Question about Technics SH-GE50 Home Equalizer
SH-GE50EG-K - no power - powersuply/transformer - I need spare parts or service-manual
The unit dosen't work because the puwersuply,specially the transformer is faulty. I'm looking for servicemanual or spareparts.
Regards gerd093
Can you advise me where to purchase a dust bag for ozito compound mitre saw.
Part 108
http://cdn3.blocksassets.com/assets/ozito/ozito-product-manuals/b5ZLP0doHsVMmPH/SCMS-107-Spare-Parts.pdf
[PDF]SPARE PARTS cdn3.blocksassets.com/assets/ozito/ozito-product.../SCMS-107-Spare-Parts.pdf
  1. Cached
  2. Similar
SPARE PARTS. SCMS-107. Tool: 8" Slide Compound Mitre Saw. Model No. SCMS-017. Item. No. Description. Part No. How To Order. 13. 20. 35. 52. 58. 63. 66. 67. 74. 91. 92. 96. 108. 109. 116. 126. 132. Mitre Lock Handle. Kerf Board. Bevel Lock Handle Assy. Fence. Material Clamp. Blade Bolt L/H M8x16. Locating ...
[PDF]SPARE PARTS
cdn3.blocksassets.com/assets/ozito/ozito-product.../OZSCMS1600WA-Spare-Parts.pdf
  1. Cached
  2. Similar
SPARE PARTS. OZSCMS1600WA. Tool: 10" Slide Compound Mitre Saw. Model No. OZSCMS1600WA. Item. No. Description. Part No. How To Order. 3. 10. 21. 25. 34. 75. 76. 78. 79. 87. 99. 146. 122. 125. 128 ... The following is a list of spare parts carried by Ozito. Please contact Customer Service for any parts not listed. 4.
[PDF]SPARE PARTS
cdn2.blocksassets.com/assets/ozito/ozito-product-manuals/.../CMS-210-Spare-Parts.pd...
  1. Cached
  2. Similar
SPARE PARTS. CMS-210. Tool: Compound Mitre Saw. Model No. CMS-210. Item. No. Description. Part No. How To Order. 15. 32. 41. 48. 49. 74. 75. 86. 89. 96. 99. 106. 108. 125. Kerf Board. Handwheel Bevel Adj. ... Special Orders Desk at any Bunnings Warehouse. If you have any further questions, please contact Ozito.
Ozito - Customer Service and Support
https://ozito.com.au/service-support/
  1. Cached
  2. Similar
If you need spare parts, manuals or any customer service for your tools we're here to help. Check out all the info you need or contact us.
ozito compound mitre saw spare parts Google Search
Dec 27, 2017 | Saws
I have this lg 42lc7d that keeps burning the transformer. I have put n two supply board n each time I plug in the transformer smoke n burn lead wire that goes to transformer.
Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Oct 24, 2015 | LG Televison & Video
Ideas? TV Works BUT has extremely Hi Pitched Screeching from power board.
Apr 16, 2015 | Sceptre X460bv-f120 46-inch Class...
I have a 33 lg lcd tv. Lg 32lc2d. Power off fine. I turn it on the transformer buzzing loudy. Then it shuts off no pic or sound. I turn it back on still buzzing transformer but works fine. I've replaced 4...
Jan 29, 2015 | LG Televison & Video
1980 Yamaha XS 400 Special wiring diagram
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
1980 Yamaha XS 400 Special wiring diagram Google Search
Yamaha Motorcycle Wiring Diagrams
Yamaha XS 400 SH Service Manual ENG XS360 2D XS400 2E 2F SG Supplement ENG...
Yamaha XS360 Service Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-xs-owners-manuals
Jan 09, 2013 | 1980 Yamaha XS 400 Special
Spares for magna spot welder
Ebay is about it.
If you have the hand held unit for auto body, they do not service the transformer as a discrete part from what I have seen. Using anyone elses transformer or adapting something ftom a microwave is done at your own risk and should only be attempted if you understand characteristics of transformer design.
Dec 17, 2011 | Welding Tools
I have a tview indash dvd player and the screen wont come out. i called the company and they said i need to send it to them but all i really need is a service manual how do i get that cause they claim they...
It is difficult to get hold of a service manual in the first place and then to find the spares if there is a failure that you have identified. Considering both factors and specially if the player is under warranty, then it is better to send the unit over for claims. Also it will be better if you can just open and check for the power to the display section and the power supply.
Other wise get an estimate to decide as spending on manuals and spares must be considered with teh possibility that sometimes you may need a repairing JIG to connect when the unit is taken apart.
Jul 12, 2011 | T-View Dvd7905bd Car Video Player
I bought SH-GE90 DSP And I pluged into 240V source while the indicator was on 110v and now its not working will replaceing the transformer will help or it just simply gone.
It is not possible for us to be able to determine the extent of the damage. It is possible that only the fuse has been damaged. It is also possible that the rectifiers have been dmaged. The bottom line here is that there needs to be some examination of the unit and some testing of the internal components. The best case will use parts in the $5 range. Worst case you are looking at $50 or more in parts. If the cost is not too high, take this to a servicer and ask for a detailed repair estimate.
Dan
Dec 02, 2010 | Technics SH-GE90 Home Equalizer
Failed power transformer
With out make and model, I can not supply parts information. Please update this with that info. Also, depending upon the age of the unit, parts may not be available. Are you sure that the problem is the transformer? This part is rare to fail.
Dan
Jan 21, 2009 | Cambridge Audio Audio Players & Recorders
129 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
