Question about Vizio VX37L Television
Channel buttons (up/down arrows)
Up/down arrows for channel control do not respond on either the remote or at the television...26" LCD vizio
  • 2 more comments
  • Anonymous Jul 13, 2008
    channel button dont work
  • captiansave Sep 30, 2008
    channel buttons up and down on the remote and tv do not work
  • Vizio user Oct 13, 2008
    Yesterday the channel up and down (- & +) buttons worked fine, now neither the remote nor the buttons on the side of the TV work. Aaarrgh.
  • Anonymous Mar 23, 2014
    the remote wont work and neither will the side controls help
I called the Vizio help line. The solution is to auto re-scan for channels. I was skeptical, but it worked!
Posted on Oct 14, 2008
Do an autosearch in the setup menu and that should program those buttons. Weird I know, but it worked for ours!
Posted on Jun 22, 2008
Vizio tv dropped a channel, won't rescan
Try with the remote to direct enter the channel number (with the number buttons and or enter) If set makes it there go into menu for option to manually add it to the set memory.
Not likely a problem with your set.
Dec 17, 2012 | Vizio RazorLED M260VA 26" LED-LCD TV -...
Vizio TV. Can't get out of PHOTO mode. I have no remote. Side MENU button doesn't respond when in PHOTO mode. Need to Hard Reset... How can I?
^_^ Those answers are only for new remote but that's not the only way, There trying to ask in another way with out a remote.
Jan 16, 2012 | Vizio VA26L 26 in. LCD HDTV
How to initial The TV? Problem: Only one channel available when connect a cable right now.
Hello:
It sounds like you need to do a "channel scan". For the LG 26LX1D, you can follow these directions:
  1. Press the "MENU" button on your remote
  2. Use the Up and Down Arrows to select "SETUP"
  3. Press the ">" button
  4. Use the Up and Down Arrows to select "EZ Scan"
  5. Press the "ENTER" button
This will scan all available channels. You can edit the channels by choosing "Channel Edit" in the same menu.
Mar 06, 2011 | LG 26LX1D 26 in. LCD HDTV
We have lost our digital channels on our sharp aquos. how can i get them back. ex. 5.1, 5.2, 17.1 etc
Remove the coax cable from the television
Unfortunately your digital tuner may have gone kaput. I hope not but try an init and then rescan the channels. Unplug the television. Press and hold down input and vol-. This might take two people. While holding those buttons down on the television NOT on the remote have another person plug the television in. Keep holding down on those buttons until there is a k (green) on the left side of the screen. Then release the buttons and hold down vol - and channel - until the service menu comes up on the screen and release the buttons. Scroll down once with your down arrow on your remote until you are on page 2/26 (might be 2/some other number besides 26). The press the right arrow to turn on INIT + cause on. Press enter. When the screen turns green unplug the television without powering it down or anything. When you plug it back in it will prompt you back through the setup process.
Replace the coaxial cable before completing the setup.
If you do not have this exact model number do not complete the steps above without consulting again with the correct model number because you can wipe the memory of the television if you do not complete the right choices to bring up the service menu.
Dec 04, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
CHANGE CHANNELS WITH THE CONTROL
Run a channel scan on the DTV and/or TV input depending on what one your not getting channels on. This will solve your issue.
Change the input on the unit to the DTV or TV input. Press the menu button on the remote. Navigate to the tuner DTV or TV tuner setup menu. Go down to auto search using the down arrow. go right when with auto search selected. This may take a few minutes but you should have all the channels back after the scan.
Apr 06, 2009 | Vizio L32 32 in. LCD HDTV
Channel button on tv and remote control dosent work
The channel buttons on the tv and remote only navigate through the channels programed into the tv. You will need to go into set up and scan for channels or manually add channels you wish to receive.
clarkco
Mar 07, 2009 | Vizio GV42L 42 in. LCD Television
Element TV remote control
Our Vizio TV came with the same problem and my husband just figured out how to fix this... Go to menu then TV at the top and go down to skip channel. Uncheck all boxes and this should solve the problem. Hope it helps.
Dec 01, 2008 | Vizio VO47L 47 in. LCD TV
Olevia series 2, 26" LCD TV remote control device code for DISH remote control
well in most tv the dish remote control reconice the code automaticaly just press the tv button then press the power button and press de up arrow button (the one with the square over the select button) until the tv get off then press the # button to save the code try this.... good luck..and rate me
Jan 04, 2008 | Olevia LT32HVM 32 in. LCD Television
Code for Vizio tv
I contacted Vizio the other day. They tell me that they use the same generic codes as LG. I have Suddenlink Cable, formerly Charter, so I still use the Charter remote. My remote only needed 3 digits and I have noticed that many need 4 or 5. I can tell you that the LG code worked for my tv. I can power on/off, volume, and change the channel. All other functions require the manufacture's remote. The code I used is 005. There was also 004 but that did not work on my tv. Hope this helps someone!
Dec 26, 2007 | Vizio L32 32 in. LCD HDTV
Vizio VX37L Television Logo
1,151 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
