Question about Canon DC20 DVD Camcorder
Shut down i wrongly inserted a memory card while the unit is turn on. when i push the card to insert, the unit shut off and never turn on anymore.
  • slapshock Apr 21, 2008
    thanks boff1. but how can i try to use another memo card if my unit won't turn on. the power is off and it won't charged. when i trying to inswert the card in wrong position, the unit already shut off and never turn on again. will it going to turn on if i try to use another memo card? the memo card i used before is not damaged. i just insist to push it even it is not fit. but why the unit shut off and never turn on again ... pls help me...
    Sergeant:
    Champion:
  • 333 Answers
You may have damaged the memory card not the camera. Try the card in a card reader and also a different card in the camera.
Good luck
Posted on Apr 14, 2008
DC shuts off when memory card is inserted
reformat the card. the card is corrupted.
Mar 23, 2014 | Cameras
Memory card will not go in all the way and the door won't shut.
was it working before?
turn the memory card anyway and have a try - before check inside the memory card compartment with a flashlight if you can see the contacts at the bottom and insert the card corresponding to them.
Or try another card to exclude yours is not damaged or wrong type somehow....
Konica Minolta MAXXUM 5D Instruction Manual Inserting And Changing Memory...
Mar 07, 2014 | Konica Minolta Dynax 5D / Maxxum 5D...
How to remove/load sd card stuck in Huawai M860
The SD memory card slot is spring loaded, to insert the memory card insert the card into the SD memory slot with the SD card contacts going in first and gently push it in until it locks in place. NOTE if the SD card does not slide into the slot easily then the SD memory card has been inserted back to front, turn the SD card around and insert it again.
To remove an installed SD memory card, press the SD memory card and it will pop out slightly then you can then pull out the SD memory card.
Mar 12, 2013 | Cameras
I am getting no memory card inserted
Remove your battery
insert your memory card
insert your battery
Power On.
if still no memory card inserted
Replace your memorycard
something wrong with your memory reader (parts of cellphone)
Jan 19, 2013 | Nokia N73 Cellular Phone
Memory card will not push in and stay engaged in memory card slot
This happens most of the time with digital camera and mobile phones, if you try to insert the memory card in a wrong direction. Before inserting your memory card, look into the slot hole and see the position of contact terminals and insert your card in such way that the card comes with contact with the terminals inside the slot. If your card already got struck into the slot, try removing it by pulling out using a small nose plier. Also try with another memory card of similar type to detect any problem due to your memory card. I hope this will help you out.
Aug 04, 2009 | Canon PowerShot A720 IS Digital Camera
Cannot insert the memory card - push in, won't seat, springy feel
Make sure that you insert the SD card in the correct orientation. If not, it will not lock into place. The SD card is push in to insert and push again to eject.
There is a small diagram showing the correct way to insert the card just below the left hand side of the slot.
Doug
Nov 03, 2008 | Canon PowerShot A720 IS Digital Camera
Mustek PVR-H140 shuts down when I insert some SD cards
Yes that's correct newer SD Cards use faster memory chips that are not always compatable, not just with this unit but you can have the same problem with cameras and other MP3 players as well.
The PVR-H140 is quite old now so stick to the older type cards, oh and they dont like being hot swapped, this can cause a shutdown or driver corruption, insert them before turning the unit on.
Jul 26, 2008 | Mustek PVR-H140 Digital Media Player
Insert Smartchip
You have to insert the smart card all the way in on these phones. You can use a pen cap or something to push it all the way in there until it goes all the way in and click and stays there. Then it will not say " insert smart chip" anymore.
Feb 20, 2008 | Sony Ericsson Z525a Cellular Phone
Installing memory card in nextar digital photo frame
I had no problem inserting an SD card. Turn the back of the display towards you, insert the Sd card with the label side also facing you. Push card into slot. The card will only go in about halfway.
Dec 09, 2007 | Microsoft Broadband Networking MN-500...
Canon DC20 DVD Camcorder Logo
63 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
