Question about Video Game Consoles & Games
My xbox 360 is not playing my games. it said to clean it and re-start the game. i then put several other games, new and old it didn't read them either. i disconnected the cables, i let it cool off, but it didn't work. my xbox sounds that the driver is not recognizing the disc. it can play music cd's but my dvd movies where choppy and i couldn't veiw those either.
    Problem Solver:
  • 15 Answers
When this starts happening, it appears that you have a problem with the DVD player. You could try to buy a DVD lens cleaner (it looks like a CD with a little brush on it), but I suspect you may ahve to take it to an authorised service technician to get the DVD unit replaced.
Posted on Apr 14, 2008
Bought an Original XBox used. Worked great for about 2 days--played KOTOR 1. On the 3rd day, it froze and read that there was a problem reading the disc. Annoyed that the XBox: -originally played...
Unfortunately this is high likely a disc player issue and it will be cheaper for you to purchase a new (old) system then it would be for you to go through the hassle of repair.
As you have already specified you are aware of the pot tweaking and that is the route that might lead you to a solution if you are to try and do it yourself. Another option though also costing money is to purchase just the disc player from ebay and change it out completely. Again, I find Xbox 360 cheap enough at pawn shops or yard sales that you could easliy find a cheap one.
I have given all my original xbox systems to family members already otherwise I would have gaven you one of mind.
Good luck.
Aug 01, 2011 | Video Game Consoles & Games
My xbox 360, has a problem i put in a new clean disk(game) into the xbox . it is a xbox 360 game and every time i put in a new clean disk the xbox says (open tray)
The XBox 360 is a wonderful video game console, however, with heavy usage, the laser (and/or other components in the drive) will eventually burn out.
The first signs of the laser starting to burn out is that your game will start freezing during game play. Eventually the games will stop reading altogether and you will get an "OPEN TRAY" message when you put a disc in and close the tray. What this means is that the XBox 360 thinks that there is no disc in the system.
If you click into the following U.S. based website, you can find more information about this issue, the parts to fix it yourself and you can also send your XBox 360 to them to have it repaired:
http://store.richspsxparts.com/howtofixxb36.html
Jun 21, 2011 | Microsoft Xbox 360 Console
My xbox 360 is not playing xbox 360 games but reads dvds and cds.
Is it a new or old xbox? and have you tried cleaning it with one of those dvd disk cleaners that cleans the lens sounds retarded but my old xbox was the same issue i ran that dvd cleaner through and the games worked again
May 20, 2011 | Video Game Consoles & Games
Xbox 360 won't play new game - screen flickering on the 'press start' screen. plays cd's perfectly and was ok with games till put in new game from Morrisons.
old or new generation model? it might just need a good cleaning with one of those dvd cleaner cds you can buy. I have a game in general "home front" that sounds like my box is gonna blast off.
May 08, 2011 | Microsoft Xbox 360 Console
Hi, I had a problem with my xbox, it wouldn't play games. I bought a new drive, I have a benq. I fitted the old mother board into the new drive but it would still not play. I then fitted the new mother...
Your Xbox 360 lens are most likely dirty. And your 360 probably has something like dust stopping it from scanning your games. I suggest blowing into your DVD drive carefully and gently. If it still doesn't work I recommend sending your Xbox 360 back to Microsoft for a new one if your under warranty. If you don't have a warranty you could clean you lens by your self. But opening your 360 to clean the lens could make it worse so do it at your own risk.
Apr 15, 2010 | Microsoft Xbox 360 Console
Games wont play. Problems with Disk player
If you don't have the tools to open your 360 go to best buy or an office supply store and get a can of compressed air and blow the dust out of the dvd drive. If that doesn't work then the lens needs to be cleaned with a q-tip and alcohol. This has worked for me on numerous occasions.
Jun 01, 2009 | Microsoft Xbox 360 Console
Xbox 360 Pro : To Play This Disk Error
Unfortunately , a new xbox360 game cant be played in a normal xbox (not xbox 360)
The problem is that the new xbox is way different on the inside than the original xbox is. Because it is way more powerful, you can put an old xbox game into a 360, and it will work fine (most of the time), but if you try the reverse there is no way to make it work.
May 13, 2009 | Microsoft Xbox 360 Pro System Console
Won't read disc
sounds like the laser's stuffed. the lasers in those machines are notoriously bad. you'd best be careful. a dodgy laser will cause laser-burn to the discs. i had the same thing on my machine. i could play a couple of games, then there was some that would work after i took them out and put them in, several times. after fixing the laser, ive not had the problem again.
Mar 30, 2009 | Microsoft Xbox 360 Console
Not reading cds.
Now.. if it's four red rings, check your component cables, unplug them, then plug them back in, if it's only three lights flashing with the top-right quadrant remaining idle, then there is a problem with your hard drive and you have to send it in for repairs.. but as far as the fact that it won't play any games, try to get a disc that will clean the eye of the console something like "Maxell" player cleaner, that usually works.. if that doesn't help.. sorry
Jun 08, 2008 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
46 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
