Question about Sony Ericsson W850i Cellular Phone
W850i problem "memory stick not inserted"
Hi! my w850i does not read memory sticks any more although i have checked various MS and they all work fine on my reader, a w810i, and another w850i.
sometimes when i reboot my phone, it would ask to format the MS but then it fails. i recently updated the phone using the update service of SE. but i am not sure if the problems started with the update. everything else works fine.
do u think the internal reader hardware/software of the phone could be damaged?
how can this be fixed?
thanks a lot for any post.
  • Anonymous Jun 18, 2008
    When turning the phone on it says it is going to format the MS and I can't see any of my files.
Muztha///////////
Posted on Apr 14, 2008
How do i format my sony ericsson w850i?
go to settings -> master reset -> reset all
it will erase all data except contacts and msgs
to format mamory card go to file manager and then go to memory stick section
go to more menu
go to memory status
select memory stick
select more menu
select format M.S.
you can delete msgs manually by going to inbox and selecting delete all msgs from more menu.
Mar 01, 2011 | Sony Ericsson W850i Cellular Phone
My w850i can't read memory card
to make sure the problem please insert ur mem stick to external card reader, if it can read ur mem stick so ur phone card reader had a problem and i think its hardware problem, but sometimes when system files(hidden files) in the mem stick is missing can make the same problem, so u better insert ur memstick to the same device that worked to really make sure the problem is (ur memstick or ur phone card reader), and u also can try to insert the memstick from that worked device to ur phone (just make sure problem solution) :)
Apr 01, 2009 | Sony Ericsson W850i Cellular Phone
I have problem with my memory stick in w850
It should be a problem with your memory card slot in your phone. It could solved by dusting the inside of your memory card slot.
After trying this, please reply whether it worked.
Thank You
Nov 15, 2008 | Sony Ericsson W850i Cellular Phone
W850i java not working
hi sir
remove the memory card and try. phone application will run.
if it run's then insert the memory card if the same problem continue's memory card may be corrupted.. try to format it and use.thank's sir..
Sep 03, 2008 | Sony Ericsson W850i Cellular Phone
Cant save Photo in Memory Stick
Easy one! Turn on camera function, select settings, using the very small illuminated dots, scroll through past turn on light etc( in yellow function bar at lower part of screen) till you come across "save to" then select,
Hope this helps.
Jun 29, 2008 | Sony Ericsson W850i Cellular Phone
W850i memory stick
I had the same problem, I realised I must have got it wet from the above comments.
I basically took the card out and blew very hard into the socket in an attempt to dry it. I put the card in and it worked fine!
I hope this has helped, sorry if it doesn't.
Jan 19, 2008 | Sony Ericsson W850i Cellular Phone
Playback failed!
the problem is that file the file is currupt buddy
Nov 28, 2007 | Sony Ericsson W850i Cellular Phone
I can't get into my apps and games on my w850i.
Try Fomating your memory card. but if you have pictures music or video remember to trasfer them to your computer first! after that fomat it.
you can do that by..
On you fone go into FILE MANAGER
then CLICK MORE
then MEMORY STATUES
then MEMORY STICK
then CLICK MORE
and FOMATE M.S
and it should work.
remember to transfer all your files to your computer or it would be all gone when u fomat it!.
Nov 17, 2007 | Sony Ericsson W850i Cellular Phone
Suspected virus
you have positive doomboot virus! do not turn on the phone!!! reformat your phone asap before the virus damaging the CPU IC.
Sep 28, 2007 | Sony Ericsson W850i Cellular Phone
Problem
mine did this, remove memory stick, blow out any dust or bits, turn off, replace mem stick and turn on
Sep 06, 2007 | Sony Ericsson W850i Cellular Phone
Sony Ericsson W850i Cellular Phone Logo
160 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
