Question about D-Link DI-634M Wireless Router (DI634M)
Internet connection hi i have a DI634M router and and cable internet connection, on fresh start of modem and router internet is fine on my laptop which is connected wirelessly but after a few hours internet will be gone on my laptop! but on desktop pc which is connected through the lan internet still works! why is this so? please help! thanks tap
  • Anonymous Dec 03, 2008
    My DI-634M loses the internet connection daily. I have to reset it in order for any of my computers (wireless or hard wired) to work. That previous "answer" was ignorant.
    Novelist:
  • 144 Answers
Hello!
1. what is the model number of your wireless adapter?
2. what is the operating system of your computer?
3. how far is the laptop from the router?
-- try to change channel on the router
-- try enabling wireless security on the router and on the wireless adapter
-- diable other 3rd party firewall on your laptop
Posted on May 06, 2008
WIFI CONNECTION
You may check the firmware on the router by logging into router's web interface (usually it is 192.168.1.1). Check the existing firmware version. Also, verify from dlink website, if any new firmware version exists for your router model. If yes, upgrade the firmware of your router from a hardwired computer. After this step, powercycle the modem, router and your wireless laptop. Check if you are able to connect wirelessly.
Nov 30, 2013 | D-Link DI-634M Wireless Router (DI634M)
Hi, I want to set up my router to my DCM425 modem (from Time Warner). So far I cannot access the internet on my laptop. I get internet fine when the modem is directly plugged into my laptop, and I can also...
1) Make sure the cable is plugged into the Internet port (or whatever the appropriate port is, since you didn't specify exactly which router).
2) At your router's configuration page, make sure DHCP (Automatic) is selected.
3) After connecting to the router, if it still does not work, open up the command window by going to the search box in the Start Menu or click Run... and type "cmd".
4) Type "ipconfig /release". Wait until this is finished.
5) Type "ipconfig /renew". Wait until this is finished.
This should have given you an IP Address.
6) Try to connect to a website.
Jun 04, 2011 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
My internet is working fine. But when im trying to connect my router and the modem it stoops working. Like when I plug my internet cable to the router and then take a cable and put it in my modem its not...
unplug the modem and wait 30 seconds. Modems remember the MAC address of the last device connected to them. If it was connected to your laptop and working fine, then it has stored the MAC address of your laptop and will only communicate with the laptop. You need to connet the router and unplug the modem to clear the memory, then plug it back in so that it stores the MAC address of your router.
Mar 14, 2011 | D-Link DIR-615 Wireless Router
Unable to connect wireless router to cable modem
try this website has wizard to make sure you have set it up right:http://support.dlink.com/emulators/di634m/ if this doesn't fix problem return for replacement
Jul 20, 2010 | D-Link DI-634M Wireless Router (DI634M)
N1 Vision keeps losing internet connection from modem.
Hi Friend,
Please check it by updating the Firmware for your router from the below website
www.belkin.com/support
Regards,
Aysaam
Apr 13, 2010 | Belkin N1 Vision Router
Router -> Modem Connectivity: I am fine if I'm hard-wired to the modem but if I connect wirelessly through the router I can't get WAN. I can get the modem page wirelessly. This just started tonight. I...
Have you check your DNS settings within your Wireless Network Adapter TCP/IP properties settings? Or it may be a proxy server or firewall settings wich may block internet access to the internet. Try testing it with your LAN cable first and see if you are able to connect to the internet using that cable from the laptop/pc to the modem. If it works using the network cable then it might be a DNS related issue on your wireless network adapter tcp/ip properties.
Jul 29, 2009 | Belkin (F5D5231-4) Router
Vista desktop won't connect to internet cable modem eithernet
power down cable modem, router, and computer. Connect ethernet cable from modem to router/ and connect ethernet cable from router to PC. Power up cable modem first, after modem shows connectivity, plug in router. After router shows internet connectivity, start computer. Be sure that you LAN card operable
Apr 15, 2009 | Acer Computers & Internet
Belkin Wireless G wont connect to cable modem
If you switched ISP then you have tor reconfigure your router according to the settings of your new ISP.
Aug 24, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Wireless internet
Hi 4ladyj,
plug your laptop into the router with an ethernet cord, and see if you can connect that way. If you can, go into modem settings via IP (or through the software) and change your wireless settings to default..
If that doesn't work, there is a reset button on the back of the unit, press it in with a paper clip and hold it in for 10 seconds, this will reset the router to the factory default settings.
You will have to change all your settings for your connection again.
Mar 28, 2008 | D-Link DI-634M Wireless Router (DI634M)
Wireless internet connection
I may be able to help with this...but I need a detailed description of how you have things connected between the XP desktop, the cable, modem, the Linksys router, and the laptop. Also, is the Linksys router new?
Typically, the wan port on the wireless router connects directly to the cable modem with a cat5 network cable....then the desktop pc connects to the router...on port 1 for example...with a similar cable. Once the wireless router is set up properly, the laptop should then be able to connect using wireless.
Feb 01, 2008 | Computers & Internet
D-Link DI-634M Wireless Router (DI634M) Logo
102 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
