Question about Frigidaire FES367 Electric Kitchen Range
Frigidaire drop in range model #FES367DSA
We turned the breakers off to work on a evaporative cooler and when we turned the power back on the control panel was blank. I pushed cancel and all of the other buttons and nothing worked. I turned on one of the knobs for the cooktop and the panel flashed 1200 so I set the clock and turned off the cooktop burner and the panel went blank. When turning the knob it makes a buzz for about a second. When I had the cooktop burner on I also turned the oven on and neither of them heated up. The range is about 31/2 years old
IFIXALL
  • 868 Answers
SOURCE: Electronic Oven Control won't work after power failure
Replace the clock.
Posted on May 22, 2008
SOURCE: Frigidaire Range control panel DEAD
We tested the EOC and it will indeed need a replacement. Also, just a couple weeks prior we ran the "clean" mode on the oven as did another poster who experienced the "pop" and loss of the control board/oven function, but still had stove top function.
Posted on Dec 17, 2008
  • 3238 Answers
SOURCE: F 31 Frigidaire gas range
if it cooler that the temp set its the theromstat f31 sorry don.t know
Posted on Jan 05, 2009
SOURCE: Frigidaire electric stove, burners work oven does not. No clock
one of the stoves does not work. What could be the problem and how to fix it?
Thanks
Posted on Sep 13, 2010
  • 82 Answers
SOURCE: The stove looks like it has no power and none of
to give you the right information, brand and model is needed. also if its electrical plus gas, or just electrical...Now if you get power to the clock usually the clock works all the time.. if you have knowledge with a voltage meter I sujest you test the main power to the main device. in some cases there is a fuse of somekind. you must test for continuaty. test for power to the knobs and when you open the know you should have power on the continuing wire. test the knob from one end to the other for continuity by turning clockwise and counter clockwise. if there is continuity you know it works fine. then test for main power. test for continuity, then test for main device power.consult a voltage meter instructions if you dont know how to do it.
Posted on Nov 23, 2010
Fes367dsa fan runs while baking but it is not a convection oven
Chris Lindstrom,
I understand that you have a fan running while you are baking. This is a totally normal function of your applliance. A cooling fan may automatically turn on and off to cool internal parts. It is normal, and the fan may continue to run even after oven is turned off.
-Best Regards-
Jan 15, 2014 | Frigidaire FES367 Electric Kitchen Range
Stove stopped working - electric pannel is not working- no digital reading
First attempt ... try unplugging the range (or turning off the breaker) for at least 2 minutes. Maybe a "hard reset" will bring the controls back to working condition again. If there is no difference after turning the power back on, further information on your range will be needed to attempt to narrow down the possible failure.
Apr 15, 2011 | Frigidaire Kitchen Ranges
No power to tstat
If you have no power to the cooler control, your breaker has tripped. Check it. Turn it off hard, and back on hard. If it trips again, you have a problem up top, with a motor, pump, that is pulling enough amps to trip breaker. This is all it can be on these units, no power from main breaker to unit control.
Shastalaker7
A/C, & Heating Contractor
Mar 29, 2011 | Mastercool 67471 Evaporative Cooler Air...
Frigidaire Model fgfl79gsa EOC won't lite up
If it has 120 volts to the EOC, with a good line and nuetral, and it won't show the clock or turn the oven on it has to be replaced. Frigidaire doesn't offer repair parts for the EOC.
jim
Jul 28, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Frigidaire Gallery ES340 electric range, burners will not turn on
Okay,
1, check your power, locate your breaker for the range. turn the breaker off and turn it back on.
Your Range it is electronic control on the Oven but not the Stove Top heating elements.
After you reset the breaker and it still not work.
Please let me know more about the unit.
When you purchase.
How/when it happen.
What is the indicator showing.
nguyen@ite.net
Jun 09, 2009 | Frigidaire 30 in. Electric Gallery Series...
Get F5 error code. Burners don't work. Oven don't work, only the convection and top broiler. Bottom oven don't work. frigidaire stove, plefm399dca
Hi jdaleq,
The f-5 code on the frigidaire ranges is a bad one. It is a ERC (electronic range control) failure. The repair manuals state to replace the control when the f-5 code shows up. You can also try to reset the control. To do this flip the breaker to kill the power, wait about 20 minutes then turn the power back on. If the problem returns then you will need a new ERC. The part number is.
#316418704 The price is $194.99 including shipping in the US. I do have these available to ship today. I hope this helps and please rate me when you can.
Mike
Anderson Appliance
(865)945-3808
Sep 30, 2008 | Frigidaire Kitchen Ranges
No Power to FGF366ESB Range
althougy ou cked circuit breaker did you try unplugging unit waiting 2 min then plugging back in. sometimes you get lucky and will reset. has to do with high voltage bleeding through to low voltage wiring. if it works, your good!!!! if not remove the back panel and check the clock/control for icoming power. as long as you have 110v going in at the black (L1) you should have a display. if you have powerand no display you need a new control.
Mar 13, 2008 | Frigidaire FGF366E Gas Kitchen Range
Oven does not come on
First, reset your circuit breakers. This is generally a pair of breakers with at least a 30 ampere rating. It is not your kitchen breaker. Turn them both off and back on. If this doesn't do it, you've got to look at the heat element. Does it look damaged, deformed, discolored? If so, remove it and bring it to the appliance guy to get it tested. Generally this is a couple of screws. Make sure power is off when dealing with this. Not the element? Then you've got the control board.
Nov 22, 2007 | Frigidaire FEF336BC Electric Kitchen Range
My Frigidaire range display has gone out and the oven doesn't work.
sun, first test is to power the unit down. Find the pair of breakers which are generally 40 or more amperes. Turn them both off and back on. If this doesn't fix it, you will probably need a circuit board.
Nov 10, 2007 | Frigidaire FEF336BC Electric Kitchen Range
Frigidaire FES367 Electric Kitchen Range Logo
275 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
