Question about HP OfficeJet 4255 All-In-One InkJet Printer
File ansd print server
Print server will not print, I have tried net stop spooler
net start spooler.
error message
server properties canot be viewed.
  • Roscoeboff Apr 18, 2008
    When I try to print an Excel document from my iMac, the print dialogue runs and then the printer shows as stopped in the print utility. When I click start jobs it begins spooling for a while then stops. I replaced an empty ink cartridge which I think triggered the problem initially. I then deleted the printer and preferences, restarted and the printed worked with text edit but not my Excel document.
  • 47 Answers
Check out this link:
http://forums.techarena.in/showthread.php?t=25716
it should solve your problem.
Let me know what happens.
Posted on Apr 14, 2008
Z615 Error message,Printing Failure,current print job canceled,print status 15% completed,shows cartridge info.Power light blinks on-off,have reinstalled driver,rebooted windows. Widows XP
It could be the Print Spooler service on your computer. Make sure the service is running. - Browse to Start -> Run... and type in "NET STOP SPOOLER" (this will stop the print spooler service)
- type in "NET START SPOOLER" (this will restart the print spooler service)
Try to print again.
May 24, 2011 | Lexmark Z615 InkJet Printer
Tip
HOW TO CHECK AND FIX PRINT SPOOLER SERVICE THAT CAUSES UNABLE TO PRINT FILE...
Print spooler service is a computer service that loads the print jobs into the printer memory for later printing and it acts as intermediary between a computer and a printer. When the print spooler service is stopped or malfunction, printing is not possible.
Here are the possible reasons :
1. Virus or Malware infection.
2. Spooler service was stop by accident or turn off to manual/disable mode.
3.Faulty installed printer driver that contains error or incompatible with previous printer drivers installed in your computer or system.
4. Print jobs and drawing jobs were corrupted by accident which caused print que lock and resulting print spooler service to crash.
5. Your printer had printing problem issue with pdf files.
To fix this problem, you have to check if the print spooler service had stop.
Here's how to check and fix the print spooler service.
Go to START
Choose RUN
Type SERVICES.MSC
Click on PRINT SPOOLER and check if the STATUS IS STARTED
If not, on the upper left side, click on STOP to stop the spooler service
Then click on RESTART to restart the spooler
Restart your printer and your computer
Then try to print again and it will surely solve your printing problem.
Another procedure :
Go to START
Right click on DOS command prompt and run as administrator
You should be in this command directory before you
Type CMD and be sure you are in this directory C:Windows\System32
And if not, type this to change the directory, CHDIR C:Windows\System32
Type NET STOP SPOOLER and message will appear like this
Exit and go to C: DRIVE
Choose WINDOWS and click show content if not view all the folder files
Choose SYSTEM32
Choose SPOOL
Choose printer and delete printing jobs if any
Again right click on Command prompts and run as administrator
Type NET START SPOOLER
Exit and restart your printer and your computer
I will works fine right now.
NOTE : You can bypass the C:Drive procedure and just type NET STOP SPOOLER AND NET START SPOOLER in the DOS COMMAND PROMPT if you believe that there are no printing jobs pending.
Another procedure is to download this troubleshooting software and follows the troubleshooter wizard and it will fix your print spooler service automatically and some common problems as well.
Click here to start downloading.
I hope it helps you solving your print spooler problem. Regards to all readers.
on Mar 24, 2011 | Office Equipment & Supplies
On command to print with my epson lx-300+, message reads, "No Printer". When searched on fax and printer and double-clicked "Add Printer", a message came out saying, "It can't...
Hi Basti here,
Try this...
If you are receiving SPOOL.SVC or PRINT SPOOLER ERRORS when trying to uninstall/reinstall your printer, or when trying to print a document or access the printer properties, please follow the steps below.
The following are examples of some of the messages you may be receiving:
Spool.svc is not running. Make the service active and try again.
Printer Properties cannot be displayed. The print spooler service is not running.
Printer cannot be removed. The print spooler service is not running.
Windows cannot print due to a problem with the current printer setup.
(When clicking Add Printer) Operation could not be completed.
NOTE: Only these types of errors warrant the troubleshooting steps clearly defined below.
Resolution:
SPOOL.SVC is an operating system function which carries files through the operating system for printing. It must be STARTED (active) to be able to print or access any printer's functions. This file usually starts automatically with Windows, however operating system issues may cause it to become stopped. You cannot uninstall or reinstall a driver while this service is stopped.
Please try the following to start the service again:
1) Click on START, right click MY COMPUTER, left click MANAGE.
2) On the left column, double-left click SERVICES AND APPLICATIONS, then click SERVICES.
3) Locate and highlight the PRINT SPOOLER on the list of Services.
4) Click START THE SERVICE.
If errors occur and the service cannot be started, there is another issue within the operating system itself.
May 23, 2011 | Epson LX-300 Matrix Printer
When I press print I get the following message: "The Lexmark 2600 series is currently busy. Your print request will begin as soon as current processing is complete". Nothing prints. The...
There could be some print jobs stuck in the print queue. Try to clear the print queue first before sending a new print job. Follow these steps: - Browse to Start -> Run... and type in "NET STOP SPOOLER" (this will stop the print spooler service)
- Browse to your windows\system32\spool\PRINTERS\ folder - You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files. - Browse to Start -> Run... and type in "NET START SPOOLER" (this will restart the print spooler service) - Double click the printer icon in the lower-right corner of your taskbar to examine your print job queue and browse to View -> Refresh.
Try to print again.
Apr 25, 2011 | Lexmark X2650 All-In-One InkJet Printer
Printer spooler
Resolution:
Mar 13, 2011 | Canon Office Equipment & Supplies
My HP Photosmart C4280 all in one printer will not print...can you help?
Do/did you get any error messages?
Check that the printer is online and check the printer queue (Devices and Printers in Win7). Try a new USB cable and plugging the printer into a different port. If you have a print server or USB hub, try connecting directly to the computer.
Reset the printer by unplugging it and the USB cable. (If files are built up in the queue and the printer is online, try deleting them. If they don't delete, you need to stop and restart the printer spooler. In any version of Windows from a command prompt window, type "net stop spooler" without the quotes and hit <enter>. On the next line type "net start spooler" again without the quotes and <enter>. Restart the computer.)
Other issues are possible if there are any error messages that you don't mention.
I hope this helps.
Apr 12, 2010 | HP PhotoSmart C4280 Laser Printer
Print Spooler has stopped.RPC server unavailable
I can definitly help you out....it may take a few steps to narrow down this issue..so don't get frustrated! :-)
First lets start off by trying this:
Go to System Properties>Advanced
Select Performance>Settings
Select Data Execution Prevention
Select Turn on DEP for all programs and services except those I select
Click Add
Paste this in to the file name box of the window that opens:
C:\WINDOWS\system32\spoolsv.exe
Select Open
Select OK when you receive the warning
Select Apply
After doing that , follow my steps again for enabling the print spooler , let me know how that works
Oct 06, 2008 | Canon PIXMA MX310 All-In-One Printer
Printer does not respond, and we restarted it and it still does the same thing
Whats the brand and make of the printer and are there any error lights being displayed ?
also try this solution it may solve your problem:
Click start > click run
in the Run window type cmd
hit enter
now a black DOS window will appear
now type
net stop spooler
wait 10 seconds
now type
net start spooler
it should look like this :
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\NCR>net spool stop
The syntax of this command is:
NET [ ACCOUNTS | COMPUTER | CONFIG | CONTINUE | FILE | GROUP | HELP |
HELPMSG | LOCALGROUP | NAME | PAUSE | PRINT | SEND | SESSION |
SHARE | START | STATISTICS | STOP | TIME | USE | USER | VIEW ]
C:\Documents and Settings\NCR>print spool stop
Can't find file spool
Can't find file stop
C:\Documents and Settings\NCR>net print spool stop
NET PRINT
\\computername\sharename
[\\computername] job# [/HOLD | /RELEASE | /DELETE]
C:\Documents and Settings\NCR>net stop spooler
The Print Spooler service was stopped successfully.
C:\Documents and Settings\NCR>net start spooler
The Print Spooler service is starting.
The Print Spooler service was started successfully.
Anymore information would be great
Thanks
Aug 18, 2008 | Office Equipment & Supplies
HP print spooler problem and error 1068. Want my printer back!!!
Just go to your Server or Desktop PC and enable the RPC service (Remote Procedure Call)
Right click in "My computer" icon, from the manu select "Manage" then go to "Services and Applications" and expand that, after that select "Services" you will find that services in the right pane, just click in "Start"
I hope this work for you, good luck!!!!
Jul 28, 2008 | HP LaserJet 1022 Printer
Net work printing
my apologies on the typo in the net commands
Should be...
net stop spooler
net start spooler
Apr 14, 2008 | Computers & Internet
HP OfficeJet 4255 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
