Question about Microwave Ovens
Whirlpool Microwave excessive grease build up
When I first got my microwave oven the steam build up was go great that the turntable broke. I replaced that, but still have excessive steam build up. Also there seems to be an excess of grease in the top of the oven. Is there a way to clean this? I cook bacon quite a bit. I have noticed at times that there are drops of water on the ceiling of the microwave.
  • 1 more comment
  • ufunny Apr 20, 2008
    I do keep the moisture wiped from the microwave. I am just concerned that maybe there are filters in it that I need to change???
  • ufunny May 26, 2008
    Whirlpool MH1150XMB-1--Just thought I would let you know. Whatever the problem was, now the microwave quit. It popped then quit. The lights work,turntable works, but won't heat. We just gave up and bought another, since it probably would cost more to fix it than buy another. It is probably the door switch??
  • Anonymous Mar 21, 2014
    my glass dish broke in the microwave while cooking bacon
Posted on Apr 21, 2008
  • Microwave Ovens Master
  • 9,086 Answers
First you should be sure the ventilation is correct through the oven.
If you don't feel air through the vents when it's running, that needs to be addressed.
Also, it's important to wipe off the interior surfaces whenever moisture seems to be accumulating.
Also, it's recommended to leave the door open a few minutes after cooking to allow it to dry.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Apr 18, 2008
  • William Miller
    William Miller Apr 21, 2008
    Okay, could you reply back with your model number, then I could check the owner's manual if you don't have yours.
  • William Miller
    William Miller May 26, 2008
    With the pop, I would suspect a bad high voltage rectifier diode.
    But it sounds like you had a lot of issues with it, so I'm guessing a fresh start with the new unit is a welcome change for you.
    Good luck.
I need a replacement turntable for my brevile combination microwave model brcm2516 where can I get one
First4Spares Glass Turntable Plate For Breville Microwave Ovens ...
https://www.amazon.com/First4Spares-Glass-Turntable-Breville-Microwave/.../B007B...
Shop First4spares at the Amazon Small Appliance Parts & Accessories store. Free Shipping on eligible ... BREVILLE MICROWAVE TURNTABLE Glass Plate 245mm 9.5". $29.99. Next ... Container for Microwave Oven · Add to Cart · Add to ...
Amazon.com: BREVILLE MICROWAVE TURNTABLE Glass Plate ...
https://www.amazon.com/BREVILLE-MICROWAVE-TURNTABLE-Glass.../B00COP... Quality replacement glass turntable for your Breville microwave. ... Small Appliance Parts & Accessories > Microwave Oven Parts & Accessories > Turntables
Breville Shop ' Partmaster
www.partmaster.co.uk/breville/microwave/catalogue.pl?shop=breville&path... Find your Breville products and repair your appliance yourself for less. ... Connects the microwave motor to the glass turntable Suitable for select microwave ...
Breville Canada
https://breville.ca/ Breville designs and engineers small kitchen countertop appliances to deliver commercial quality performance that look great and are easy to use.
Breville Microwave Parts & Accessories ' eBay
https://www.ebay.co.uk > ... > Breville Microwave Parts & Accessories BREVILLE Microwave Glass Turntable Plate Roller Ring Support Stand 3 Wheel ... Turntable Turn Table
Plate MOTOR for BREVILLE Microwave Oven ...
Breville Parts -Google Search
Jul 03, 2017 | Microwave Ovens
Burned a tiny hole in the microwave inlet cover of my whirlpool MH1150XMQ0? Is it safe to still use?
Safe but will burn more replace wave guide cover common problem
in all microwaves grease build up on guide cause it to burn
Dec 05, 2016 | Whirlpool Microwave Ovens
Kitchen aid kemms308sss04 plastic insert on turn table broke how do you replaace
That may be called the turntable coupler or turntable support or roller ring assembly.
You can find helpful exploded views and part numbers at the link below, by replacing XXX with the full model number found on the tag on your microwave (not on the service manual).
XXX&siteCd=WHRCOM&userType=Consumer">http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=XXX&siteCd=WHRCOM&userType=Consumer
My preferred place to order Whirlpool parts is from the Pro here.
Feb 16, 2014 | KitchenAid Microwave Convection Oven
Hot microwave door handle
I always recommend that you use the vent fan whenever you're cooking on the stove top to keep heat, steam, and grease out of the controls and door panels.
Jan 08, 2013 | Whirlpool Microwave Ovens
The glass turntable broke. Where can I find a replacement?
Go to www.ebay.com Type: make and model of microwave, and refine search to glass plate.
Apr 02, 2012 | GE Spacemaker JVM1540 Microwave Oven
Turntable not turning - no microwave cooking
Could be a reset or fuse within may just have popped Beware of excessive internal Voltages when servicing...
Apr 20, 2010 | Neff B7740N0GB Microwave Oven
Whirlpool MH1150XMB
Driver turntable or turntable motor needs to be replace
Aug 24, 2008 | Whirlpool MH7135XE Microwave Oven
Microwave Ovens Logo
386 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
