IP3300 turns out a quality check pattern- lines and bars are all intact- but except for black colours are feint. Have tried regular clean several times and deep clean to no avail.
  • 655 Answers
Did you change the black cartridge, there might be problem in that cartridge.
Posted on Apr 14, 2008
Why does my canon mg5250 not copy black and white
Go to the setup, then maintenance menu on the printer and select "print nozzle check pattern"
You should see a complete black ladder pattern (for the fat black cartridge) and a set of coloured bars for each colour cartridge (including the thin black cartridge). If the black ladder pattern is missing then this indicates the black printhead is blocked or cartridge is empty. If you are SURE the cartridge is not dry, then:
select clean to clean the print head for the black only. You may have to do this several times. If the check pattern does not improve, you may have to remove the printhead and clean it manually. Instructions to do this I will give separately if needed.
Mar 04, 2015 | Canon MG5250 Printer
Why is my dcp135c printing images in brown instead of black
Several probable causes of this.
  1. Your Black is empty and the printer is trying to approximate the Black using the other colours. Check and replace Black.
  2. Your Black printhead is blocked and all you are seeing is the other colours that are used to make the black into a full black. Check cartridge and do a printhead clean to see if this clears it. Also print off a print quality test sheet (In the Ink Management options on the printer)
  3. Another colour has been put into the Black Slot on your printer. Replace the incorrect cartridge and hope that the printhead has not been damaged by using the wrong cartridge. May need several printhead cleans to clear incorrect ink from the feed lines.
Hope this helps.
Oct 07, 2014 | Brother DCP-135C Flatbed Digital MFC...
Why is my Canon Pixma 4820 suddenly leaving lighter lines through color pictures.
Worn print head. And for what they charge for a stinking print head you can get a new printer for less with a warranty to boot!
Mar 24, 2017 | Office Equipment & Supplies
When you change the ink cartraige and clean printer and test the colours the quality of colour is not good on the test! what do you segested i try beacaue the machine has been on its 100th clean and...
    1. Print a Print Quality Check Sheet.
    2. Press the Ink or Ink Management key on the control panel.
    3. Press the up or down arrow key to choose Test Print and press OK.
    4. Press the up or down arrow key to choose Print Quality and press OK.
    5. Press Color (Colour) start. The machine begins printing the Print Quality Check Sheet.
    1. Closely examine the Print Quality Check Sheet. Each of the four colors is represented by a slanted square pattern made up of individual blocks. The colors should appear in the following order from left to right: Black - Yellow - Cyan - Magenta.
    2. Compare the print quality of the Check Sheet you just printed with the three examples listed below:
      (A) One or more complete blocks of colors are missing:
      (B) Most of the short diagonal lines are missing from one or more color blocks:
      (C)Some parts of the short diagonal lines are missing from one or more color blocks:
    3. The display will then ask you if the print quality is OK for black. Press the down arrow key or 2 or "-" to choose No for black with the problem.
    4. The display will then ask you if the print quality is OK for Color. Press the down arrow key or 2 or "-" to choose No for color with the problem.
    5. The display will then show Start Cleaning? Yes No.
      Press the up arrow key or 1 or "+" to choose Yes and the machine will start cleaning the color ink cartridges.
    6. When the machine completes cleaning the print head, press Color(Colour) Start. Another Print Quality Check Sheet will print.
    7. Repeat the cleaning and the quality check process following the Step 4-7.
    Jun 02, 2011 | Brother MFC 6490CW InkJet Printer
    I have a Canon Pixma MP270 and I can only print in colour both the black and colour lights are lit up on the printer
    f print quality does not improve by the standard cleaning of the Print Head, clean the Print Head deeply. Cleaning the Print Head deeply consumes more ink than the standard cleaning of the Print Head, so clean the Print Head deeply only when necessary.
    1. Make sure that the power is turned on.
    2. Clean the Print Head deeply. (1) Press the g0022565.png (Maintenance) button repeatedly until y appears. g0054776.png
    (2) Press the Black or Color button.
    The machine starts cleaning the Print Head deeply. Do not perform any other operations until the machine completes the deep cleaning of the Print Head. This takes about 2 minutes.
    3. Check the print head condition.
    When the deep cleaning is completed, the LED returns to the copy standby mode. To check the print head condition, print the nozzle check pattern.
    See " Printing the Nozzle Check Pattern".
    If the problem is not resolved, turn off the power and clean the Print Head deeply again after 24 hours.
    If the problem is still not resolved, replace the FINE Cartridge with a new one.
    See " Replacing FINE Cartridges".
    If the problem is still not resolved after replacing the FINE Cartridge, contact the service center.
    Print the nozzle check pattern to determine whether the ink ejects properly from the print head nozzles.
    NOTE If the remaining ink level is low, the nozzle check pattern will not be printed correctly. Replace the FINE Cartridge whose ink is low.
    You need to prepare: a sheet of A4 or Letter-sized plain paper
    2. Load a sheet of A4 or Letter-sized plain paper in the Rear Tray.
    3. Open the Paper Output Tray gently, and open the Output Tray Extension.
    4. Print the nozzle check pattern.
    (1) Press the g0020617.png (Maintenance) button repeatedly until A appears. g0054754.png
    The nozzle check pattern will be printed.
    5. Examine the nozzle check pattern.
    See Examining the Nozzle Check Pattern.
    Examine the nozzle check pattern, and clean the Print Head if necessary.
    1. Check if there are missing lines in the pattern (1) or horizontal white streaks in the pattern (2). g0054755.png (1) Check if lines are missing in this pattern. If yes, the cleaning is required.
    See " Cleaning the Print Head".
    (A) Good
    (B) Bad (lines are missing)
    (2) Check if horizontal white streaks are present in this pattern. If yes, the cleaning is required.
    (A) Good
    (B) Bad (horizontal white streaks are present)
    Post back!
    Oct 26, 2010 | Canon Office Equipment & Supplies
    Quality of colour
    hi! there, well in connection to your poor printed color there posibility that ink was insufficient to distribute to you photo to print try to visit your ink status, black color is sepated to 3 color catridge.if there's a insufficient ink in catridge,replace or refill any thing as long there is much ink in your catridge,if ok and print still not good,try to clean your printer headdont use any thing to clean your printer herad,the printer will clean your printer head,on maitenance menu,click clean,try several time,also try to align your printer head,click aligned,t check the pattern of your printer,click pattern test.if ok try toprint if the color print is balance,try to print.check the preview before you print adjust the quality color as in yout tate before printing.regards and have a nice day.
    Apr 02, 2009 | Canon PIXMA MP600 all-In-One InkJet...
    Hi, I have an Epson Stylus 4000 printer at home. I had no problem printing high quality prints untill now. I thought that my nozzles were clogged (I haven't use it to print for a several months), so I...
    print head clogged..if you remove it try cleaning it...or sink it in a boiled water to released clogged.....used tissue on cleaning...maybe its effective coz i repaired same printer you have...
    Aug 27, 2008 | Office Equipment & Supplies
    66 people viewed this question
    k24674
    jasbo
    jasbo
