Question about NEC PlasmaSync 42MP2 42 in. Television
Twp 4210 tv ok set box faulty
Red light on box is not on cant switch on tv can you help
  • 103 Answers
Please check the main power switch located on back of set or on bottom edge
Posted on Jun 09, 2008
I have an audiosonic 1201 54cm tv dvd combo. I cant receive any channels, do I need to purchase a set top box?
Connect the TV to external areal, and do a re-tune to it, and see whether it captures all the programmes on air; so that you can make sure that your TV is OK. If not the tuner to your TV is faulty.
If it capture all the on-air channels, and not with your set-top box, the fault is with the set-top box.
Nov 06, 2014 | Televison & Video
Techwood twp 4210 media box
DEAD AV BOX NO POWER LIGHT
UNPLUG FROM THE MAINS
UNSCREW THE TOP CASE
UNPLUG THE 2 SOCKETS REF PICTURE ( TECHWOOD AV BOX RESET AND UNPLUG )
LEAVE THEM UNPLUGED AND “PLEASE BE CAREFUL AT THIS POINT” SWITCH THE MAINS BACK ON AND SWITCH THE POWER ON THE AV BOX, IF YOU GET A RED LIGHT SWITCH THE SET OFF.(PLEASE NOTE THE RED LIGHT MAY NO ALWAYS COME ON, SO DONT BE ALARMED).
PLUG BOTH THE LEADS BACK IN AND SCREW TOP CASE BACK.
CONNECT ALL BACK UP AND YOU SHOULD BE WORKING NOW
JOB DONE HARD RESET.
Let me know if you need any further help
thank you for using fixya and good luck
Apr 15, 2008 | Televison & Video
Hi, I have a Sansui SV-4210 LCD HDMI TV . It does not switch on with the remote and only works once I unplugged the power cable and plug it back again. Lately it occurs every time and I have to do th
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Sep 20, 2014 | Sansui Televison & Video
What's wrong?My red light is out and tv won't turn on. What's wrong?
Is your TV plugged into the Mains. Is the Mains fuse on the set ok. Your on/of switch could be faulty, or the Mains wire inside the TV is adrift and a Hell opf a lot of other situations could be your problem
Jul 30, 2014 | Proscan Televison & Video
KDF-60XBR950 Red light blinks 5 times
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 01, 2017 | Sony Grand WEGA KF50WE610 50" Rear...
Techwood plasma twp 4210 broke
First make sure to hit the menu button on the TV's remote and if nothing is there then friend while the set is on turn a bright flashlight on and shine at angle into the set push the TV menu button if you can see a image then your back light is not working.
You can also check the transformers they are close to were the wires plug into the panel, make sure all transformers read the same amount of resistance if not you have found a bad one. Now you will have to check to see if the power supply is sending 24v to the backlight, if not the power supply is bad. Cost backlights around 150.00 and power supplies around 100.00. Well this should help you friend.
Dec 07, 2009 | Televison & Video
HDTV-AT&T UVERSE
First of all, is your blue "HD" light lit up on the front of your Uverse box?
If yes, then you're in HD
If No, you need to check your connections from Box to TV
1.Those Red-Blue-Green cables are for video only, they don't carry sound and shouldn't be connected to audio outs. Audio needs a seperate cable. Make sure your Red isn't on the audio out which is also red. Make sure your blue and green aren't switched with each other either. Check that at both ends.
2. Try an HDMI cable. It will carry audio and video together and it's one cord instead of 5.
3. What brand/model of TV is it? Is it an older projection TV? The HD tuner might be shot. The individual color tubes commonly fail after a few years.
4. Are you selecting 720p or 1080i from your TV's menu or from the Uverse menu? You'll need to set it through the Uverse box, not the TV.
5.Follow -Menu -Settings -Aspect Ratio to change to 720 or 1080. This should start an autotest which will scramble your picture for about 5 seconds, then bring you back to a menu asking you to keep settings or revert back settings. If you never see that question pop up, then your TV isn't supporting the HD, and you settings will be rolled back automatically. If the question does pop up and you can read it, select "keep settings" and press OK. Your blue HD light should come on the front of the box now.
Mar 01, 2008 | Philips 55PW9363 55" Rear Projection...
Samsung LE R88 BD LCD TV / digibox problem
Hi.
Its a long shot but try this,
It can cause problems when you switch set to & from stand bye.
Check that you are viewing a digital TV channel
Enter the menu and navigate to:
Setup > System > Software Upgrade > Standby Mode upgrade
Change the setting to Off.
I cant gteee that this will sort your problem out so post here if it doesnt & I will check samsung data base.
http://dysonmanuals.llc.nu/
Chris..
Jan 08, 2008 | Televison & Video
NEC PlasmaSync 42MP2 42 in. Television Logo
94 people viewed this question
Top NEC Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a NEC Televison and Video Expert? Answer questions, earn points and help others
