Question about ASUS K8N-LR Motherboard
Asus K8N-LR power problem
Can someone help me!! When i turn the computer on at the wall the computer turns on, without touching the power button on the case!i have checked to make sure the micro switch isn't stuck in the on position and also if there is any scheduled tasks that turn it on and nothing! it still turns itself on! help please
  • Savage1042 May 13, 2008
    thanks for the heads up, ill try a new one!
  • 101 Answers
This is a problem within your ATX power supply . Better to get it repaired or replaced , otherwise each switch-on surge would damage your comp components eventually .
Posted on May 13, 2008
Hi,when turn on the pc stops immediately and the restart button is red and the power button is off
FIRST RE-WIRING ALL AND CHECK SO THEY ARE NO LOOSE
WIRES.IF IT NOT HELP TRY WITH A OTHER PSU.
Aug 31, 2013 | ASUS K8N-VM Motherboard
What is wrong if I get two beeps on my asus motherboard
2 short beeps Post Error ,review screen for error code
if you want to know what this is the error code is related to
click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occurred
or click start type in event viewer press ENTER
you might be able work your way through the problem
if you need more help with this post a reply with the error message details
hope it helps
Oct 13, 2012 | ASUS K8N-LR Motherboard
System not booting, k8n
Have you tried resetting the bios? turn off the computer and remove the power cable connected to the power ATX power supply, look for the "clr_cmos" jumper and change the settings from 1-2 to 2-3 for approx. 10 secs, then return the jumpers to original settings and reconnnect the power cable and turn on the computer. This was the solution when i had the same problem before. Hope this helps you too.
Oct 01, 2009 | ASUS K8N-E Motherboard
Problem
Hello nikunj_bhatt:
I know that you have a hard time with English.
But to get your idea and problem we need to clearly understand what you are doing and how. Have someone to help you with this English.
I will attempt to help.
Make absolutely sure you have the correct bios set up for this mother board.
If you put in the wrong bios recovery, then the problems cannot be corrected and may render the mother board useless.
However, if it was the correct one, then it seems that this needs to be done again. Make sure you have read the instructions which comes with the data bios set up disk and program.
Thanks,
Hope this helps.
Sep 02, 2008 | ASUS K8N-VM Motherboard
I F disced my computer recently and now am trying to set it up again. Where can i find drivers to install my ASUS k8n-e socket 754 motherboard online?
Try this download site:
http://drivers.softpedia.com/get/BIOS/Asus/Asus-K8N-E-Bios-0411.shtml
click on the download button, select one of the "external mirror" links, and it should begin to download the driver for it.
Aug 08, 2008 | Computers & Internet
K8n-lr motherboard
1 long beep and 2 shorts beeps indicates a problem with your RAM. If you have more than one RAM chip, remove one of them to rule out a faulty chip. If you only have one chip, remove and reseat it. For clarity, you can find the manual for your board at; http://support.asus.com/download/download.aspx?SLanguage=en-us&model=K8N-LR And the Asus general motherboard troubleshooting manual at; http://support.asus.com/images/document/ts/E2437_MB.zip
May 30, 2008 | ASUS K8N-LR Motherboard
ASUS k8N motherboard major error
try to go to Bios setup and select the default settings and restart your unit. after you restart tell me what happen.
Mar 30, 2008 | ASUS K8N Motherboard
ASUS K8N-VM mother board win98 drives
Try going to the Asus website and look for support for your MB drivers and Operating System.
If there is no longer any Win98 support for your MB then I suggest a fresh computer and more recent software for less hassle!
A ten year old OS indicates to me that you might be stuck until you go with the flow!
Cruel but true.
Hopefully the recent cheap prices for computers pre-installed with Vista or XP will persuade you.
Feb 06, 2008 | ASUS K8N-VM Motherboard
ASUS K8N-LR Motherboard Logo
88 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
