No it's not a fuse,when they pop they won't work again,if it's gas it's most likely the gas coils located on top of the gas valve,remove the two phillips screws,remove the cover and change out the coils.also when was the last time you cleaned out the dryer?all a dryer does is move air,if something gets clogged with lint the dryer can't move the air correctly and problems start.clean out the vent line,if it's a long run from the back of dryer to the outside hood i use a leaf blower to blow out the line,then clean out the duct that the lint filter slides into and vac out the inside of dryer where the motor is.let me know what you find and next time send the model number
