Question about Smith Corona Wordsmith 100 Typewriter
Circuit Diagram etc: for Spellmate 5F-6
The unit suddenly died on me. Power supply is ok getting 18v at link, ocassionly LCD goes dark or flashes with dark lines, get the odd click from carriage mechanism and light in Caps lock key flashes and that's about it.
    Sergeant:
  • 329 Answers
I have a person that does board repairs for SCM let me know if you need upstate0s@adelphia.net
Posted on Jun 12, 2008
POLAROID P40LCD12 SCREEN AT BOTTOM COMES ON BLUE FADES THEN GOES GREEN ABOUT 5 INCHES LOST ON BOTTOM TV WORKS OK BUT THE SCREENS STARTS BLUE ABOUT 5 INCHES FROM BOTTOM THAT FADES AND TOP HALF PIC OK BUT...
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
May 02, 2017 | Polaroid Televison & Video
Why does my TCL tv stay dimmed and very dark screen? I've reset it and everything?
Apr 30, 2017 | Televison & Video
2 red LED flash (power fault) on Sony Brava KDL 40v2000
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 29, 2016 | Televison & Video
Emerson TV wont stay on
you have to check the power supply of the tv. for the check the video to know how check the power supply of an lcd tv . if you need the circuit diagram of the power supply the link to it is also added
http://electro-medical.blogspot.in/2015/10/emerson-lc320em9-service-mode-how-to.html
Testing LCD TV Power Supply BoardsSTEP BY STEP
Nov 07, 2015 | Emerson LC320EM9 32 in. LCD HDTV
My tv flashed on and off and left with 6 blinking lights. Did a power reset and tv powers up with Sony on the screen then goes dark but the green light stays on. Screen is dark. Which panel is bad.
Probably the back light inverter is faulty . Before going to buy a new inverter board tey to check the power supply. Which the bellow added video to know how to check a power supply board. You have to check the 24V power sto the inverter board from the power supply. if its not there then the problem is with power board. If its ok then you have to go for a new inverter board. Also try to replace the electrolytic capacitors in the power supply board. some times bad electrolytic capacitors can lead to back light failure.
www.electro-medical.blogspot.com
Oct 31, 2015 | Sony Bravia Kdl-46bx450 46" Class 1080p...
Why does my Sony KDF E55A20 LCD projection television stopped. It flashes green 3 times at power up and then continuously flashes red in 6 flash intervals
The problem is sort of complex. This could be the main power supply, or the high voltage supply. There is also a chance there is a short on one of the boards and the main supply is tripping to protection.
This is not something you can fix at home. In consideration of the service cost, and most likely the circuit boards and many of the parts will no longer be available, you should consider a new set!
Jul 16, 2014 | Sony KDF-E55A20 55 in. LCD Television
KDL-40XBR4 bought 1/08. Turns on for 30 seconds with screen staying dark. Then it goes off automatically with the stand-by light blinking 5 times repeatedly. Took it to the shop and he said the LCD panel...
KDL- Bravia blink codes (Australian):
2 times-Main power supply voltage error (12V, etc)
3 times-Malfunction of 3.3V line
4 times-Malfunction of 5V line
(Voltage Supply to FE, etc)
5 times-Malfunction of power supply for screen
6 times-Malfunction of inverter or overcurrent, etc
7 times-Abnormal temperature inside unit
8 times-Audio circuit error (amplifier, etc.)
9 times-Fan malfunction
10 times- Digital FE circuit error
11 times-Malfunction of Trident IC or around IC
12 times-BH board error
13 times -Malfunction of balancer
If this is correct the 5 blinks is the power supply having problems, I would much rather change the PS than replace the screen. Also if screen is determine bad, look for class action lawsuit on Sony for defective screen, i am told they know all about this.
Mar 06, 2011 | Sony Televison & Video
My Acer AL2216W Black LCD Monitor all of a sudden is wavy & flickering!?!?!? Is there anything I can do about it?
Hello,i think your LCD monitor is faulty and you should consider replacement.but first take to a qualified service personnel.
Dec 22, 2010 | Acer AL2216W LCD Monitor
Smith Corona Wordsmith 100 Typewriter Logo
85 people viewed this question
Top Smith Corona Office Equipment & Supplies Experts
James Cagle
James Cagle
Hjalmer Lamminen
Hjalmer Lamminen
Jim Keysor
Are you a Smith Corona Office Equipment and Supply Expert? Answer questions, earn points and help others
