I have a 20" Daewoo Tv probably about 8 years old. I was recently trying to change the channel seetings and in the process have lost ITV1 and cannot work out how to retrieve it. I have gone in to menu on the remote control and then edit etc but I can't work out what to do.
  • 655 Answers
See in menu if there is any Search or Scan option.
Try that, that will tune all the signals avail able. Means your chanels will be back.
Thanks
Iqbal
Posted on Apr 14, 2008
    President:
  • 1,944 Answers
You need to find the channel again via tuning.
  • Damen Wong
    Damen Wong Apr 14, 2008
    Does it find it automatically?
How do i reset my DAEWOO dlt-37g1?? i have been on the internet for three hours trying to find a solution...i am going mad.. this morning i turned the television on and it said "no channels found" i
hi check aerial connections on the lead coming in to the house and on the back off the tv if ok try first time installation, thanks
shaun
Mar 16, 2017 | Televison & Video
My daughter has a Goodmans GTVL19W17HDF in her bedroom for two or three years. She has only now mentioned that she has now lost ITV1 Channel 4 and Channel 5 using DTV, and also has a very inconsistently...
Fisrt check that the aerial connector going into the TV is OK.
The UK is in the process of switching off the analogue channels and reassigning to digital TV. This means that the signal strengths of various transmitters are getting stronger and channels are moving around to different frequencies. Try retuning the digital TV stations. If this does not work then try an external DTV box to see if the TV is at fault or it is a bad signal on the aerial.
May 16, 2011 | Televison & Video
Hi. My 8 year old Wharfedale tv ha been working perfectly until now. The picture is fantastic on all the channels including freeview. The only problem is that of yesterday it has lost all reception from...
Hi, problems like this are usually caused by a bad connection or faulty scart lead, you could try to replace the scart lead or check to see if the one you are using is loose.
Hope this helps
Regards
Midge.
Feb 10, 2011 | Televison & Video
No BBC channels available after retuning Sony Trinitron TV
When TV channels are moved from one frequency to another frequency that was previously used by a different channel (sorry, but there's no simple way of saying that !) as has happened recently in th UK, some digital TVs and digiboxes struggle to sort the channel list out properly and channels can go missing as you describe.
If your equipment has the option to delete all currently stored channels (normally in the tuning menu options) then do so and then do a full re-tune.
Sometimes, this solves the problem as the equipment is no longer aware of any previous use of a frequency and just loads every channel it finds.
If this doesnt work, or your equipment doesnt have the option, then there is normally the option soemwhere in the menus to retore the item to "factory defaults/configuration". This will clear all previously stored channels and after a full re-tune your missing chanels should be there. However, any other configuration changes you previously made, e.g picture size, output type (RGB/NSCT/etc), etc will be lost and you'll need to set these again.
NB. some regions of the country have lost some channels temporarily now until after the switch over programme completes at the end of 2012. If you visit the Freeview website, this will tell you if your area is affected.
Nov 07, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
20 year old Quasar colour TV (no remote)
That is because the switches of the front panel buttons are stuck or defective.
Try first unplugging power for ten minutes, this probably wont work.
To fix this the TV must be taken apart from an expert, and front panel replaced.
You can enquiry here for parts.
What you can do at home, is getting a replacement remote and using TV with a remote, or buying a freeview box, and watching and changing channels through the box.
You can get a replacement remote here: Replacement Remote Control orReplacement Remotes
My suggestion, if it is supported in your area, get a set top box with 30 channels : Freeview - digital TV from Argos.
Oct 11, 2008 | Quasar SP-2723 27" TV
Toshiba 2151TB Television
I had a similar problem. You need to press the 2nd button down on the remote 3 arrows should appear on the screen. then use the volume + and - buttons to tune to correct channel. once the correct channel has been reached you need to enter the number of the channel u want stored ie 03. Hope this helps.
Sep 07, 2008 | Toshiba Televison & Video
TV Stuck in VCR mode
I used code 191 for my combo unit
Jul 09, 2008 | Daewoo GB-20H4T2 20 in. TV/VCR Combo
TV channels
Sounds like it lost programing, if it has an "auto program" feature try that, or some older models need it to be done manualy and have a "add/erase" feature, instructions for that should be in your owner's manual.
Oct 31, 2007 | Televison & Video
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
