Question about Epson DFX-9000 Matrix Printer
Error massage 07 displyed on the controll panel when turn on printer
  • semekor samuel Apr 14, 2008
    i need the solution to the printer.
    please some one should help me with this quation.
    thanks
Error 07 is due to Low Volt.
Power Supply or Rom Board (Main Board) is the cause of this problem.
The Motor CR (42V) or the Head Drive (37V) voltage fell below the allowable level.
Posted on Apr 28, 2008
My kyocera fs 1120 mfp all in one lasser printer showing massage out of toner after riffil toner why?
you hv refilled toner only,you should change complete cassette of toner,including electronic chip circuit
Dec 11, 2014 | Kyocera Office Equipment & Supplies
HOW DO I FIX HP DJ T1300 WITH ERROR CODE 08:11
There is a cable behind the disply screen that has a tendency to wiggle loose in shipping. Just reach behind the control panel and push the cables in firmly.
Aug 13, 2014 | Office Equipment & Supplies
Error 08 11
No communication between the product and the Touch Control Panel
Corrective action: Try the following:
1. Check the event log at the EWS support pages to see if there is another SE (for instance 07:10) and troubleshoot the problem more accurately
2. Turn off the product and turn on again, and check to see if the error remains.
3. Upgrade the firmware
4. Check the condition of the USB cable, check it is not damaged or incorrectly connected.Reconnect USB cable (from Engine PCA to the Interconnect PCA or from Interconnect
PCA to the Touch Control Panel
5. Replace the USB cable
6. Replace the Interconnect PCA, see Interconnect PCA on page 315.
7. Replace the Engine PCA see EE Box on page 281
8. If the error continues, replace the Touch Control Panel
Jan 15, 2014 | HEWLETT-PACKARD T790 InkJet Plotter...
Init unable 51
The message means that there is something stuck inside the printer. Open it and look for staples, paper clips, torn pieces of paper, etc.
Hope this helps. Please rate this response.
Randy
Oct 10, 2012 | Brother DCP 130C All-In-One InkJet Printer
Can't access system settings on Canon imagerunner 400s
Turn off the main power switch, and
disconnect the power cord.
Remove the copyboard glass; then,
remove the screw, and detach the small
cover from the IP cover.
remove the remove all eprom dccon ram
& insert again & start the machine.
Jul 29, 2009 | Canon imageRUNNER 400S Copier
Error code 001. On/off switch trips off after 10 seconds
when you open the front door you,ll find under the disply a smal hole put eny nail in it a doller sign will apeer in the upper left corner of the disply pres
star , 4,star you will see another disply press the right arrow till you find error word press on it and then press star (astresk. the disply will turn off and on again theis error might be from the heater lamp if
it comes again change the hamps
May 08, 2009 | Canon NP 6545 Copier
49.FF95 SERVICE ERROR
Please look on: http://www.fixyourownprinter.com/
There are much solutions of this problem listed ...
For example this (it see good):
http://www.fixyourownprinter.com/forums/printer/46157#1
HP Laser Jet 4250n by TLYNN (3/20/07 12:22 PM) reply + / -
Anybody know the error code "49. FF95 Service Error"
We can't get around this...
Firmware Error 49 by Stephen (edited 3/20/07 12:29 PM) reply + / -
It could be a bad job.
First disconnect it from your network and any PC it might be attached to.
Power cycle it, then if it goes to ready status try the built in test pages, do they work?
If the printer will go to ready status and you have a parallel cable with the proper connector, then you can try upgrading the firmware from a PC, you can also try to upgrade the firmware over the network.
More reading:
http://www.fixyourownprinter.com/search/forums?f=&q=49+4250
Re: HP Laser Jet 4250n by TLYNN (3/20/07 12:59 PM) reply + / -
Still won't go back to ready status. Turns on to the same error code....
Cold Reset HP Laser Jet 4250n by Stephen (3/20/07 1:03 PM) reply + / -
Try a cold reset, it will reset the JetDirect settings, but it's the next step.
Cold Reset:
Power off printer, wait about 5 seconds, then power it on, when asterisks start appearing on the display press and hold the check mark until all 3 lights come on solid, then use arrow keys to find cold reset and push check mark to perform the reset.
Re: HP Laser Jet 4250n by TLYNN (3/20/07 1:06 PM) reply + / -
Thank You so much for your help... but that didn't work either. Same error code showed up.
Re: HP Laser Jet 4250n by Stephen (edited 3/20/07 2:27 PM) reply + / -
Then you probably need to replace the formatter.
Do you have another printer you can swap parts with?
There is a slim chance the memory DIMM is bad, you can try it with the DIMM removed, if there is more than one DIMM you can try installing just one and then the other.
A 49 error indicates that the formatter could not understand or execute an instruction within a file or cannot interface with an accessory, DIMM, or EIO device. Troubleshooting 49 errors is done through process of elimination. First determine if the printer functions in a stand-alone mode then test communications to the printer.
These errors can be divided up into two categories; the associated troubleshooting depends on the circumstance the 49 errors are occurring.
A 49 error is always followed by Hexadecimal numbers, for instance, 49.00FF. The Hex code is a memory address. Most Hex codes are not documented.
Re: HP Laser Jet 4250n by dmzcompute (3/20/07 2:26 PM) reply + / -
I do not see anywhere where the printer has been disconected from everything. If you have not done so already disconnect every cable from the printer with the exception of the power cable and turn the printer back on and see if you get the error and if not report back here for further instructions.
Re: HP Laser Jet 4250n by Stephen (3/20/07 3:28 PM) reply + / -
You might also try disabling the embedded JetDirect.
To disable the embedded LAN port
Turn the printer power off.
Power on the printer and watch for the memory count to begin.
Hold down the SELECT (Checkmark) button, when you see the memory count begin.
Continue holding down the SELECT (Checkmark) button until all three printer control-panel lights flash once and then remain on. This might take up to 10 seconds.
After the message SELECT LANGUAGE appears on the display, press the UP ARROW button or the DOWN ARROW button until EMBEDDED LAN DISABLED appears on the display
Press the SELECT (Checkmark) button. The printer then continues its power-on sequence with the embedded LAN disabled.
If this works the JetDirect built into the formatter is bad, you can either replace the formatter, or buy an JetDirect to install in an EIO slot.
Re: HP Laser Jet 4250n by Trev Pearson (3/20/07 10:08 PM) reply + / -
The only other thing to try, before spending money, is to get the network administrator to clear the print queue for that particular printer and then turn it on.
The theory being that a 'corrupt' print job is still in the system and as soon as the printer is turned on, that 'corruption' floods the network card with garbage which promptly goes 49.
If the printer comes 'ready', great. Then do a firmware upgrade. If not, then you will have to spend money on a new formatter.
Regards
Trev
Re: HP Laser Jet 4250n by roadrunner178 (6/21/07 2:09 AM) reply + / -
hi.
With a cold reset ,my problem solved.
try this as a first solution.
thank you
Re: HP Laser Jet 4250n by Anonymous (7/31/07 1:20 AM) reply + / -
THANK YOU WERY MUCH
FROM TURKEY
ZAFER
Jan 02, 2009 | HP LaserJet 2420dn Printer
Boot password
how to fix printer hp photosmart c5180 has system error 0xc18a0107 help me please
Jun 24, 2008 | HP Photosmart C5180 All-In-One InkJet...
Pixma mp150
when i get copy or print the appear on disply error #2 pls helpe me 2 find solution. error service 5100. For my mp 160 printer
Dec 12, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Epson DFX-9000 Matrix Printer Logo
194 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
