Question about Jenn-Air SVE47100 Slide-In Electric Kitchen Range
Tell me what jenn-air model sve47600 10 year old stove is worth
Ive come across two of these stoves in very good condition very clean, a family member wants to sell them but i dont know what a fair price would be
Not sure, but I would be interested in parts if you have any extra. I need a double burner for mine. I have a burner for one side and a grill and steamer for the other. I do not use the steamer but would love additional burners.
Posted on May 04, 2008
My self clean feature on my stove will not start. Don't know where the model number on the stove is so I can't tell you that. It is 20 years old and is a down draft fan. Can you help me?
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Dec 12, 2010 | Jenn-Air Kitchen Ranges
My GE XL44 Gas Range (Model JGBP34 GEP 1A) control
If you like the stove and it in good shape otherwise, have it fixed. The parts are still available. The stove in good used condition (without leak) is probably worth $75.00. May cost that much to repair it. Will cost approximately $450.00 to replace it with equal range. If it's a standing pilot model (no electricity needed) they are unavailable and your new range will require power to use the oven. Hope this helps.
Dec 07, 2009 | GE Spectra JGBP35 Gas Kitchen Range
My stove berner egnighters shorted out manufacturing problem arked a hole in the burner control knob gas was leaking arked by it self started a fire from leaking gas i want assistance imedeatly ive spent...
Hi you needed a good gas fitter to look at this problem , you will need some new parts and the leak fixed , but is the stove worth it , or is it worth putting any more money in to it .
you will have to look at the saftey side of it
hope this helps
Oct 31, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Jenn Air stove wired backwards
The fan is likely 120-volt fan, and swapping the wire likely put 220 across the fan. Did the fan seem to rev up very fast? The control is also likely 120-volt, and that too had 220 applied to it.
Give me the model number, and I'll find what parts you need to replace
May 13, 2009 | Jenn-Air SVE47100 Slide-In Electric...
I have a Jenn-air electric stove model S125, which is about 20 yrs old. Lately, the ventilation system quits after about 25 minutes. I usually turn it on manually, but it goes on automatically during...
The answer your provided by email only confirmed what I suspected -- that the vent system was probably overheating and would cut out at a certain point.
Thank you for fast reply. I may have to get a pro to confirm this, as I'm an old lady with NO skills for taking stove apart and installing new vent motor.
Dec 29, 2008 | Jenn-Air SVE47100 Slide-In Electric...
F1 Failure , need to know how to advance the clean timer to get unit to unlock
Hello welcome to fixya,
Below I pasted the fault codes for the two different years of this range.
To diagnose these difference you will need a hands on tech !
this is not an easy thing to determine
JENN AIR
Range/Stove/Oven Fault Codes
Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad)
JENN-AIR
'Newer Style' Range/Stove/Oven Fault Codes
Failure
Code
Condition Check/Repair F1 Power to element relay energized during time of day display Wiring harness shorted or change power relay board (PRB)
Note: for double ovens, change second oven board
Dec 08, 2008 | Jenn-Air SVE47100 Slide-In Electric...
I am getting a F9 on front of my oven
We solved this by holding in the door/light switch, hitting "clean", then pressing stop/clear for about 3 seconds.
Nov 27, 2008 | Jenn-Air SVE47100 Slide-In Electric...
How do i set the self clean on my jenn air stove
pparker581
What model Jenn-air stove do you have?
In the user guide there is a section on using the self cleaning system.
I do not have the guide readily available at the moment or I would send it to you!
Bless You
huuum
Sep 12, 2008 | Jenn-Air Kitchen Ranges
Jenn-Air S160
I did it by mistake. I tried to move the lever over and of course, it didn't open but went to restart. I hit the cancel button and then tried the door again and it opened. Yup, we all here feel likes dorks!
Thank you!
Sep 06, 2008 | Kitchen Ranges
Jenn-Air SVE47100 Slide-In Electric Kitchen Range Logo
370 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
