Question about Archos Gmini 402 Digital Media Player
Unit Frozen After battery replacement
Hi, I inherited an Archos Gmini 402 from my sister after she told me, and I quote 'the battery doesn't last 2 seconds'. She really wasnt kidding. You could give the unit a full 4 hours charge till the led flashes at you. Turn it on and without even playing music you could watch the battery indicator go from full, to half, to empty, then off and dead all in the space of about a minute.
Nevertheless I tried to contact archos who wouldn't cover the battery replacement and I would have to send them half a million pounds to fix it (not likely). So I went down my own route and sourced a replacement battery. The swap was simplicity (how could it not be with only 2 coloured wires) and after screwing the case back on I tested it and: Yay! It fired up first time; but thats it. The screen illuminated with the archos gmini logo and the HDD led blinked once. And thats all it will do.
I led it 'sit' there on that screen until the battery went dead, then I charged it fully again but when I switched it on it still does exactly the same thing. I have found out that by holding the back/stop/escape arrow button you can turn the unit off, but it still doesn't do anything when you turn it on again.
What have I done? Have i killed something by swapping the battery? Surely everything is kept on the hard drive right?
Any help would be greatly appreciated.
Dan
  • 1 more comment
  • bignely Jun 24, 2008
    Same problem. I have done everything possible to fix it, including contacting Archos. They told me they wouldn't repair it because the 402 has been discontinued, and that they would give me a discount if I bought a new media player from them. I'm going to continue to try and find a solution though.
  • TangoVTEC Jun 25, 2008
    Ah a new plan!
    I will let you know how I get on!
    Thanks a lot.
  • TangoVTEC Jul 01, 2008
    ITS WORKS!!!!!!
    You da man bignely!
I came up with a solution (finally!). Only try this if you have exhausted all other possibilities.
First, make sure the unit if turned off, remove the backplate, and set the battery aside, still connected. Peel back the gold foil where hard drive connects to the motherboard, and loosen the small silver plate at the other end, sliding it to the side. Remove the hard drive by sliding it off the pins. Turn the unit on, and you should get a screen that asks if you would like to reformat. Replace the hard drive, carefully, and quickly, and reformat.
I had to reformat twice, but I eventually got the thing working. I was almost ready to toss it, so any extended life I get is worth it. If nothing else, this should get you off the dreaded logo screen. Good luck!
Posted on Jun 25, 2008
Thank you bignely!! Your solution worked! You saved me not only my player after looking like it was hopeless, but you also saved me some extremely valuable recordings. You rock!
Posted on Jul 27, 2008
3 Suggested Answers
SOURCE: archos gmini 402 camcorder
Try turning the unit on with the hard drive disconnected. When I did this (mine had a similar problem) a screen came up and asked me if I wanted to format. I plugged the hard drive back in and reformatted. I had to format twice, but after that it worked fine.
SOURCE: I need a replacement screen for my Archos 402 Gmini
Broke the Back on my Archos Gmini 402 20GB and if anyone has one for sale broken i am willing to buy it from them for the parts as all i need is the rear panel and the screws for the Rear panel.
Posted on Jun 16, 2009
Archos Gmini 402 Camcorder will not charge properly.
i think it has battery problem. its not charge properly. check its cable or other wise change the battery with new one
Jan 19, 2012 | Archos Audio Players & Recorders
Jan 26, 2009 | Archos Gmini 402 Digital Media Player
Archos gmini 402 camcorder
May 04, 2008 | Archos Gmini 402 Digital Media Player
Archos Gmini 402 camcorder 20GB digtal media player
Hi there this may seem a silly question but the ear phones you are using are a stereo ear phone? or the adaptor to your archos is a stereo one?
Apr 09, 2008 | Archos Gmini 402 Digital Media Player
Archos gmini 402
Output 5v=0.75A
negative exterior, positive interior
Feb 13, 2008 | Archos Gmini 402 Digital Media Player
Freezes on start up
If you have problems with the file system on your Gmini? 402 you can try to fix it using the DOS utility, check disk (chkdsk). Do the following; ? Make sure external AC adapter is powering the Gmini? 402. ? Quit all running applications. ? Properly connect the Gmini? 402 to your computer ? Wait patiently (up to 5 minutes) for Windows XP to show the local drive as mounted. ? Open a DOS window. Programs > Accessories > command Prompt. ? At the prompt, type chkdsk e: /f. Use e: or f: or whatever drive letter is representing your Gmini? 402. The /f argument tells the program to automatically fix errors. ? Be patient, this may take a while. ? When it is finished, exit the DOS Window and properly disconnect the Gmini? 402 from your computer. Try it now and see if makes any difference,
May 22, 2007 | Archos Gmini 402 Digital Media Player
Gmini 402 camcorder freeze/format
If you have problems with the file system on your Gmini you can try to fix it using the DOS utility, check disk (chkdsk). Do the following; ? Make sure external AC adapter is powering the Gmini. ? Quit all running applications. ? Properly connect the Gmini to your computer ? Wait patiently (up to 5 minutes) for Windows XP to show the local drive as mounted. ? Open a DOS window. Programs > Accessories > Command Prompt. ? At the prompt, type chkdsk e: /f. Use e: or f: or whatever drive letter is representing your Gmini. The /f argument tells the program to automatically fix errors. ? Be patient, this may take a while. ? When it is finished, exit the DOS Window and properly disconnect the Gmini from your computer. Try using the device now and see if makes any difference. This method should help to fix any disc errors that have occurred within the FAT and help your PC recognise it again. If you have more problems, try formatting it using a DOS prompt. You MUST make sure NOTHING is trying to access the disc before you can format it - this includes windows explorer.
Archos Gmini 402 Digital Media Player Logo
650 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
