Question about Refrigerators
Have an Engel portable fridge. When I plug it in it turns on and sounds like it is working properly but I doesn't cool at all. What is this most likely to be?
  • 66 Answers
SOURCE: 35 litre Engel. Not getting cold.
can you feel if the fan is blowing air
Posted on Jan 22, 2008
  • 403 Answers
SOURCE: fridge side wont cool properly.
Check out this link below for a PDF manual on your item. Great information to have. Just copy and paste into your browser.
http://www.samsung.com/us/function/search/espsearchResult.do?keywords=RS2630SH&input_keyword=RS2630SH
Try this:
Temperature Adjustment
• After 24 hours, adjust the controls as needed. Adjust temperature gradually: push the button in small increments,
allowing the temperature to stabilize.
• Press the button(Freezer Temp or Fridge Temp) repeatedly until the desired set temper.
• For lower temperature, press the button(Freezer Temp or Fridge Temp) towards coldest.
• For higher temperature, press the button(Freezer Temp or Fridge Temp) towards cold.
If this does not work for you let me know or you can contact Samsung support at 1-800-SAMSUNG (1-800-726-7864) Mon - Sun : 9am - 9pm (EST).
Or you can try this Live chat at this link below, just look to the middle left of their page for live chat:
http://www.samsung.com/us/info/contactus.html
Let me know how this works for you or if I can help you with anything else.
JimmyC
Posted on Oct 06, 2009
  • 4793 Answers
SOURCE: engel 43 qt fridge freezer stopped cooling.
have you checked the compressorpump is getting warm(a sure sign its working.sometimes a little tap works)
Posted on Feb 11, 2010
  • 35 Answers
SOURCE: fridge section not cooling properly
your evaporator iced up, defrost it, leave it off for 24 hours.Check defrost heater,timer, and the fan motor.
Posted on Apr 07, 2010
Macmarkus
  • 2605 Answers
SOURCE: The freezer doesn't freeze and
Hello, welcome to FixYa.
I'll start by saying...that's a good start to diagnosis on your part, good job. Thank you for providing some back round. Unfortunately I have to follow that up with this...Those are all typically a good indicator of s system low on refrigerant...if the compressor is indeed operating. Are you able to confirm it is operating for sure ?
I usually find those unit's leaking right under where the defrost bi-metal is clipped onto the evaporator.
**Unplug the unit from the wall before proceeding to removing any panels...safety first**
If you remove the back evaporator cover inside the freezer to inspect the evaporator for a complete frost pattern (which is what I'd suggest if the compressor is indeed running), then also check the bi-metal (also known as a "dts" or defrost thermostat shown below) and inspect it closely for any sign of oil, that may pin-point the leak.
Let me know as much as you can in regards to my questions and I'll watch for your post to follow up from here. Please include if you can a confirmation it is a Frigidaire model FRT22TSE...Good luck.
Regards,
Macmarkus :)
Posted on Jul 12, 2011
Why does my engel MT45F-U1 fridge and freezer vibrate and make so much noise?
have u checked the groumets on the compressor? more than like are bad
Apr 20, 2015 | Engel Refrigerators
Fridge does not work on dc and does not show temperature readings
you should call the fixer immediately,it hamrmful to your freeze.
Feb 16, 2013 | Engel 40 Qt. Portable Fridge / Freezer
Long running periods with Engel B 12v fridge
the owners manual will tell you but yes most do
Apr 11, 2010 | Engel Freezer MT 27F-U1
My 39ltr Engel is only freezing on 1 side the other is only cool
This sounds like a water problem. Both sides should be at comparable temps. Is this a model with door instant ice/and/or icemaker?
Mar 09, 2010 | Engel Freezer 22 Qt. Fridge/Freezer
Engel 43 qt fridge freezer stopped cooling. the compressor comes on, the fan is blowing but not cooling
Feb 11, 2010 | Engel 43 Qt.Portable Freezer.
Hii have an indeset fridge freezer 2 year old freezer ok fridge not cooling
Usual problem, let it defrost properly, I mean 48 hours with doors open in warm room. It is most likely frozen up inside (its frost free! no?) inside is a different matter and they dont tell you that!
Mar 03, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
12v &240v connections on an ENGEL COOLER
AUTOMATIC AC/DC CHANGEOVER: All Engel Fridge Freezers can be plugged into both AC and DC at the same time. The Engel is smart enough to use the AC while available and then automatically switch to DC when the AC is no longer working. It will also sense the resumption of AC power and automatically switch back to AC making it ideal for high hurricane areas and places where power disruption is common.
Read more: http://www.roadtrucker.com/engel/engel-12-volt-fridge-freezer-technical.html#ixzz2MvRL2xrC
Mar 29, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Refrigerators Logo
29 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
