Question about Toshiba 36A50 36" TV
Red picture hi, the problem started with the picture blacking out for a few seconds at a time once in while say every half hour give or take...that went on for a few days... then that problem stopped but the picture then went red...like the transmission was coming from mars! this happens if the source is satalite tv or dvd. when there is no signal the tube is all red with horizontal lines running across it about 4" apart from the top to bottom. this has been a great set (5 yrs old). would like to save it. Please help! thanks, ben
    Problem Solver:
  • 14 Answers
Assuming this is a TV with a picture tube and not plasma or LCD; I'm afraid that your picture tube is dying on you one electron gun at a time. From what you said your green electron gun is almost totally dead and the two remaining blue & green guns aren't far behind. Eventually you'll have no picture at all and I would estimate that to be about 6 more months but whatever the time eventually it will go totally black. These blackout periods will get longer and longer. The only way to fix your problem is a new picture tube but my will probably find it less expensive to just get a brand new TV set.
Posted on Apr 14, 2008
Hi there. I have a Sony Trinitron KD-28DX200U. There's no picture and the red light flashes 15 times.
TV has gone to trinitron heaven. Give it a decent burial and time to move on.
Aug 12, 2015 | Sony Televison & Video
Decora 6124H Timer
Leviton 6124 timer instructions:
Timer comes with plastic protector over display >> remove protector to see display.
Large button is manual override.
After timer is wired, push override to make sure Load turns ON and OFF.
Timer has 3 small buttons located below manual override used for programming
Display is divided into 24-hours with am times on left and pm on right.
24 Hour day is divided into 1/2 Hour segments
Each 1/2 hour must be set for ON or OFF
Start by pushing left-side event-cursor-advance-button and it scrolls down each 1/2 Hour.
Once you arrive at 1/2 hour > make decision if you want timer ON or OFF for that half hour.
Press event-set-reset-button in center to set ON-OFF for that 1/2 hour.
Press center event-set-reset-button and solid black rectangle fills in for that half hour.
Solid black rectangle means timer ON for that 1/2 Hour.
Once solid square is selected, press event-cursor-advance-button and cursor advances again and starts filling in black rectangles for each 1/2 Hour period.
Keep filling in black rectangles for all times you want timer ON.
When you reach 1/2 Hour period you want timer OFF, then press center event-set-reset-button so that no black rectangle is visible for that 1/2 hour.
No black rectangle means timer is OFF for that half hour.
To set current time, use right-side time-advance-button.
Press and hold time-advance and time cursor advances down through the am and then pm hours.
Stop cursor at current time, and timer is ready.
Jan 04, 2010 | Leviton 6124H 24 Hour LCD Programmable...
I have a philips 50'' television, model #50pf9631d/37 with a flashing red light on power light, sometimes i unplugged the unit about 5 or 6 times for about an hour, then try to turn it on quickly with the...
Two problems: first, tv turns off for about 10 seconds after being on awhile, then turns back on. 2nd, picture will sometimes go black horizontally displaying only half of the upper screen. This will go on for about an hour off and on.
Dec 31, 2009 | Philips 50PF9631D 50 in. HD-Ready Plasma...
Tv won't come one and blinks red 7 times then stops.
When the bottom half of the picture goes out this usually indicates a failure of the lower Y driver module. When this module fails it will often take out the Y sustain module and when that happens the set goes into over current shut down. Both boards will have to be replaced. All of this is assuming you have a Plasma set and not a LCD flat panel.
Jun 02, 2009 | Philips Televison & Video
Standby Lamp
Count the flashes of the standby light and the gap between them as this will give you the exact error code for the fault. Then check handbook or sony forums for the solutions. Like I have said in other posts sony and 3rd party dont really go together but it does not mean that because I have had those experiences it applies to all products and components. Hope this helps.
Aug 18, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Picture jumps after a few hours turned on
I have a 3 yr old 55 inch mitsubishi TV and when I turn it on the green light starts flashing and I must reset the TV about four times before it finally comes on has anyone had this problem if so what solution did you have?
Jul 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Sony Trinitron Top Half picture blacked out
You could have a bad capacitor 35v 100uf ,1uf 50v ,VERTICAL ICs have 7-11pins depends on which one you need LA7830-or 7833,7835,7836,7837 7838 make sure you get correct part.
ThankYou for using FixYa. Have a Nice Day
Feb 07, 2008 | Samsung HCM4216W 42" Rear Projection...
Several problems
you may want to check all of your coax conections and stray ground shield piece littl tiny silver mtal wire will cause that reaction or you may have a ad reciever if so if ou have the directv inurance they will replace it for no cost to you at all.
good luck
please rate
Jan 11, 2008 | Philips DSR708 DirecTV DTV Receiver /...
Toshiba 36A50 36" TV Logo
94 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
