Question about Dryers
Dryer cutting main power off after acouple of seconds
As soon as i turn my drier on its cuts my main power off, it has a fault , i have checked the plug and that looks fine . please help , thanks clare
it is a hotpoint aquarius ctd00 dryer condenser
My condenser tumble dryer cuts my electric as soon as I press the on switch. I have also noticed a smouldering smell and a sparking coming from the back of the machine. Obviously it is not safe to use, any ideas on what is causing this?
Thanks.
  • 66 Answers
You need to ck the back off the dryer and open the small cover wher the elet cord is ateched . it may bo loose or need to replace the block.
Posted on Apr 14, 2008
Lg dryer dle7177 cutting off during cycle
I had a tumble dryer that stopped working and after much investigation it turned out to be an internal thermostatic switch and lots of fluff around the internal filters. ( Mine had 2 of them 1 would cut the heat and kick back in when the temperature dropped and the other one would completely cut all power rendering the drier non usable until cicuit breaker thermostat was replaced. The reason they cut out is to prevent overheating and possible fire. When the thermostat gets to certain temperature it breaks the circuit. Apparently you shouldn't stop the drier until it has completely cooled down as there will be too much heat which could cause a fire, which is why most drier cycles have 10 minutes of cool/ non heated air at the end. So in conclusion I would take all the filters out and give them a good clean and try to avoid opening the door while there is still a lot of heat in the drier. I'm not sure if this will help but its a starting point.
Feb 03, 2013 | Dryers
Have power everywhere but won't turn on
see this causes and fix it. God bless you
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.Thermal Fuse The thermal fuse helps to prevent a dryer fire by shutting off power to the dryer if it overheats. If the dryer won't start check this fuse first. Test the thermal fuse with an ohm meter or continuity checker. This is the most common part to fail when the dryer won't start. Once the thermal fuse has blown, it has to be replaced. It can not be reset.
Thermal Cut Out Fuse Kit Most dryers have several temperature control devices such as a thermal fuse, thermal cut out, high limit fuse or high limit thermostat. Some manufacturers sell the thermal fuse and thermal cut out in a kit. These kits normally solve no-heat problems rather than when the dryer won't start. However, in some models, this kit will solve both problems. Even though this is not the most common part to fail if the dryer won't start, both can be checked using an ohm meter or continuity checker. If they have continuity they are good. If not, they should be replaced.
Main Control Board The main control board is normally not at fault when the dryer won't start. First, check all of the other components in this troubleshooting guide before replacing the main control board. The main control board can not be tested and must be replaced if it is defective. If there are obvious signs of burning or a shorted out component on the board, it should be replaced.
Timer The timer is normally not at fault when the dryer won't start. In many situations where timers are replaced they end up being returned. First, check all of the more common components in this troubleshooting guide before replacing the timer. If the dryer won't start, the cause is much more likely to be a thermal fuse or switch. The timer can not be tested, it must be replaced if it is defective.
Oct 02, 2012 | Dryers
Bought a drier from the us. have problem using it
Is the house wiring capable of handling the amp load from the dryer atleast 30 amps would be required to run the dryer.
Jan 16, 2010 | Dryers
Tumble drier tumbles but no heat its an Indesit...is it the thermostat
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
Nov 02, 2009 | Tricity Bendix TM310W Electric Dryer
I have a Whirlpool Dryer Model number GEX9868JQ0 and it will run however; it is not blowing hot air? How do we remove the kickplate (front or back) to check out what is wrong? Please advise.
A typical problem that causes tumble dryers to stop heating up is the thermal overload cut-out devices. These are safety devices, and are some times "single-shot". That is, if they operate, and shut off the heating element, then they need to be replaced, usually as a pair along with the thermostat (they look very similar). The other common fault is that the heating element fails. However, if the thermal cut-out was the problem, LOOK FOR A CAUSE. If it is a condenser drier, check the condenser box is not clogged with lint/fluff
Oct 30, 2009 | Whirlpool GGQ8831L Gas Dryer
The tumble dryer tumbles but I have no heat and the filter light
Since the heating element is not heating up when powered up you must have a bad heating element.
Oct 06, 2009 | Candy CDC266 Dryer
Mower runs for only 15 to 20 seconds then cuts out will restart first pull after acouple of minutes then cuts out again etc.
check fuel flow to engine. check spark plug. check oil. check air flow to engine.
replace air filter.
Aug 06, 2009 | Garden
your heating element is the most likely cause of this. will need replacing
Nov 18, 2007 | Hotpoint TDC32 Electric Dryer
Dryers Logo
314 people viewed this question
Top Dryers Experts
