip address
This might be due to several causes. First of all, reboot your router AND your PC. If that doesn't fix it, a few possible situations remain:
- If you're getting this message on a secured wireless connection, you might have filled in a wrong network key.
- Your network card may be malfunctioning. Try reinstalling your network card drivers and see if that helps.
Mar 12, 2011 | Computers & Internet
I AM GETTING A MESSAGE 'ACQUIRING NETWORK ADDRESS' MESSAGE, IT SAYS I AM CONNECTING BUT NO ACTUAL INTERNET
If you are using Windows 7, this can happen. If you own the network, and know the address range, disable Automatic IP on the machine, and give it a static IP address. Make sure you indicate the gateway and DNS server addresses as well.
Feb 14, 2011 | NetGear WGR614 Wireless Router
Using Nintendo Wireless Adapter - No Connection Anymore
If available networks are found, it means that the wireless adapter is working just fine. In case of Wi-Fi, the device has to acquire an IP address from the wireless router and the mutual communication is not taking place. This has something to do with the wireless router. Check for any kind of security filtering like MAC address filtering or lower down the encryption technique to 64-bit WEP. Try connecting to even an unsecured network, then check for the automatically acquired IP address. It should never be starting with 169.254.xx.xx (Invalid)
If you have other wireless computers going online in the same network, without security and filtering, then it means that your DS Lite is not acquiring an IP address. In that critical case, you may have to statically or manually assign an IP address in the range of the router.
And lastly, as you said LAN connection is active, it would be because it doesn't face any hardships while connecting!
Thanks..
Do get back if you need further clarifications.
Mar 18, 2010 | Computers & Internet
Acquiring network address/limited or no connectivity
network not set right check firewall disable it and try
Mar 29, 2009 | Toshiba QOSMIO F15-AV201 Notebook
Cannot get online
Please try the following steps to check if there is any issue with TCP/IP protocol
TCP/IP protocol is resposible for getting IP address. You can determine if you have a TCP/IP problem by doing the following.
Put in the windows XP CD and navigate to the support >Tools folder. Double click setup and do a Complete install.
Click Start >run >cmd {enter}
Type netdiag /test:winsock /v {enter}
this will provide information if there is any problem in TCP/IP protocol due to winsock issue. If problem found then try the following steps
To Reset the Winsock Registry Entries
Click Start >Run >regedit {enter}
Navigate to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Winsock and delete it; just below that, see HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Winsock2 and delete it
Exit Regedit and reboot.
To Reinstall TCP/IP
To do this you need a copy of nettcpip.inf. There is one on the Windows XP CD and there may be one on your hard drive at C:\WINDOWS\inf\nettcpip.inf. Note: To see the inf folder, open My Computer and go to the menu item Tools > Folder Options... > View > and choose Show hidden files and folders.
Right click "My Network Places" select Properties.
Right click the connection(s) and select Properties.
Click Install >Protocol >add >have disk.
Browse to the location of nettcpip.inf .
Select nettcpip.inf then click Open then OK then Internet Protocol (TCP/IP) then OK then Close
Reboot
Please reply back if further information required
Dec 30, 2008 | Belkin (F5D7010) 802.11a, 802.11g/b...
"acquiring network address" problem
The password might have been changed that's why you keep getting "acquiring network address", the password is incorrect. What you can do is just reset the router. There's a reset button at the back of it, press and hold it down for 10 seconds then release, unplug the power now for 10 seconds then plug it back in. That will disable the wireless password, just re-enable it.
Oct 26, 2008 | NetGear WGR614 Wireless Router
Cannot connet my laptop to he wireless router
If compuetr always saying acquiring network address you can try firt restarting the computer, but if still wont get a valid ip address, you need to adjust the wireless settings of the router and after that try to reconnect to the wireless network....
Oct 25, 2008 | NetGear WGT624 Wireless Router
Acquiring Address Problem
you will need to make sure that DHCP is enabled within the routers settings as this will tell the router to assign ip addresses automatically, then go to network connections, right click on your network card>properties>TCP/IP line>properties and tick 'obtain an ip address automatically', click ok, close window and restart pc.
Sep 24, 2008 | HP PAVILION A6230N DESKTOP PC
Cannot acquire network address from access point
then it seems thatb the wireless security key for your network is incorrect, make sure if you are entering the key correctly..
or else..
check if you are able to go online with the router wired first, if yes, then the w/ls settings has to be checked..open your w/ls network connection, remove your preferred wireless network and then try to reconnect again and check.. if you are not able to gon online wired with the router, disconnect power cables from modem- router , wait for 10 sec, and reconnect it , wait till all the lights come up and then reconnect, check if you are able to go online if not your router has to be reconfigured,,
plz check and revert back in case of any issues
Dec 02, 2007 | D-Link AirPlus Xtreme G DI-624 Wireless...
NetGear WNR854T Router (WNR854T100NAS) Logo
89 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
