Question about Gateway FPD2185W 21 in. LCD Television
FPD2185W Hi Firehawk, I took mine apart after it stopped turning on and found the 8 caps in between the two heatsinks. Are these the medium 470uF25v that you removed and replaced? Did you change the slightly lager caps on the board as well? thanks
    Problem Solver:
  • 6 Answers
You need to use 105c temp caps
Posted on May 21, 2008
Frigidaire FEQ1442CESO wont stop beeping
Mine did the same thing. It started right after the warranty ran out. I dealt with it for a long time until 1 day it wouldn't stop running. I saw a couple internet posts about defective circuit boards in this model so I got brave and took mine apart. Once I got the board out and examined it I found 7 or 8 cracked solder joints, including the main power supply to the board. I reheated them with a soldering iron and added a little bit more solder to a couple of them and now my dryer works like the day it was new.
Jun 14, 2014 | Frigidaire FEQ1442ES Electric Dryer
Roller not turning when vaccuming
just had the same exact issue with mine - took everything apart - found that the swivel roller brush wasnt turning. it was not any belt issues or motor issues. took out brush roller - held in my hand by holding just the hand cap still - and tried turning the roller with my other hand. roller would not turn at all but is supposed to with no effort. on some models the end caps pop off but most are one piece and are just discarded and a new roller bought - seems to be $10-$20 for one for most dirt devils and under $10 shipping in north america. you can try something down the side of the roller and end cap like a razor - i did cut lose some crud and it works - but roller still stops on 2 of 4 settings on the rug because of this. i've already ordered a new one.
Mar 11, 2013 | Dirt Devil Vacuums
FPD2185W Gateway Monitor
its still ur power chck for swollen fillter capacitors
Oct 17, 2008 | Gateway FPD2185W 21 in. LCD Television
Same problem as others have had but with a twist
SOUNDS LIKE IT WAS (FIXED) PUT BACK IN THE BOX AND TRIED TO SHUCK IT OFF ON SOMEONE YOUR BEST BET WOULD BE SENDING IT TO GATEWAY MAYBE JUST MAYBE THEY WOULD HELP YOU EXPLAIN WHAT HAPPENED
Oct 09, 2008 | Gateway FPD2185W 21 in. LCD Television
My Rainbow stopped running
I took my unit apart to clean it. I was careful to put it back the same way. Now it won't start.
Jul 07, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Gateway FPD2185W take apart
you have to be very gentle and pry it apart.... VERY gently. Any questions you can e-mail me at Andrew@CreativeAudio.biz
Jul 01, 2008 | Gateway FPD2185W 21 in. LCD Television
Ecofan only turns slowly
These fans can be rebuilt! Like many others, our fan died after being placed in the center of the stove top. I took the two halves of the fan body apart, and scraped the heat sink compound off either side of the power plate. I then applied CPU heat sink compound that can be found at any computer or electronics store liberally to either side, and put it back together. The fan spins like new, spread the word!
Nov 28, 2007 | Cfm 802 Ecofan Table
FPD2185W turn on problem
I had a similar problem... mine would work fine all day. I put it to sleep at night and when I go to wake it back up, it would come on for a second and then back off.
Here's my fix:
BE CAREFUL when popping the case open and unplugging the connectors!
Everything is flimsy and can break easy. TAKE YOUR TIME, and be very gentle.
Ikeep electronic screwdrivers, tweezers and the like for projects likethis. The connectors were a b*tch to get out. They are darn-near microscopic, so take your time and skip that next can of beer... you're going to need patience and concentration to get the little bastards out.
OnceI got inside, I found the capacitors were NOT bulged out the top,leaking, or leaning; however I noticed some of the bottoms on the canswere sticking out further than others.
Hard to say if they are bad, but it won't hurt to replace them since I'm already knee-deep into it.
There are 14 capacitors total that I replaced. You might as well do all of them.
Ok, now time to find the replacement parts:
Thenew capacitors were a bit of work to find. My local Radio Shack andtheir online store didn't have some of them, and the ones they didwasn't rated the same.
The OEM capacitors are rated 105* (1000hrs). There were a Samxon brand. According to some web sites, thesecaps are a general purpose and a lower-quality cap.
The Radio Shack ones are 85*. They would probably work, but who knows for how long.
Ifigure the OEM caps are already made by the lowest bidder, so I betternot take the chance and make it worse! Besides, Rat Shack didn't evenhave all of them.
Here is a list of the caps I found in mymonitor (your monitor may be different and you should check yoursBEFORE you order them)
* ALL OF THESE ARE RADIAL ELECTROLYTIC (aluminum can type), 105 deg. *
QTY. (1) 10 uf, 50V
QTY. (1) 47 uf, 25V
QTY. (2) 68 uf, 450V
QTY. (2) 220 uf, 25V
QTY. (8) 470 uf, 25V
I found all of the parts at Allied Electronics: https://www.alliedelec.com/
Total parts was less than $8.
Allied part #'s:
10uf: 613-0743
47uf: 613-0783
68uf: 613-0312
220uf: 613-0766
470uf: 613-0190
According to their specs, they are good for 2000 hours.
Digikey also had them: http://www.digikey.com
Theirprices were comparable, but I couldn't get all of the same manufacturer(not that it really matters, but I'm picky like that :) )
I took my time and I was up and running in about an hour. Most of the time was spent removing the old caps. They can be a real bear to get out if they have the sticky goo under them.
So far the monitor is running perfectly. Only time will tell if I get the power-up problem again.
Hope this helps.
H.
Nov 15, 2007 | Gateway FPD2185W 21 in. LCD Television
Open Questions:
See all Gateway FPD2185W 21 in. LCD Television Questions
Gateway FPD2185W 21 in. LCD Television Logo
147 people viewed this question
Top Gateway Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
