Question about Canon DR-9080C Path-Through Scanner
Canon Dr-9080C scanner
I have a Canon Dr-9080C scanner which is brand new and it is giving an error code.
The scanner worked great for one day and the following morning it gives error code P00.
The P00 is a paper jam code according to the user manual. Obviously, there is no paper jam and scanner continues to list this code the counter display.
I’m at a loss, is there a procedure to completely reset the scanner?
Any ideas will be appreciated.
Thanks for your help in advance.
To check the page count install the driver and setup the scanner as a "scanner device" on your computer. Once you have done that , go to the "control panel" than "scanners and printers". Right-click on the device that says "Cannon DR-9080C" and select "properties". The device information will appear, than select the "counter" tab on the information box; the scan count will be listed.
Posted on Jan 31, 2009
The POO error can also be caused by the little sensors in the outside edges collecting dust or if you wiped out the scanner with anything damp they will react to foging as if they are being covered.
Posted on Dec 07, 2011
  • 490 Answers
Canon 9080C is a good scanner and will not fail on 2nd day. Just check if there is any small bit of paper stuck in any of the sensors. Remove the rubber rollers, clean and refit them.
S. Mohan, Chennai
Posted on Jun 23, 2008
  • 4 Answers
I have the same model Canon DR-9080C scanner which I recently acquired and I'm trying to figure out how used it is. I see many referrign to a counter. I see the big LCD on top front, but how do you know how many total pages have been scanned through it? I read somewhere there is a mechanical scanner. Is this true?
Posted on Jul 07, 2008
Set up disk for canon DR 9080 path through scanner
Hi Joseph, you should be able to find the driver for your OS on the Canon website here. imageFORMULA DR 9080C Color Production Scanner
Apr 10, 2014 | Canon DR-9080C Path-Through Scanner
DR-9080c Isn't being detected via USB
Uninstall the device driver, restart the Comp and reinstall the software. If the scanner is not detected, try inserting any working device on the same USB port. if it detected, thee could be problem in the Scanner, if the new device is not detected, then it may be port problem.
S. Mohan, India
Feb 07, 2013 | Canon DR-9080C Path-Through Scanner
We recently acquired a Canon DR 9080C Scanner and purchases and installed a SCSI card in an older HP Pavillion. The scanner works fine using the USB port, but when using the SCSI port I get an error when...
CapturePerfect ver 3 is on chargeable basis! You can download ver 2.0 from http://software.canon-europe.com/software/0022439.asp?model= Though this is listed under Canon DR 5020, it works fine with DR 9080C. DR 9080C has very intelligent features and ver 2 works fine. I do not know if there are addl features with ver 3.0. I have used for scanning over 500,000 docs.
S. Mohan
Aug 05, 2009 | Canon DR-9080C Path-Through Scanner
Canon DR-9080c scanner not lifting error no page found in feeder
There is a paper sensor just under the rolers in the lifting tray. Clean the area thoroughly with a damp cloth. Keep some sheets and try ]count only'. If it works then the sensor is okay, then you can try your scanning. If it is not sensing paper, check the sensor or connections to the sensor.
S. Mohan, India
Jul 09, 2009 | Canon DR-9080C Path-Through Scanner
Imprinter won't work on DR-7580/9080C
May 31, 2008 | Canon DR-9080C Path-Through Scanner
IDoc scanner Canon DR-9080C has a P00 error when not paper jam found?
There are sensors in the paper path. Just blow air to ensure that there is no shreds of paper is blocking the sensor.
S. Mohan, Chennai
Mar 13, 2008 | Canon DR-9080C Path-Through Scanner
Scanner command invalid in current state
I have not used CapturePerfect 3.0. Hope the scanner is just fine. Try count only mode to check if it is okay.
Uninstall Captureperfect. Run chkdsk/scandisk to check if OS is ok. Reinstall Captureperfect again and it should work.
S. Mohan
Jan 31, 2008 | Canon DR-9080C Path-Through Scanner
E15 error codes on a canon dr7580c scanner
Oct 12, 2007 | Canon DR-9080C Path-Through Scanner
Power supply gone bad
Canon 9080C is a very good scanner, so dont dump it.
Yes all power supply units have a fuse. Check if it is okay. You can source scanner power supply board from the market, if you can handle it or it is easy to call Canon support and get it fixed.
Oct 11, 2006 | Canon DR-9080C Path-Through Scanner
Canon DR-9080C Path-Through Scanner Logo
2,025 people viewed this question
old marine
old marine
Corne Viljoen
