Question about GE 21.7 cu. ft. Side-by-Side Refrigerator with Dispenser TFX22ARBWW
Ice maker My GE Refrigerator is not producing ice. The temperature is set to the coldest level, and everything in the freezer is frozen solid. I'am able to obtain water from the water dispenser.
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 531 Answers
Water valve or icemaker
Posted on Apr 02, 2009
My GE Monogram side by side built in refrigerator will not freeze ice or keep food frozen. It stays just under the freezing temperature. The refrigerator portion seems to work. Can anyone help?
its possible that its either short of gas or the little fan motor in frezzer/fridge is not working,but if its only making ice now and then its sounds like a gas shortage
Aug 28, 2012 | GE Monogram ZISS420NRSS 42" Built-In...
How to troubleshoot ice maker for my GE refrigerator
The first thing to check is the temperature in the freezer. Even though everything is frozen the ice maker won't cycle unless its below 10 degrees F as a safety precaution. If the temperature is good, and since you can't manually advanve the ice maker, or not suppose to anyway what I would do is turn the ice maker off a few minutes and then turn it back on, but when you do pay close attention to the fill tube where the water comes in at, because if the valve is good, a little water should flow up real quickly. If this happens, change the icemaker.
May 10, 2012 | GE GSL25JFPBS Side by Side Refrigerator
Ice maker does not work
Hi ndfi,
If your ice maker wont work, it is often due to a defrost problem. If something is going on inside the freezer and the temperature is too warm, No Ice production. The ice maker needs to be at a certain point or temperature to make ice. Try putting a thermostat inside the freezer to see what the temperature is. It should be at least Zero. If not, turn the temperature of your refrigerator to the next coldest setting inside the freezer. Let it go for a day and see if the machine starts to make ice. Here are additional steps that you may apply on this issue.
1. The Fill tube for the Ice Maker may be froze. There is a tube that runs up the back wall of your fridge and enters the cabinet through a hole right behind the ice maker. If you look at the ice machine inside your freezer you will notice a tube entering it from the rear wall. This is the tube. Inspect the tube carefully with a flashlight to see if it's blocked with ice. If so, there's your problem. Use a hairdryer to thaw it out and your machine will be making ice.
2. If the tube feeding the ice maker is solid round. Like a paper towel roll. Cut a **** along the top of it to prevent it from freezing up again.
3. Check your Water valve for any loose or bad connections. On some refrigerator style ice makers you can easily check the valve using the hole in the front of the module.
Hope it helps.
Thank you for using FixYa.
Feb 08, 2011 | GE Profile 26.6 cu. ft. Side-by-Side...
Vegges frozen...ice in ice maker melting GE model PSW 26 LSRD refrigerator
Checkthe freezer temperature. The proper freezer temperature should be around 5degrees. The warmer it is in the freezer, the more difficult it is to make ice.
Jan 27, 2011 | GE Profile PSW26P Stainless Steel Side by...
Refrigerator is 7 years old. no ice is being made and refrigerator is now setting on the "coldest" setting, and barely keeping refrigerator cool and freezer items barely frozen. could dirty coils be...
Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...
Aug 13, 2009 | Roper RT18HDXKQ Top Freezer Refrigerator
We just moved into a home with a 3 year old GE side by side refrigerator (model# GSS 25LGMB BB, serial# VA 412740). It works but it's not as cold in the fridge section as it should be and we have it on the...
Ok, this is a temperature control board malfunction. this board control the temp throughout the box and , if it is unstable and unable to regulate the temp, it will produce erratic fluctuations within the box itself. simply replacing this board will fix this issue.
CLICK TO PURCHASE THE TEMP BOARD
Please rate and god bless:)
May 11, 2009 | Refrigerators
Side by side freezer
check the fan in the frezer is it running and is there any frost on the back panel of the frezer
Nov 29, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Freezer not freezing
Check to see if the fan motor in the freezer is running. Most likely it is not circulating the cold air Also make sure the defrost drain line is clear and has drained out. A frozen sheet of ice will restrict airflow also
barneyluc.
Sep 28, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice maker doesn't make enough ice to supply two senior citizens. This is the 2nd refrigerator we have had installed this month. What can we do to increase the amount of ice it puts out. The ice bin has...
Found in the FAQ section on Samsung.com:
Samsung refrigerator freezers produce about 120 cubes per day, which is in line with most manufacturer specifications.
Empty the ice tray and let the unit run for 24 hours.
If fewer than 50 cubes are produced during the 24-hour test, then your refrigerator requires service. Please contact Samsung Service at 1-800-SAMSUNG to schedule a service appointment.
If your freezer is producing 50 to 90 cubes per day, try the following:
  • Set the freezer temperature display to a lower setting. Freezer temperature must be 5 degrees Fahrenheit or less for the ice maker to work properly.
  • Make sure that the water valve on the refrigerator water supply line is completely open. You can find the water valve where the refrigerator water supply line taps into your house water line.
  • If you have a water filter in your refrigerator, change the filter cartridge. For instructions, see your Users Manual.
If you want your freezer to produce more than 120 ice cubes in a day, try the following:
  • An ice maker typically makes 1 tray of ice every 90 minutes. To shorten the amount of time the freezer takes to produce a tray of ice, set the freezer temperature display to a lower setting.
  • If your refrigerator has a Power Freeze function, press the Power Freeze button to speed up the ice making process. In the Power Freeze mode, both the compressor and the freezer fan run for 10 hours continuously. The ice making interval is reduced from 90 minutes to 55 minutes. If the ice bucket fills in less than 10 hours, Power Freeze stops automatically.
NOTE: If you have just installed your refrigerator, it will take 6 to 12 hours for the refrigerator to produce ice.
You should throw away the first three batches of ice cubes that the ice maker produces (approximately 30 cubes) to ensure the ice maker is making ice from clean water.
Feb 06, 2008 | Samsung RM255LASH Side by Side...
Refrigerators Logo
98 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
