Question about Cameras
Sanyo vpc 5500 camera when you use zoom it turns camera ff has a red error
  • tom0601 Aug 12, 2008
    when camera is on and you go to zoom in closer the camera automatically
    will cut it's self, how do you correct this problem?
SOURCE: sanyo vpc-e760 camera lens error 41
Mine says Lens error 22 or I get a bunch of Dim lines across my screen It cost me $135 for this camera and it was my first!
Posted on Jul 28, 2008
SOURCE: Help!! Sanyo VPC-E760 Digital Camera driver for Mac OSX
the driver is not separately available for Sanyo VPC-E760
Posted on Aug 06, 2008
SOURCE: my sanyo camera is not working
Well maybe I can solve this..... My lens would not retract and showed two error messages. Tried a number of tricks that have been recommended on this site to no avail. Ultimately what worked for me was pushing quite hard on the barrel of the lens trying to force it back in ( yeah i know, sounds extreme but did'n't think it could make the situation any worse ). The lens remained in the locked out position not moving in spite of the fact that I pushed it fairly hard. When I turned it on the lens retracted and it appears to be fully recovered from whatever was ailing it. Hope this works for you.
Posted on Mar 12, 2009
  • 11967 Answers
SOURCE: lens error 0x03110000 in sanyo vpc e1292
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Apr 23, 2010
  • 11967 Answers
SOURCE: Purchased a Sanyo VPC-E1500TP ditigal camera while
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Posted on Oct 12, 2010
Auto focus or any focus not working on Xacti VPC-CG20
Hello
See SM for Your cameras - http://elektrotanya.com/?q=showresult&what=sanyo%20VPC-CG20&kategoria=&kat2=all
You have problem in Zoom:
1. Focus motor
2. Focus drive mechanism
If You not work with repair cameras - not touch
And - not remove the matrix from the lens - you will lose all focus adjustment.
Oct 29, 2013 | Sanyo Xacti VPC-CG20 Dual Camera Full HD -...
Sanyo VPC-5500 says "card locked"
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Oct 28, 2010 | Sanyo VPC-S500 Digital Camera
How can i get a hold of a users manual for a sanyo digital camera i got as a gift? sanyo vpc 5500 5.0 megapixel.
Google sanyo vpc 5500 manual . And look for free down load manual . It could be up to 100 pgs even more . So be prepared to print alot . Maybe do it at work lol so you dont run out of ink .
Aug 18, 2009 | Cameras
Is there any free software I can download to retrieve photos on the sanyo VPC 5500 no memory card"
Sadly not, when you format the card or memory, it wipes it clean off the system. Unlike Hard Drives, there is no magnetic trace from which you could reconstruct the data. Sorry it's not good news :(
Mar 05, 2009 | Sanyo VPC-S500 Digital Camera
Error 2111 on camera VPC-S750 when i try to zoom in it says lens error 2111 and shuts off. the lens does not close when i turn my camera off.
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Sep 07, 2008 | Sanyo Xacti VPC-S60 Digital Camera
The sound with the sanyo(vpc-5500) digital camera
I thought my pink sanyo VPC-5500 was messed up, but once I imported my pictures and viceos onto my computer, I opened up a vidoe player and the sound worked perfectly. So if you have the USB cable, hook your gigtal camera up to your computer and import what's on it, then you will be able to open up a video player and watch a video that was stored on it.
Apr 13, 2008 | Olympus Stylus 790SW Digital Camera
Sanyo vpc-e760 camera lens error 41
dudeee. totally have the same problem cept mine stays fully zoomed then when i try to zoom more it says lens error 41 and turns off and the lens doesnt go in
Mar 04, 2008 | Cameras
Cameras Logo
48 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
