Question about ASUS A7V8X- X VIA KT400 ATX AMD AUDIO LAN (A7V8XXLANUAYZ) Motherboard
Audio output problem
I have got a pc of amd and motherboard asus all the installisations are complete except realtek high definition audio driver what to do now
    President:
  • 2,351 Answers
Hi naveenraj, listed below is the link for your board through Asus.
http://support.asus.com/download/download.aspx?modelname=A7V8X-X&SLanguage=en-us
Suggest you add this link to your favorites.
I'm betting that the driver file software on your Asus CD has the same date as listed above within Audio. Click the pulse + sign next to Audio & it will open.
We need to check two places within your PC.
First click the start button & slide up to & open control panel. Than double left click on the Sound and Audio Devices icon.
Once opened click on the Audio tab. Next under, Sound playback is Default device. Write down the name of the device
(If one is listed). Than click the Voice tab, here again under Default device write down the name of the device. (If listed).
Both devices should be named the same. Close that window by clicking Cancel. Next while still in control panel open the System icon. Click the hardware tab, than click the device manager button. Scroll down to & click once on the plus + sign next to, Sound, video and game controllers. (It will open if it's not already opened).
Do you see a yellow ! point? If that's a yes than for reasons not known the sound driver software did not install correctly.
Rather trying to reinstall by using the sound software's setup.exe file we will do a more direct method of installation.
Right click once on the yellow ! point & left click once on update driver. Windows hardware wizard will open. Click No, not at this time. Than click the next button. Another window will open. Left click once in the circle next to, Install from a list or specific location (Advanced). Than click the next button. Again, another window will open. We want to remove the green check mark next to, Search removable media (floppy, CD-ROM...). Click the green check mark once & it will go away. (Put your Asus CD into your cdrom drive. Wait for the splash screen to open).
Once it has opened close the window.
Back in the Hardware Update Wizard window click the Browse button. Another window will open. (Brows For Folder). Click the + sign next to My Computer. Scroll down to the Asus CD & click the plus + sign to open the CD.
Look for the driver folder & click the + sign to open. Find the Audio folder & click it once so the folder is highlighted. Click the OK button. The sound driver software should start to install. Once finished, close all opened windows & restart your PC. Turn on your speaker's.
After windows has finished loading completely open windows media player & play a song, turn up the speaker volume. Do you hear the music? If you still have no sound. Follow the above instructions to check the device manager for that yellow ! point.
If it is still there than your integrated sound chip is bad. That can not be repaired. Asus warrants your board for three years. Your board is out of warranty. You can buy a PCI sound card & install it into an opened (White), PCI slot. Any one of these card cards will do. Click the link. http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=2769&name=5.1-Sound-Cards
Have more questions, feel free to ask.
Good Luck!
Mike
Posted on Apr 18, 2008
There is no sound coming out of my motherboard audio plugs. I cannot find a Realtek audio driver for Windows 7.
You can either go on the Asus support site and download them there with your motherboard model number.
Or
On the Realtek site directly here is the link : Realtek high definition driver download
Good luck
Dec 15, 2010 | ASUS P5QL PRO Motherboard
What is the compatible sound driver for this motherboard my operating system is XP
Normal 0
You can download the drivers from ASUS WEB site. Select your model motherboard/computer/laptop, and make sure you select the Windows XP or Vista version of the drivers that matches your Windows operating system. Please click on this link to their WEB support site : -
http://support.asus.com/download/download.aspx?SLanguage=en-us
Oct 05, 2010 | ASUS P5QL PRO Motherboard
I m having asus k8v-vm bt no space for sound card
The Asus K8V-VM motherboard has an intergrated audio chip on the motherboard, Realtek ALC660. You need to enable it in the bios. If you do not have you're manual down load it from Asus; http://www.asus.com/Search.aspx?SearchKey=K8V-VM You'll also need Adobe reader installed to view the manual. Enter the bios menu. Open Advanced. See the top of page
2-21 in the manual. Set, High definition Audio to [Auto] Save and exit the bios. Also check out page 1-19. You can install the driver software from the Asus CD or download it from the Asus link provided above.
Realtek Audio Driver V5.10.0.5211 for Windows 2000/XP/XP 64bit. (WHQL)
Cheers'
Mike
Jan 10, 2010 | ASUS K8V-VM (K8V-VM GREEN) Motherboard
Realtek High Definition Audio failed to be installed
hi, try to re install again, if its not installed check in the real tech audio drivers web site
Feb 02, 2009 | ASUS P5P800-MX Motherboard
Need audio
The SR1820NX is powered by a 2.2GHz Athlon 64 3400+ CPU. The Asus A8N-LA Nagami motherboard features the integrated GeForce video and eight-channel audio.
The Asus A8N-LA Onboard audio or audio card :
  • Built-in Azalia 8 channel audio
  • Realtek ALC883 8-channel High Definition Audio CODEC
So you want the Realtek High Definition Audio Driver R2.11, which has support for ALC883. You can find it here:
http://rapidshare.com/files/173933659/WDM_R211.zip
and the Vista one is here:
http://rapidshare.com/files/173930788/Vista_R211.zip
Hope this helps
Chris (ziraffa)
Dec 23, 2008 | HP Compaq Presario SR1820NX (ER919AA) PC...
Computers & Internet Logo
142 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
