Question about Whirlpool AWM6100 Front Load Washer
WHIRLPOOL INSPIRATION AWM337-----
After selecting programme,machine just goes thro cycle no water going in machine nor any spinning,back to stop then carrying on again through cycle again.....unable to open door.!!!!
  • Anonymous Apr 28, 2008
    cannot get a full cycle, cannot open door, machine shakes excessively in spin
  • 1294 Answers
SOURCE: We have a Whirlpool AWM
Check your exit hose spigot, it may be clogged. This is if your filter is all clean (ref manual). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Posted on May 10, 2008
  • 1073 Answers
SOURCE: washing machine spins but doesnt drain water until I turn it back to spin only
timer contacts are burnt replace the timer
Posted on Jun 13, 2008
jsrock516
  • 5911 Answers
SOURCE: washer
The symptoms you describe are typical of a broken lid switch. The lid switch is located under the washer top on the right hand side. It is activated through a slot by a small plastic piece on the lid called a "lid strike". Make sure the lid strike is still installed and not broken. Make sure the lid switch itself is not loose, as well. There are two mounting screws along the washer tub opening that hold it in place. If the screws become loose the switch will not make contact with the lid strike when the lid is closed. If you need to replace the switch or lid strike, the parts are available at searspartsdirect.com. Just type in your model number and look under the "Washer Top and Lid" heading on the next page. The lid switch is listed as item number 22 (part #3355806) and the lid strike is listed as item number 16 (part #358684). Both parts combined will cost you about $30. If you have further questions and/or require additional assistance, please let me know. I hope this helps you.
Posted on Jul 22, 2008
docjohn174
  • 943 Answers
SOURCE: Washer will not Spin during SPIN CYCLES
Thanks for the question If your washer sorta spins and washes ok, your problem is with the transmissionTHanks for your question THe Appliance doc
Posted on Sep 11, 2008
futureloginn
  • 734 Answers
SOURCE: Whirlpool AWO3761 stuck mid-cycle
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Posted on Dec 10, 2008
    Oko 72630. Why is it stuck on rinse cycle?
    Could be several reasons:
    - Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
    - Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
    According to your description I think that this is not a failure otherwise error E20 will be appears on display.
    Once the washing programme has come to an end, END illuminates on the programme progress display.
    If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
    1. After a rinse hold, the water must first be pumped out:
    - Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
    After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
    - Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
    - Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
    At the end of this programme step, the END indicator will illuminate.
    2. Open the door.
    As soon as the DOOR indicator lights up green, the door can be opened.
    Dado
    Aug 15, 2015 | AEG Washing Machines
    Fills with water correctly, will not go to next cycle
    Hi ,, ok lets try some fault finding,,, try putting the washing machine on a no or low temp programme like wool,, or even the fill empty spin , see if it moves then,, if the programmer moves through then spins, i would assume the thermostat is broken,, if it moves through but does not spin , it may be the heating element,, if it does not move at all in any programme i would assume the programmer has a problem
    Nov 14, 2013 | Whirlpool Washing Machines
    Hi my hotpoint washing machine wont stop spinning for some reason any ideas what is wrong
    Very likely that the filter is blocked. Because the machine senses there is still water present it carries on spinning but the blocked filter is preventing the machine emptying. Turn off the power at the plug. The filter is usually mounted at the front near to the floor. Unscrew counter clockwise and be prepared for some water to leak out. Clean the filter under a tap, it will probably looked blocked and then re fit. Select a short programme cycle and see if the fault is cured.
    Jul 04, 2010 | Washing Machines
    Programmer sticks before the spin cycle (number 5 and 9) on my beko washing machine also if you change programmes the programmer jumps round
    Prog jumps as it will carry out 1st command selected unless reset.the sticking could be a faulty water solonoid valve if this happens say during softner fill although could also be the timer /programmer at fault
    Apr 03, 2010 | Washing Machines
    Machine wont stop washing on programme 9! went for days. Had the error lights flashing but that stopped.
    If you select a rinse and spin programme and it completes the cycle, then I would say that the heater element is probably faulty, because the programme will not advance until the water has reached the correct temperature.
    If it does not complete the rinse and spin cycle, then it is likely to be the control module that is the problem.
    Feb 09, 2010 | Indesit W 123 Front Load Washer
    Washer stops after aggatating and wont drain
    My Kenmore 70Series washer goes through the wash cycle then just stops when it is to drain and then spin.
    Jun 10, 2009 | Whirlpool Washing Machines
    AWT5108 no spin
    The motor is bad and you should replace the motor. To do this and order it you can go to
    whirlpool.com and type in the model number and get he part
    Feb 08, 2009 | Whirlpool AWT5108 Top Load Washer
    Whirlpool AWM6100 Front Load Washer Logo
    559 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
