Installing XP over preinstalled Vista
Dear All,
I have a recent Toshiba Satellite Pro L40, with dual pentium T2130, 1.5G RAM and 60G SATA HDD. I would like to remove the preinstalled Vista Home Basic and install Win XP. Please can you talk me through the process (or direct me to existing advice) in simple steps as I've been told that retaining or reinstalling the correct drivers is pretty crucial with Vista laptops.
Many thanks for your help.
Sincerely, Geoff.
  • maximus73 Feb 10, 2009
    Im sick of the Vista on my Laptop I need help on istaling Xp if any one can help me that would be great. thanks
    max
    makcnmka05@yahoo.com
  • Frank
    Frank May 11, 2010
    I would like to mention that removing Vista might void the manufacture’s warranty.
    You might look into dual booting if you want to be safe.
    I would read this and follow the links.
    http://www.labnol.org/software/tutorials...
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 49 Answers
You can simply boot the system using XP CD and can format the current os and install XP. but, before you do that check whether the proper driver files are available for the XP for your system. Note that if you still have warranty for your system it is not advisable to do that. It will break the warranty.
Posted on Feb 23, 2015
  • 175 Answers
http://www.labnol.org/software/tutorials/dual-boot-pre-install-windows-xp-vista/1883/
Posted on Apr 15, 2008
    Novelist:
    Champion:
  • 214 Answers
You can Install XP simply by inserting the Installation Disk and running the Install Program. When asked where you want to install it select C:\ and let it remove the existing Operating System.
PeepnLklown is correct that this MAY void your Warranty so check this out first. If this is not a problem, install XP as described.
As regards the Drivers, it is IMPORTANT to have the correct Drivers FOR THE OPERATIING SYSTEM INSTALLED, all your devices should have XP drivers listed on the Manufacturers sites - so Identify the components and download the drivers from the manufacturers site (this may not be Toshiba) before you install XP (to make sure that you will have the XP Drivers for the devices).
To identify the Devices - open Device Manager (If I remeber correctly this can be found in Control Centre under Administrative Tools) and open each of the devices which will display the manufacturer and model number of each device. Write these down and do a Google search with the following string:
(brand Name) (Model number) +driver
This should take you to the manufacturers Support site where you can download drivers. Check to see that XP is listed as one of the Operating Systems. Download the Driver and (when you have them all) burn them to a disk.
Install XP and when asked for the drivers, direct it to the disk you have burned to find the drivers. The DVD Burner may need to be searched for on the Internet (after you have Installed XP) before you can use this device to read the Disk.
Good luck.
Posted on Apr 14, 2008
How do I remove the hard drive in Toshiba SatellitePro A10 EN? (Removing the plastic cover exposes only the end of the hard drive. I'm reluctant to just start pulling on it!
  • The original Toshiba Satellite Pro A10 HDD is fitted into a Toshiba Satellite Pro A10 Hard Disk Drive cradle - Toshiba Satellite Pro A10 HDD caddy.
      • Gently remove the cradle from the laptop, yes pull on it
      • Unscrew the original Toshiba Satellite Pro A10 Hard Disk Drive & remove it from the cradle.
      • Screw the new Toshiba Satellite Pro A10 Hard Disk Drive into the cradle & refit the cradle into the laptop.
      • Re-install XP or Vista
          Aug 21, 2010 | Toshiba Satellite A10 Notebook
          Displays no hard drive found wen installing win xp
          You have to go to BIOS setup, find HDD setup, and change the value to the other one (there are only two possibilities). That will fix your problem. The problem is caused by the fact that the lap top was designed for vista, not XP. and the lap top contains SATA HDD. when installing XP pre-installation doesn't have SATA drivers, so your OS can not see the HDD. Change it in BIOS, and you trouble is gone
          Nov 14, 2009 | Toshiba Satellite A200-19501F Notebook
          Not Changeing sata to ata
          You will need to go into the BIOS and disable SATA RAID. then windows XP setup will show the HDD.
          Jul 02, 2009 | Microsoft Windows XP Professional With...
          Installation of windows xp on a preloaded windows vista laptop
          See this , you have to download the SATA driver , as you have a SATA hard disk , then slipstream it into the xp installation package.
          Alternatively , put the driver on a floppy and press F2 when prompted during the setup when its loading all the files (It says Press F2 if you want t o install a SATA Driver"
          Then it will detect your drive and install as normal :D
          http://news.softpedia.com/news/Install-Windows-XP-On-SATA-Without-a-Floppy-F6-47807.shtml
          Jan 07, 2009 | Toshiba Satellite A100-S8111TD Notebook
          Running XP on a Toshiba Satelite L40-18X
          I Have satellite L40-18W-PSL4CE laptop . I installed XP . i got all drivers except sound driver. the last sound driver was running on vista is (Realtek High Definition Audio System Software Ver:R1.72) on toshiba site they said this driver soppurt vista & xp but i got nothing after installing the driver. pls help me with greatfull.
          Sep 28, 2008 | Toshiba Satellite A135-S4527 Notebook
          Matshita DVD-RAM UJ-8505 problem
          often when a newer computer comes with vista installed.... going backward and installing xp just doesn't work because the new hardware is not compatable with xp.
          Robert
          Sep 26, 2008 | Toshiba Satellite A135-S4527 Notebook
          Remove vista
          Hi Andrae
          If your installing Windows XP you need Sata HDD drivers ( because Windows XP doesn't come with Sata support)
          Go to link to find out more
          http://www.mydigitallife.info/2007/10/23/windows-xp-setup-could-not-detect-and-find-any-sata-hard-disk-drive-on-ahci-mode/
          bye Pete
          Jul 03, 2008 | Toshiba Satellite A205-S4617 Notebook
          Toshiba Satellite Pro L40 PSL43E Vista B to XP downgrade
          i can find drivers for Toshiba Satellite Pro L40 PSL43E for XP too! Help mi plz. my model is PSL43E and i cant find this model in toshiba site:/
          Apr 04, 2008 | Computers & Internet
          How to install XP in toshiba Satellite L45-S7423 laptop
          I found it!!!>>>
          Just go to Toshiba support web site Download the Storage Manager Driver for XP 32 then have an External floppy drive with formatted Disk ,install the drivers Files in the floppy connect the floppy drive put the XP sys CD Boot from the CD as in Solution #1 or by press on F12 tell choices boot screen popup select the CD then after that when the third party appear press F6 to chose the Driver for HDD to get recognized by the system. J
          Mar 27, 2008 | Computers & Internet
          Computers & Internet Logo
          392 people viewed this question
          David Payne
          David Payne
