Maxtor ata 80g drive jumper settings to slave?
    Genius:
  • 1,027 Answers
PDF File
Work around, Set both drives to cable select, then the ide channel flat ribbon cable will determine which is master and which is slave.
But to answer your question, no jumpers= slave
Posted on Apr 14, 2008
I've a Fujitsu MHV2080At like external disk and from some days PC don't recognize Hard disk and this is "dead" , the led's are ok when i connect USB but the head of hard disk don0t...
  1. Serial ATA:  If you have a 3.0 Gbit/sec SATA drive that is not being detected by your 1.5Gb/sec SATA controller, or it causes your system to lock up when connected to a 1.5 Gbit/sec SATA controller, you may need to jumper your 3.0 Gbit/sec SATA drive to the slower speed of 1.5 Gbit/sec for the system to recognize it properly. For further information on changing the jumper setting to slow down your SATA drive's transfer rate, please see Document ID: 193775
    -48-8s.jpg -- (Click to expand) Jumper settings for Seagate SATA drives
    -48-9s.jpg -- (Click to expand) Jumper settings for Maxtor-brand SATA drives
    ATA:  It is recommended that all Seagate ATA hard disks supporting the Cable Select jumper option be configured as Cable Select. If your computer system was built prior to October 1998 and does not support UDMA 66 or greater you will be required to use the Master/Slave jumper settings.
    -48-10s.jpg -- (Click to expand) Jumper settings for Seagate ATA drives
    -48-11s.jpg -- (Click to expand) Jumper settings for Maxtor-brand ATA drives
    When using Cable Select jumper settings on your ATA drive, all devices connected to the UDMA cable must also use the Cable Select setting. The cable decides master/slave device detection when the cable select jumper settings are used. Please consult Document ID: 196299 for further instructions.
  2. Faulty Hard Drive
    If you have completed the above checks and procedures and the drive is still not properly detected, please attempt to use Seatools for DOS (see the tutorial here) to test the drive.  If SeaTools does not detect the drive after the steps followed above, or an error code that signifies drive failure displays, please proceed to the our Warranty Services page to begin a warranty replacement order.
Sep 19, 2011 | Fujitsu MHV2080AT (MHV2080AT50PK) 80 GB...
How to set jumper to slave mode on maxtor 6y080m0(picture pls)
These are the jumper settings for a Maxtor Diamond Max ATA hard drive.
Sep 23, 2010 | Maxtor DiamondMax Plus 9 80 GB Hard Drive
Maxtor hard drive jumper setting for model 6v200e0
here is a poster of Maxtors jumper settings for each kind of drive.
Nov 12, 2009 | Computers & Internet
I want to install as second drive - i need the jumper settings
There should be a diagram on the front of your drive at the top left that shows you the jumper configs.  For most Maxtor drives, if you want a drive to be slave, you remove all jumpers.
Cheers!
May 01, 2009 | Maxtor Ultra hard drive kit 80GB 7,200 RPM...
Maxtor PLUS 8 7200RPM IDE ATA 133 40GB hard drive. Do i need jumpers and software for the install of this harddrive and if so here can i get. Thanks j
are you mounting it as the only drive or with another one... if you are mounting it as a slave usually you don't need a jumper... the jumper setting will hopefully be on the sticker.
xp and up will autodect the drive..
Jan 23, 2009 | Maxtor Hard Drive
How can I detect maxtor 3200 ide as slave
Somewhere on the harddisk, you should be able to see a label indicating jumper settings. Check that the jumbers are set to slave sattings.
Dec 17, 2008 | Maxtor DiamondMax D540X 100 GB ATA-133...
Slave pin settings
hi frined
remove your hard disk jumper & u r hard will be slave
Apr 12, 2008 | Maxtor 20.4GB 7200rpm ATA-100 HDD p/n...
Maxtor 40gb hard drive as master
Hi, Below is an image of a Maxtor 3.5 HD settings as shown on the actual HD. If you are connecting 2 of them in a single IDE flat cable/strip, one must be master and the other must be slave. Jumper settings on the left is for master, the second is for slave. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Sep 15, 2007 | HP/Maxtor 40GB 3.5 IDE/ATA Hard Drive...
Computers & Internet Logo
93 people viewed this question
David Payne
David Payne
