SOURCE: Fatal alert [Memory Mgr,C,Line:3751, Free handle
Thoroughly flush (delete) documents to go using the tool below and then reinstall.
Worked for me two times over the past two years when my E2 has gotten sick.
http://support.dataviz.com/support.srch?docid=13445&pid=2000
SOURCE: Note pad
Maybe some other program has modified the Notepad program. Back up all your files and do a hard reset. Still not work, call palm...
SOURCE: Palm Tungsten E2 error
Everytime I got that error, press soft reset on back and it should reboot normal
SOURCE: how do I do a
Hold power button while pressing reset button release release the power button when you see YES/NO confirmation to erase all data. Once you choose Yes, It will set everything to factory default. Personal data will be erased.
SOURCE: How to insert a sim card into my Palm Zire 72
No sim card in the Zire 72. On-board memory on the motherboard only to store records not directed to or on expansion memory card.
Zire 72 battery changeout not designed to be user serviceable. Undertake at your peril (unless you are very steady handed, patient, and very very careful). The 72 is probably the most difficult of the Palms to change batteries. Go to: http://forum.brighthand.com
Navigate to the Zire 72 section and read the posts. There are even detailed photos and uTube movies that deal with changing the battery. I have used their forum for years. Lots of help there.
