Question about Canon imageCLASS D661 Digital Printer
What is causing black streak
When I place document on glass and copy it, a streak of black ink about and inch and a half wide ends up on the right side of each document. It sounds as if there is a little piece of paper caught inside because there is a crinkling sound as the page is printed. I do not know how to open the machine to check. Sound seems to be coming from inside on the end that the new printed document comes out of. (left end, facing machine) Do you you what this is?
  • 81 Answers
You should try changing the toner cartridges first. There may be something stuck in it causing the noise and streaking
Posted on Jan 03, 2009
Black cq when using document feeder
clean the slit glass its the small maybe two inch wide glass to the left of the main glass clean it good use windex or alcohol that will get rid of you problem have a great day
Apr 18, 2014 | Kyocera KM-1505 Copier
Black line is present when copying document; not
This sounds as if you have some ink/contamination on the small scaning glass that sits to either the left or right of the main glass on the copier.(Depending on the model/make)As your original is scanned over this thin piece of glass the scanning device will see any spots and this will result in a black line down the page.Please clean the glass with a soft rag.
Oct 12, 2009 | Office Equipment & Supplies
Photocopy has black band at end of the page
well ithink tou are using the ADF to copy something...you will have to clean the scanner glass(not the scan bed but when you lift the ADF cover you will see a scanner glass about inch wide)...it should resove your concern...
Mar 27, 2009 | HP Photosmart C7280 Printer
ADF copy with black streaks?
lift up your adf and locate the thin piece of glass, about an 1' wide, and clean real good with rag and windex. probably white out or some foreign material on that glass.
hth,
razors
Feb 27, 2009 | Brother MultiFunction Center MFC-440CN...
Faxing is clean, streaks occur when copying
Open the document feeder cover. The scanner glass is dirty or you have a bad scanner block.
Dec 05, 2008 | Brother IntelliFAX 4100 Laser Fax
HP Officejet 6300 All-in-one machine makes black streaks
The problem is that that there a small piece of glass that the doc feeder use's to scan the orginal. You will have to clean the small glass it's about a half of a inch piece and is normally under the doc feeder unit. It will either be to the right side of the main copy board glass or it is under the doc feed unit where the paper goes down through the feeder. It is mostly some white out on the glass, just clean with a dam cloth with water or windex..... Good Luck
Nov 15, 2008 | HP 190 Copier
HP 7410 streaks when using auto document feeder to make copies
the document feeder of that unit have its own scanner glass. try opening the document feeder and clean the scanner glass with a lint free cloth that is moist with water and also clean the rollers of the document feeder
Aug 13, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Dark strip down center of page when coping from tray
There is a small strip of glass on the left side directly under the edge of the scanner, About a half an inch wide. It has something on it.
May be very hard to see, use a strong glass cleaner or some alcohol and a regular piece of paper to clean it with.
May 08, 2008 | Xerox Phaser 3200MFP/N Laser Printer
Good, so u are having probs in ADF. Open the cover, lift the rollers and u can see the scanning glass. Take a lint free cloth and clean it. it will be ok.
Feb 03, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Scanning document leaves streak down right hand side
Even a single grain of dust or a single strand of hair on the scanning glass will cause the scan head to perceive ink/image where there is none. Deffinetly try cleaning the glass using a good window cleaner, and a cloth that is completely clean, or even a peice of newspaper. If the black line remains, I would suggest taking it into a service center to have the scan head itself cleaned.
Dec 05, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Canon imageCLASS D661 Digital Printer Logo
358 people viewed this question
old marine
old marine
