Question about Baumatic BTWM4 Front Load Washer
Leaking Machine from underneath
Washing machine appears to be leaking from underneath. i have checked the incoming and outgoing water and they appear to be OK. I recently heard loud noises from the machine, as if a coin has been stuck in the drum. i opened the filter and it was fine. the machine is only a year old. this should not be normal. can anyone help. please...
  • millernew Jul 25, 2008
    HI
    I do have the same problem
    can anyone help
  • 734 Answers
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Posted on Dec 12, 2008
Bosch avantixx front loader leaking underneath machine? machine only 2 years old
  • You will find a small door on the front bottom of the washing machine.
  • Open it.
  • Unscrew the filter and rinse it with running water.
  • Put it back in place and repeat the above steps in reverse order.
This should solve your leakage problem.
Aug 03, 2014 | Bosch Washing Machines
Water leaking underneath. doesn't appear related to hook up
check the water valves that they haven't split under water pressure....then check the pump and hoses inside the machine.... follow your nose really to see what's happening and where the water is coming from good luck
Mar 01, 2011 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washer will not spin there is water on the floor and has a fault code of 130 it is fisher+paykel brand model numberWL26CW1
Hi just read your posting.Error Code 130 means your fault is called Single Rotor Position Sensor Error.This component is attached to your motor which is underneath your machine.What concerns me is your machine is leaking.Did the Error Code appear the same time your machine started leaking?The reason I am asking this is because the water could have damaged the rotor sensor.Is the water leaking underneath the machine?Please reply with additional information and I can help you rectify this fault.
Jul 20, 2010 | Fisher and Paykel WL26CW1 Top Load Washer
Water leaking from Washer during cycle
you can remve a few screws(3) across the bottom of the unit.( just above your "add-on" drawer. 3 torx 20 screws and after removing the acess panel youll get abetter look as to where exactly you water is coming from
Jan 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Leaking washing machine
you need to clean above where the drawer goes in, the water jet holes get blocked and spray sidewards. also you can reduce the water pressure at the supply tap to a fast trickle this will avoid jets of water flowing over and forward of the tray.
Jun 22, 2007 | LG WD-1080FD Front Load Washer
Washer leaking water from underneath
Your leak could be coming from the rubber door seal. Inspect all the way around the rubber seal paying particular attention to the areas behind the rubber seal where it meets the wash tub. They wear with age and can develop small holes. When they start leaking it appears like water coming from under the machine. I hopes this helps.
May 11, 2007 | Kenmore 44042 Front Load Washer
Baumatic BTWM4 Front Load Washer Logo
247 people viewed this question
Top Baumatic Washing Machines Experts
Einar Axel...
Einar Axel...
Level 1 Expert
Are you a Baumatic Washing Machine Expert? Answer questions, earn points and help others
