DVD Video Player, Model DVD-RP56 This weekend we were watching a movie. It started to skip. I thought it was a dirty disk, took it out, cleaned it with a dry cloth and put it back. Now nothing will play. When I insert a disk it starts to revolve the machine says reading, two zeros appear and the it stops. My wife noted a message "H02" and the manual says to call for an explanation. We tried turning the machine off and on and we tried pulling the plug -- no luck. What is the problem?? Jeff
  • cashma Apr 14, 2008
    Error message is HO2
    What does code H02 mean? Definition?
    Genius:
  • 3,422 Answers
The first thing i would suggest you to do is a hard reset by unpluging the the player for 30min and then try again.
If this does not solve your problem then please see if the player tries to read the disc.
Load a disc and listen.Does the player make squealing noises or is it totally quiet? Squealing noises may indicate that the player is trying to synchronize with the disc but can't due to an obstruction on the lens or in the laser path inside the pickup or a defect in the pickup. This can also be caused by an intermittent signal problem due to a faulty ribbon cable.
Totally silent means that the photo sensor is not getting any usable input from the laser at all, meaning that the pickup is "blind" for lack of a better word.
This can be caused by an obstruction of the beam by foreign matter on the lens or inside the pickup all the way to a marginal or failed laser diode and/or photosensor array. This can also be caused by a bad ribbon cable with one or more severed traces.
You could try to clean the optics. This is the most common malfunction as far as i know in all disc players. It would involve taking the cover off and finding a way to expose the lense, and then cleaning it with a very gentle brush. some players have a cover for the lense that swings to the side during playing, this greatly reduces the chance of dust accumulating, but its still worth the try.
If you actually see dust on the lense, then its just that simple. clean, close, play.
It may also be worth your while to check on the small shafting that guides the carriage of the laser pickup. Dirt, grome, dust and solidified lubricant can cause stoppage of the carriage and the laser eye then fails to read the next track.
If the problem does not get solved then you have to get it repaired.
Goodluck..
Please don't forget to rate the solution.
Posted on Apr 14, 2008
  • 1 more comment
  • Priya darshan Apr 14, 2008
    Actaully H02 is optical pickup and H07 is spindle.
    I have read that h02 is spindle. I have also heard h02 is optical pick up.
    Click HERE for more info.
Denon s-102 skipping parts on DVD (only)
dirty lens, look for a DVD lens cleaning kit
Aug 11, 2009 | Audio Players & Recorders
Have a sony 5 dvd changer. not sure of model. disk fell off carosel. cannot get it out. any thoughts?
Unplug unit and take shell cover off. While you have it apart it would be a good idea to clean the laser lens with alcohol and wipe with clean cloth to ensure that your movies play without stalling or skipping.
Jul 11, 2009 | Sony DVP-NS300 DVD Player
Helios H4000 frozen
try using a dvd cleaning disc in the unit
Mar 05, 2009 | Neodigits Helios H4000 DVD Player
HO2 Error???
The problem with your unit is the "Spindle Motor", this motor is the one that spins the disc so the laser can read it. I sugest you to take your player to a shop, or back for service if the unit still under manufacturer warranty.
Apr 14, 2008 | Panasonic DVD-RP56 DVD Player
H02
When I insert a disk it starts to revolve the machine says reading, two zeros appear and the it stops. My wife noted a message H02 and the manual says to call for an explanation.
Apr 06, 2008 | Panasonic DVD-RP56 DVD Player
DVD skipping? is something wrong or what..hellpp
It may not be your tv, itmay be your dvd player, open the tray and blow into the tray compartment, or wipe off the lens. When the lens gets dirty, its like trying to look out through a dirty window, and when the lens goes over a part of the dvd with the area that is dirty, it cant read it so it skips over it.
Hapy new year, hope this helps
Dec 31, 2007 | RCA TruFlat 27F520T 27" TV
Samsung DVD-4600 DVD/VCR Player
My Smasung DVD/VCR Combo stopped reading DVDs because of a dirty read head. It started by only playing disks sometimes, and progressed to never playing disks. I assumed it was a dirty laser lens so I bought a lens cleaner set. Unfortunately my player wouldn't play the cleaner disk.
So I took it apart and cleaned the laser lens manually with some isopropyl alcohol (the clenser that came with my cleaning disk), and a lens cloth (that came with my glasses). Just open the case (starting with the screws in the back) and remove the snap in cross panel that obscures the lens of the DVD portion. Put a drop of cleanser on the lens and gently wipe it with the cloth.
Oh and by the way, I take no responsibility if you break your own player while following my instructions. My own DVD player was far out of warranty at the time I cracked it open.
Aug 16, 2007 | Samsung DVD-V4600 DVD Player/VCR
Dvd player doesn't work
you moust troaien CD&DVD clearns for the best working
May 05, 2007 | Toshiba MD13N1 14 in. TV/DVD Combo
All DVD`s installed in player skip .Also DVD`s that showed title donot now.
first thing i would do i clean the lens with 90% isoprople alcohol and a q-tip, if that doesn't work watch the laser eye again and the movement is the laser look like it tries to catch up???
i would put a dc volt meter on the motor and the motor should stay at lower voltage if it climbs then there is something with the rails or worm gear. let me know what you find out.
Aug 23, 2006 | Yamaha DVR-S120 DVD Player
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
