Question about Creda W120VW Front Load Washer
Problems with creda washing machine
I have a creda washing machine fills fine washes but just will not pick up any fast speed, so clothes are coming out soaking, i have checked belt to see if there is any give on the belt but all seems fine please help 3 kids one husband = lots of washing
  • 66 Answers
Try your carbon brushes and drop your sump ie the pipe that connects to the pump on the inside of the machine and goes to the bottom of the drum this is the sump that sometimes blocks or may be a weak pump but try the other 2 options first good luck dont forget to unplug
Posted on Jun 14, 2008
Kenmore 417.43142200 final spin is slow
obviously the timers contacts are bad so replace the timer.
May 16, 2017 | Kenmore 43142 Front Load Washer
The fast spin cycle on my creda 1000 will only spin slowly,leaving clothes wet,any thoughts
This machine has a variable spin-speed setting. You can set the spin-speed RPM (between OFF and 1200RPM) using the smaller dial located next to the main wash programme selector dial.
I hope I'm not stating the obvious, but appliance "faults" are often simple and don't require taking the machine apart or calling a service engineer. If you've already tried the above suggestion and your washing machine is still spinning slowly, please post back and I will try to assist you further.
Regards,
BElectric
Nov 27, 2010 | Creda W100FW Front Load Washer
Clothes are very wet after spin cycle This unit has several spin speed settings, machine does spin but not fast enough to remove water from clothes
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 16, 2010 | Kenmore Washing Machines
Creda Simplicity 1000 (w100fw) - Drum does not rotate
you could try fitting new motor brush kit it wears down after 4/5 years and need replaced....please leave feedback
Apr 08, 2010 | Creda W100FW Front Load Washer
Creda W220VW front loading washing machine leaking from bottom of casing. Hoses seem OK, coluld filter need cleaning? If so, how do I access?
Check water flow rate into soap drawer , if very fast water can overflow and run down back of fascia panel and out underneith
Nov 01, 2009 | Creda W120VW Front Load Washer
Creda Washing Machine Detergent Dispenser not emptying
does the detergent get wet?
may be the blue trap door that is behind the detergent in the drawer is set for liquid detergent ie 'closed' and needs to be set to open to allow the powder past. or the holes above the detergent section where the waster comes out are blocked so water goes in another route.
you could always put the powder straight in with the wash to get yourself out of trouble.
Feb 03, 2009 | Washing Machines
My creda iwd12 front load is not working
If the m/c completed the wash cycle, it may be that the clothes have not rinsed, or incorrect prog selected, or incorrect temp selected,
Check to see if the drum actually goes round with clothes in, as a worn or broken belt will obviously stop the clothes from being washed.
Plz rate my solution.
Thanks.
Dec 16, 2008 | Creda IWD12 Front Load Washer / Dryer
Creda machine won't agitate with clothes in it
Your load is prob to heavy for the older washer. it just doesnt have the power to handle it no more. time to replace it, sorry.
Jul 30, 2007 | Creda W120VW Front Load Washer
Freezer before Rinse
you hav'nt said if it drains. the problem just may be that you have plumbed drain hose onto a spigot on the sink drain and spigot is blanked off
Apr 24, 2007 | Creda W120VW Front Load Washer
Creda W120VW Front Load Washer Logo
144 people viewed this question
Top Creda Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you a Creda Washing Machine Expert? Answer questions, earn points and help others
