Question about Friedrich Heating & Cooling
Fan belt is broken. Need part for model THC09K34STC
This company is suppling me with part for mine.
hope this helps for model THC09K34STC
The Gabbert Company
6868 Ardmore
Houston, Texas 77054
Hours ... 8:00 am to 5:00 pm Monday through Friday
Email:sales@gabbertcompany.com
Phone 713-747-4110
800-458-4110
Fax 713-747-0192
Good Luck
Posted on Aug 22, 2008
How do i replace the fan on a riccar rsl3 vacuum cleaner?
RICCAR SIMPLICITY SUPRALITE RSL MOTOR and FAN
Its looks the same as a Kirby its done with a nut on the axle on the armature of the motor.
Feb 20, 2016 | Riccar Vacuums
Broken fan belt on my car
I need to know engine litre size and whether or not it is hybrid vehicle?
You should be able to get belt from autostore. If you want remove/install info, I need more info?
Jan 08, 2016 | 2011 Ford Escape
Had two warning lights come on the das the battery light and handbrake light plus temperature went up high
Maybe your serpentine belt is slipping or gone. Not sure if the water pump runs off the same belt as the alternator on this model.
Mar 15, 2015 | Mazda 626 Cars & Trucks
Powersteering and powerbrakes not working
  • You need to specify the particulars of the vehicle. Make, model, year.
  • My first guess is you have a broken fan belt driving the power steering.
  • Power brakes are generally vacuum driven But on certain Dodge chrysler trucks they are driven off of the power steering pump.
  • If it isn't a broken fan belt, the power steering pump is probably either low on fluid or bad.
Nov 29, 2014 | Cars & Trucks
No suction
I presume the motor is running, take the front brush roller off and check the fan is still intact. Possibly broken fan.
Mar 30, 2014 | Kirby Ultimate G Bagged Upright Vacuum
THE CORD THAT TURN THE FAN AROUND IS BROKE
Are you talking about the fan belt? On this model car it's probably a flat belt (smooth on the outside and grooved on the inside) and is called a serpentine belt. Do not drive the vehicle with this belt broken, as it can lead to overheating the engine!
You can replace this yourself, but the way you phrased your question leads me to believe you don't possess a great deal of automotive mechanical knowledge / aptitude.
If I'm correct in this assessment, your best bet is to get a local mechanic to do this job for you.
Talk with friends, neighbors and relatives to get a consensus on a reputable local mechanic.
Feb 13, 2011 | 1996 GMC Jimmy
Alternator belt broken
Audi A6 (1999 fabrication year):
1. Release the fan belt tensioner.
2. Remove the broken belt.
3. Put the new belt correctly in place.
4. Set-up the fan belt tensioner.
If you specify the engine type of yours car I will send you the fan belt routing diagram!
Apr 07, 2010 | 1999 Audi A6
Belt replacement
Take the belt with you to an appliance store and they will match it up. Much like a fan belt on a car. You won't necessarily need the model if you have the belt. Next, it sounds like your assembly is broken. If this assembly looks to be in pieces, you may need a new one.
Feb 03, 2009 | Kenmore 73952 Gas Dryer
My fan belt on my hoover is broken,where is it located and how do i fit a new fan belt
Get a new belt, then remove the bottom plate. The belt goes around the brush roll and the motor shaft. If you don't see the motor shaft, then you will need to remove the top cover to get to it. The belt will stretch to go from the motor shaft to where the brush roll sits in. If this model has 2 belts, then the drive belt(flat) goes from the motor shaft to the bigger pulley close to the brush roll.
Aug 10, 2008 | Hoover Vacuums
LOUD noise
The armiter or fan is broken and if you get it replased it should work like new
Jul 24, 2008 | Hoover U5227-930 Elite Upright Vacuum
Heating & Cooling Logo
349 people viewed this question
Top Friedrich Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
