Question about Intel Desktop Board D815EEA2 (BOX815EEAA2) Motherboard
Bios set up any how misplaced by me
Service team manerger,
bios setup wrongly misplaced by me
as a result my printer failed to work properly
shall I over-come this problem?
    Scholar:
  • 176 Answers
Some motherboard bios have an option DEFAULT BIOS CONFIGURATION look for it in the bios setup of your motherboard. But before you can exit in the bios setup make sure to save the new configuration some bios command to save is F5 or F10
Posted on Apr 17, 2008
How do I get best Brother Printer Customer Support Number ?
Are you seeking any kind of Brother Printer Customer Support services? Reach for Brother Printer Customer Support Number '1-800-213-8289 (toll-free) for efficient and reliable support services. The customer support offer services installation, setting up and configuration for branded printer. Inkjet, LaserJet and Wireless Printer are also services for proper working of device. Get timely repair of printer device for smooth and easy going print output results. From driver download to install and proper setting up every minor to major issues and also configuring the settings or any other issues are resolved with Brother Printer customer support services.
Brother Printer Customer Support for Following Issues:
    ·Customer Support for Troubleshooting
    ·Printer Compatibility Issues
    ·Customer Support for Printer Setup
    ·Printer Configuration Support
    ·Customer Support for Printer Issues
    ·Driver Installation Issues
    ·Wireless Connectivity Problem
    ·Network problem with system Make strong contact either by calling on our toll-free number, having live chat with experienced technicians, or dropping an email to our customer email address id and get assisted for any and all type of Printer issues. The capable technicians assist you calmly and steadily with guaranteed services for easy running of printer device. Feel free to call on our toll-free number any hour of day and night for proper assistance with definite services. We are available 24*7 with right kind of Brother printer tech services.
Sep 18, 2017 | Brother Office Equipment & Supplies
How could i setup a new windows when boot manager not work properly
You can boot and setup windows using either of the following ways:
a) If you have a boot able CD/DVD of Windows, then go to your BIOS setup and set CD/DVD as your First Boot Device and then save setting and exit. Place the CD/DVD of windows in your CD/DVD Rom and setup shall start.
b) If you don't have a boot able CD and have a backup on your hard disk or any place else, then you can create a Boot able USB easily. Follow the link below for getting a free utility and how to create a disk like it.
http://www.megaleecher.net/Make_Bootable_USB
Oct 24, 2012 | Samsung Np-qx411-w02ub Core I5-2450m...
Parallel port will not power up print server.
May be your parallel port is disabled in BIOS setup.
Enter BIOS setup (DEL key on some common boards, F1, F2, F8 or even F10 on some branded machines) to enter BIOS setup.
Use arrow keys, Enter key and Escape key to navigate through settings.
If Parallel port is disabled, press 'Page Down' button or '+' button (only one might work) to get an address for the parallel port.
Save BIOS and exit. Restart the machine.
Tell us the result.
Aug 30, 2011 | Tally Genicom 3810S Printer
I can't boot up. it display error 2100: Hard disk drive initialzation error.
This issue is often caused by either an incorrect setting in BIOS or a bad boot device, such as a bad hard disk drive.
Try this:
Verify that your hard disk drive is setup and detected properly in BIOS. You're computer should list a hard disk drive installed either under the main page or the drives page in BIOS. If BIOS indicates the drive is not installed or not detected skip to Hard Disk drive is bad or not connected properly.
Verify the boot options are properly set in BIOS, almost all BIOS setups should contain options specifying how your computer boots. For example, most computers should have their boot options setup similar to the below example.
- Floppy drive
- CD drive
- Hard drive
Rest your BIOS to default values. Many BIOS will enable users to reset the values to the default settings. If you've tried the above options without success try resetting the BIOS.
Boot from either your emergency repair disk, your bootable Windows CD, or your bootable restore CD.
Once boot attempt to repair Windows. If you're able to repair Windows remove the disks and reboot the computer.
If the above fails:
Verify the connections are properly connected to the computer if the hard drive was recently installed or the computer was moved.
If all connections are setup properly and all the above recommendations have been attempted, it is likely that the hard disk drive is bad and it will need to be replaced.
Let us know how it works out.
Jan 11, 2011 | Lenovo T410 Notebook
Windows failed to load because the firmware (BIOS) is not ACPI compatible
please change the cbos battrey and set the bios optimize default
F10>yes.
hope it will help tou
dont forgate to vote me
Dec 01, 2010 | EliteGroup P4VXASD2 Motherboard
Film + error lights flash. I have replaced the ink
This indicates that either the black print cartridge is faulty, misplaced or missing. Try inserting a different black cartridge. Also firmly press the large green plunger fully down once, and then release it. The plunger should return to its original position. Then reset the printer and try printing again. If the problem persists try using a new black cartridge and primeit before use with the power on.
Sep 24, 2009 | HP DesignJet 330 InkJet Printer
I have a new L2210NW monitor. The serial number is 5520B82002975. I have used it for a week without any problems. Only today I turned it on and picture is faded I am using a DVI cable plugged into...
You have done all the thing I would have done and it appears your monitor is faulty. New electronic appliances can fail in the first month, and if it doesn't then they will give good service for a long period.
I suggext you get it repaired or replaced under warranty.
Aug 04, 2009 | Office Equipment & Supplies
Problem with my BIOS CMOS Setting
Its due to your default CMOS setup does not match with your CPU configuration especially with CPU speed.
  1. To fixed the above problem goto BIOS and navigate settings of CPU, speed etc. Set the speed with the proper value as per manual. And save the settings.
  2. Infuture when you will load default, at that time also set the CPU settings.
  • The CMOS battery might not be connected properly or may be its not producing enough power as per needed by board. So have a look with another battery. Also clean the connection point of the CMOS battery.
Good Luck
Iqbal
Apr 22, 2008 | Biostar P4M80-M4 Motherboard
Rca 32v432t
You need the factory remote only for this model of set!
Contact the service rep for your set and order a new remote.
As for the service mode, most RCA sets require an external service interface.
In many models of sets, the results and commands are in HEX. You will need the service manuals, hardware interface, and instrumentation to do proper setups and adjustments.
As for accuracy of adjustments, from factory these sets were very accurate. If there are changes, this is due to failing parts, and not from adjustments going out. The setups are all uPC controled and are exact. The set should be serviced to make it work properly, and not adjusted to offset faults.
Jerry G.
Dec 23, 2007 | RCA 32V420T 32" TV
Intel Desktop Board D815EEA2 (BOX815EEAA2) Motherboard Logo
206 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
