Overflowing drawer on washer
Water pours out of the powder drawer think the drain in drawer is blocked
Hi i had this problem at the very bottom of the washer inside is a pipe and in their is where it drains through there is somthing blocked could be fluff etc it is a pig to do
Posted on Apr 14, 2008
Hotpoint soap drawer leaking, wfooo
The problem is not a leaking soap container. The problem is that it is overflowing because the line from it to the washer tub is clogged. This happens mostly when using powdered detergents. Check you operating instructions for soap dispenser cleaning procedures.
Jan 03, 2015 | Hotpoint Washing Machines
Lots of water pouring out on to the floor from the laundry soap dispenser in my front loader and doesn't say any error and when i start it pours out
Disconnect first the mains, power plug off the wall. You could have a clog in your soap drawer; pull the dispenser drawer completely out. There is a tab that needs to be depressed to release the drawer to remove. Clean the soap drawer with an old tooth brush. The usual block could be old soap, softener, etc. (you could also be using too much soap powder). I usually use just above 125ml (my measure cup says ml, I use front loader powder for the 5.5kg load) The wash is very gud. This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Next could be one of hoses has become loose, should be re-fixed. Examine by removing top of the front loader; this will give you a gud view of the pipes.If helped, click.
Apr 03, 2013 | Samsung WF328AAW Front Load Washer
Machine overflows from front (powder compartment) on starting; cannot appear to clear flow pipe into machine -tried vinegar solution
Pour a jug of water in the soap tray and make sure it goes away fairly easy indicating the tray or hose to drum is not blocked, if flows okay try reducing water pressure to machine only .....
Feb 16, 2011 | Hoover PE235 Front Load Washer
The washer is leaking water. It looks like it may be coming from the area where you put the dtergent into the detergent cup. I bought it at Bernie's and I think it has an exteneded warranty but I can't...
If you have water coming out of the detergent drawer, then i would suspect a clogged drain hose at the back of the drawer. If you take the lid off , (disconnect from mains ) at back of drawer small hoses take the soap powder to the drum. these can block with soap powder, ( gently push some wire or flex down pipe) dont pierce the pipe , be gentle. had this problem myself.
pete
Nov 17, 2010 | Whirlpool GHW9400 Front Load Washer
Washer doesn't dispense fabric softener
This can be either one of the solenoids in the dispenser has failed, the timer is not sending the signal to let the softener in, or the water is not circulating through the dispenser to flush it through. The water hose to the dispenser will occasionally plug up. Check the hose first, it's the cheapest to unplug it. ;-) Oh, I have seen the wires to the solenoids just simply come unplugged too.
Jan 02, 2010 | Frigidaire ATF6000ES Front Load Washer
Hotpoint WD440 Drawer overflowing
Hi.
I would check the inlet hose from the bottom of the soap dispenser where it goes into the drum for a soap blockage.
undesolved powder can build up here and prevent the water entering the drum
You can access this hose by removing top cover.
the hose is on the left side front.
This should solve your problem.
Please leave feed back.
Thanks.
Nov 25, 2008 | Hotpoint Aquarius WD640 Front Load...
Water gush in power drawer
You have a seal that is not working right for one. and 2 you have a water pump that is not working. because it is not limiting the water supply.
Aug 26, 2008 | Hotpoint Aquarius WD640 Front Load...
Miele Premier Novo Washing Machine: Water coming straight out of the machine
The lower left panel is a filter that should be cleaned out regularly - the filter is also connected to the drain pump which rids the washer of the water. When you clean the filter out - make sure you have a bowl or Tupperware handy that holds about 2 quarts - slowly remove the filter and the water will drain into the bowl. Clean out any debris and reassemble. If the filter is not seating properly in its seat - water will leak from the small hose - the filter is what blocks the water from coming out of the hose.
Apr 05, 2008 | Miele Novotronic Premier 500 Front Load...
Water in Fabric Softener Compartment
As for the softener compartment, powder tends to overflow and block the three drain holes. It needs removing and thoroughly cleaning out, i use cotton buds and lots of hot water.
Dec 18, 2006 | Zanussi FS1455W Front Load Washer
Washing Machines Logo
119 people viewed this question
Top Washing Machines Experts
