Question about Car Audio & Video
How do i remove pioneer premium stereo from dash
  • 20 Answers
There is 2 little thin metal peices that you have to have to slide into the sides of the reciever. It will unlock the sides so that you can pull it out.
Posted on Apr 14, 2008
The battery was disconnected in my car and now my pioneer detatchable face stereo won't come on... Is there a code for this stereo?
Most aftermarket stereos do not have a reset code that I know of. Check your fuses under the dash.Iif they are found to be good you may have to remove the radio and see if it has fuses on the back of it. Sometimes it is a glass inline fuse between the stereo and the factory wire harness. Sometimes they are blade fuses in the rear body of the cd player itself.
Mar 23, 2012 | Pioneer Car Audio & Video
I have an pioneer deh-7000bt stereo and it keeps going to mute? how do I fix it?
You need to remove the stereo from the dash and make sure the Tel mute wires are not shorting on any metal. tape up any wires that are not connected.
Hope this helps
Oct 17, 2010 | Pioneer Car Audio & Video
How do I remove a Pioneer car stereo using the extraction keys?
you slide them down both one each side and the deck should just pull out
rate pls
Aug 17, 2010 | Pioneer AVIC-D2 In-dash Car Audio Stereo...
I have a 1998 Pioneer head unit to put in my car. the #is 1256237179. Is There anyway to get a diagram to see how to hook it up?
Well you can please follow the below steps -
1. Disconnect your car battery. It is vitally important to your safety that you never work on any type of electronic in your car with the battery still connected, as this puts you at risk for electrocution.
2. Remove the old stereo by taking off all the dashboard panels surrounding your stereo, sliding out your old stereo head unit, and unplugging all the wires that are connected to the head unit. Discard the old stereo.
3. Take your Pioneer car stereo head unit and plug each of the positive wires from your car speakers to the positive terminals on the head unit. Take all of the negative speaker wires and connect them to the negative terminals on the head unit.
4. Attach the stereo's black ground wire to a metal bolt or screw located near where the stereo is mounted in the dash.
5. Connect all of the ignition power wires to your Pioneer stereo.
6. Take the harness connector and plug it into your car stereo. Now plug the antenna into the back of your head unit.
7. Slide the stereo back into the dash, screw it in place, and replace the dashboard pieces you removed earlier.
8. Reconnect your car battery, turn the car on and test out your new Pioneer car stereo. Please post comments for more help or information..........
Good Luck!!
Thanks
Jan 16, 2010 | Sony CDX-F7710 Car Audio Stereo CD MP3...
Is the pioneer ts-a6815 a good replacement for stock 2009 premium sound system?
Depends on the manufacturer of the premium sound system.I replaced my premium stereo(JBL) with pioneer mids and highs and yea they were a heck of a lot louder and the sound was like brighter and better all around but i put in a new deck and had a amp running them so i dont know if that helps you.
Jan 10, 2010 | Pioneer TS-A6815 Coaxial Car Speaker
Trying to hook up a pioneer car stereo model # KEH M8550
Depends on the type of car you have. Do you have a harness or are you going to splice all the wires? Does your car have a premium sound system? Are you going to run an amplifier now or later on in the future??
May 03, 2009 | Pioneer Car Audio & Video
Remove Pioneer radio from dash
slide them down the two enads of radio you will have to pop off the narrow trim bezel around radio to do this
Aug 19, 2008 | Pioneer DEH-P2000 CD Player
Try ebay:
Item number: 370036329272 rtcurve.gif
If the facia comes off, remove it and you should see two vertical slots. Insert the keys and pull out the unit. Disconnect the plugs for speakers power and ariel.
Mar 26, 2008 | Pioneer DEH-P5800MP CD Player
Pioneer Super Tuner 3 Removal
If it's been installed with the original DIN mount, there are 2 small flat clips that slide in a small slot on each side of the radio. The 2 pieces of metal are pushed in to release the clips holding the radio in the bracket. Then the radio pulls out
Those clips come with the Pioneer stereo but should be available from a place that sells/installs car audio
Oct 16, 2007 | Pioneer DEH-P690UB CD Player
How do I get it out of the dash
the radios come with 2 removal tools. you remove the trim plate then slade the tools in one per side... what kind of car? i may be able to tell you a different way of removing it..
Sep 05, 2007 | Pioneer DEH-P44 CD Player
Car Audio & Video Logo
73 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
