Question about Yamaha RX-V657 Receiver
Front display panel
I have no display on the front panel of my AV receiver. Everything else seems to be working fine - watched a dvd last night by using OSD - just no front panel display......
  • GT1963 Apr 15, 2008
    Firstly, let me say l was sceptical as to whether l would receive a response, so congratulations - l am very impressed with the speed of your reply. I hadn't heard of FiyYa at all before l used Google but l will be certainly mentioning you to my friends and colleagues!
    As for your reply, you'll have to excuse my ignorance but where would l find the display pins? Are they internal to the unit? You can probably tell, l am no technician and am not all that confident at opening the unit up!
  • Anonymous Mar 25, 2014
    Toshiba while recording on DVD aftaer about 40 minutes of recording Front Panel Display started blinking on and off. Turned it off not knowing what was happening it lookied like it was still recording.
  • 4,234 Answers
Check for bad connections on the display pins themselves. Specifically, the ones on the ends are the power/ground pins.
Let us know if that resolves the problem. If not, we'll look further into the circuitry.
Dan
Posted on Apr 14, 2008
  • ABRsvcs Apr 15, 2008
    Yes these pins are inside and probably need to be resoldered. If you are not familiar with this process, expect this to cost no more than the local labor rate. It is possible that the display is defective, but that is rare. I would first suspect either bad connections as I mentioned or a bad power supply. Specifically there is a regulator circuit for the display that may be defective as well. If that is the case, the parts will run about $5-$15.
    Dan
DVD stopped working
it seems the lens is bad
Feb 24, 2010 | Sony SLV-D950 DVD Player/VCR
Problems installing Toshiba RDXV59DTKB Freeview+ Hard Drive DVD
Two things, I was using a flaky budget=price SCART cable which caused a colour probolem. A techie friend said to view on AV rather than TV, which worked.
Jan 08, 2010 | Televison & Video
Acoustic Solutions TV/DVD P1480 has stopped working
Doh me, daughter had accidently hit the standby button without realising, had a brainwave after posting above and tried that, everything working fine.
Oct 01, 2009 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
No longer getting video feed through Home Theatre receiver
HDMI ports 5 and 6 on the back of tv no longer are working. (We had a series of thunder storms so don't know if that is how they got damaged or if it was something else) but moved HDMI input cable to HDMI port 4 on tv and everything is working again. Service call placed for warranty service on tv to repair bad ports.
Sep 14, 2009 | Sharp Televison & Video
Have hdcp error flashing on front display
HDCP is copyright protection for HDMI ensuring that you can't copy the protected material.
Did you connect some new DVD player or new TV to the receiver? However the error should clear once you disconnect everything from HDMI. If not, try to restore the receiver to factory defaults.
Apr 11, 2009 | Yamaha RX-V461 AV Receiver
DVD movies do not play
A blue screen means the TV is not receiving a video signal. Check all connections, then try another player, cable, etc. Also, check DVD and TV AV settings.
Dec 10, 2007 | Pioneer VSX-D912 Receiver
Can't get all speakers to turn on in AV-1 function
can't seem to get the sound to come on. i knowe i have sound but will not turn on
Feb 09, 2007 | Amphion Mediaworks T-365 System
Sudden failure to power up
I've had this happen a number of times with my receiver. This trick from the Troubleshooting guide in the owner's manual usually does the trick: To reset If an unusual condition in the display window or malfunction occurs, reset the unit as follows. 1 Press the POWER button to turn off the power. 2 Press the POWER button while pressing the ENTER button. Everything stored in memory after purchase is canceled. If the power cannot be turned off in step 1 because of a malfunction, reset by disconnecting the AC cord and carry out step 2.
Aug 01, 2006 | Aiwa AV-D77 Receiver
Yamaha RX-V657 Receiver Logo
309 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
