Question about E-Machines T6528 PC Desktop
T6528 has no video. Using a working monitor, tried differnet video cards but still no video.
  • E-Machines Master
  • 5,660 Answers
1) So you tested the monitor on a working computer? Reason I ask, is that you will be testing the monitor cable also.
If it is a monitor with a detachable monitor cable, suggest you test the cable also.
2) Each graphics (Video) adapter card has it's own specific driver.
The driver should be installed Before, the graphics card is installed.
Otherwise Windows will 'break it's neck', to find a compatible driver, from it's thousands of generic drivers.
Won't do. You will get a driver conflict.
Windows: 'Which driver do I use? These or THESE?"
Kinda' hard to do, since you can't see graphics on the monitor.
I would like to suggest you diagnose the Power Supply to start with. (After checking the monitor cable)
It may seem that the Power Supply is okay, but it could have a weak Voltage power rail.
Enough power to light LED lights, and spin fan's, but not enough power to turn the Processor on.
1) ALL the LED's use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts.
3) A typical Processor can use 51 to 125 Watts.
(Lower for older Processors)
The eMachines T6528 comes with an AMD Athlon 64 3500+, processor, that fits in a Socket 939 processor socket,
1) eMachines Support > T6528 > Specifications,
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T%20Series&model=T6528
2) Information on the AMD Athlon 64 3500+,
http://en.wikipedia.org/wiki/List_of_AMD_Athlon_64_microprocessors#Athlon_64
Can use up to 67 Watts, or up to 89 Watts. Depends on what Core it is.
(Clawhammer Core, Newcastle Core, Winchester Core, Venice Core, Manchester Core, or San Diego Core)
(Also uses an MSI K8NGM-L motherboard. Below for specifications only,
http://www.newegg.com/product/product.aspx?Item=N82E16813130041 )
A) Not to down eMachines, (I have an old T1090 in my shop that works great), but they are budget computers, and use budget parts.
One being the generic Power Supply that is used.
B) The computer could be dirty inside, as well as inside the Power Supply.
The cooling components for the SMPS, (Switched-Mode Power Supply,) are it's Fan, and Heatsink's used inside.
Once a layer of 'Gunk' covers these cooling components, the cooling capacity drops tremendously.
Heat = Wasted Energy
The more heat, the more the Power Supply strains to keep up with the call for power.
Eventually hardware components inside the Power Supply fail, and the Power Supply is toast.
You can test the Power Supply voltages.
You can use a multimeter if available, or an economical unit can be purchased for around $5 to $12, that will suffice for testing.
You can also use a power supply tester.
One example:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5250576&CatId=5471
Voltages produced by the SMPS used in a T6528 are,
A) 3.3 Volts (DC)
B) 5 Volts (DC)
C) 12 Volts (DC)
Testing should be done on the 12 Volt power rail.
11 to 13 Volts indicates a good Power Supply.
Less than 11 Volts means it's time to replace.
Orange wires are 3.3 Volts
Red wires are 5 Volts
Yellow wires are 12 Volts.
All the color coded Voltage wires, lead back to one individual power rail, for each Voltage produced by the Power Supply.
You can test any Yellow wire to test the 12 Volt power rail.
With a multimeter, the Positive (Red) probe lead connects to the power wire to be tested.
The Negative (Black) lead connects to ANY Ground wire.
ALL Black wires are Ground wires.
They all go back to one central Ground source inside the Power Supply.
[Power Supply unplugged from power before attaching probe leads. After connecting, the power supply is plugged back into power, and the Power On button is pushed ]
(Two C cell flashlight batteries produce 3 Volts DC)
Posted on Jun 20, 2010
  • joecoolvette
    joecoolvette Jun 20, 2010
    Edit:
    Also should have stated that you can use a KNOWN to be Good, Compatible power supply, for a test unit.
    Compatible:
    The power supply type is ATX.
    Case size is approximately 6 inches Long, 6 inches Wide, and 3-1/2 inches Tall.
    You need the correct power cables, and the correct amount.
    1) It's been stated that the eMachines T6528 comes with a 20-pin ATX main power cable,
    http://www.playtool.com/pages/psuconnect...
    The K8NGM2-L motherboard has a 24-pin ATX main power cable connector, on the motherboard, and IMHO should use a 24-pin ATX main power cable,
    Those extra four power wires, deliver needed power when adding a graphics card.
    Just came back to post this, in case you had a working Power Supply in an unused computer, that you could use for a test unit.
SOURCE:
I have a dell dimension 8100. I am wondering if the motherboard is bad or the video card. All monitors that I hook the computer up to are very dark and the blue hue seems to be very pronounced.
Hello
If this system has a video card its probably bad.
You may want to try a differnet monitor cable before spending alot of money.
If this motherboard has onboard video,take out the vid card and try the onboard video.
Aug 30, 2010 | Dell Dimension 8100 Motherboard (5E692)
MS-7207 K8NGM2-H MOTHERBOARD Model:K8NGM2 -H E machines T6528 no video will display tried PCI -express video card and still no display. Monitor tested on other pc and works fine
If you are using a PCI-e video card, you will need to install a driver. If you have onboard video on your motherboard and that isn't working, I would say that your motherboard is fried and you need a new one or a new machine.
Jul 18, 2010 | E-Machines Computers & Internet
Im trying to install a new video card on an emachine and i keep getting a no signal input on the monitor. thats what i started with.
Is the new video card compatible with your motherboard?If it is , can you try connecting your monitor VGA Cable from your video card properly?
And also if you are using a PCI Video Card you should try to install it to another slot if theres an instance that a PCI Slot doesnt work.
Jan 07, 2010 | E-Machines T6528 PC Desktop
No video
Sorry to have to tell you this ,But if the onboard is shot then you need to replace the motherboard.
No way is more COST effective for the average person,For the above average person get someone to replace the onboardvideo you can order one from the manuf,if not check the chipset.
Jun 08, 2009 | E-Machines T6528 PC Desktop
I use a 37" lcd tv as a monitor for my t6528 e-machine pc. I turned it on one day and the screen was awash with a bunch of colors, then it crashed with "blue screen of death". Now when I turn it on the...
an easy way to check is if you happen to have a regular vga monitor, hook it up to the computer if you get same results then you'll need to get a new video card.
Mark
Apr 27, 2009 | E-Machines T6528 PC Desktop
EMachine stopped displaying video (card not working, just mobo)
Hi there
I would say it's the graphics card that's failed. You might get the same beeps for faulty card as removed card....
Take it to a shop where they can test a compatible card, before they sell you one or install one for you.
Jan 09, 2009 | E-Machines eMachines Desktop PC
E machines t6528 video card
  Hi, slot video card can handle a multitude of tasks. If you want, you can now buy one that'll handle the graphics processing for your computer. This is a fine and wise solution if you have modest graphical needs. After all, if a spot of word processing, watching the odd DVD and a little e-mailing is all you have in mind, then on-board graphics (VGA Port of motherboard) is fine.
  Therefore, on-board graphics is fine if your intended use is modest, not so if you're likely to even entertain the idea of playing a relatively modern 3D game with the settings on a decent level, or undertake any task that involves a degree of graphical work.
  • It depends on your motherboard. If what type of video card it supports. If you have an older motherboard then it's either AGP or PCI. New Motherboards supports PCI-Express graphics card. There's also an indication what it supports. There's a label on it if it's AGP or PCI.
Jan 07, 2009 | E-Machines T6528 PC Desktop
5.1 vs. 4.1 speakers.
hmmmmm emachines has it w/ 5.1
http://www.emachines.com/products/products.html?prod=T6528
and like you said, will he realy know the diffrence :)
Apr 21, 2008 | E-Machines T6528 PC Desktop
EMachine Help
If you took the pc in to a repair shop and they diagnosed that as the problem. You will have to install the new vieo adapter in the computer. Then plug in the monitor to see something on the screen. You can go into the bios to disable the other. Now if you are going by hear say and an actual tech did not check your system it does not necessarily have to be the video adapter at fault. You will need to have it checked out to validate that. Now if you did install the card you will have to plug the monitor in the new adapter. If the problem is still there you have another issue with the pc. Please comment on what the case may be. I would be able to better help you.
Hope this helps you
Oct 20, 2007 | E-Machines T6528 PC Desktop
E-Machines T6528 PC Desktop Logo
412 people viewed this question
Top E-Machines Computers & Internet Experts
Thomas F. Schneider
Steve Allison
Steve Allison
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
