Cd player multi play problem
My AIWA NSX-V70 has a 3 disc cd player. Typically only one of the cd,s is recognised, sometimes none at all. Is there a solution?
  • 1 more comment
  • dav1892 Apr 19, 2008
    I took off the cover for the first time but was unsure which was the laser lens. How can it be identified.
    dav 1892
  • dav1892 Apr 21, 2008
    Being new to this site I did not fully appreciate the sensitivities of the rating system, I apologise for this. It would be helpful to me if you could enlarge on your first answer.
    dav 1892
  • bahjwh Sep 23, 2008
    how to you clean the laser lens on the NSX-V70- I have never done so before
    Brenda
  • 1,512 Answers
Hi dav1892
These units are notorious for getting a layer of dust on the CD optics laser focal lens. You need to give it a clean with a cotton bud moistened with Windex, and then a dry wipe to be sure that there is no smearing left. See how that goes, and get back to me here if it does not fix it.
regards
Graeme
Posted on Apr 14, 2008
  • Graeme Ross
    Graeme Ross Apr 19, 2008
    hhmmm, A thanks for trying rating brings by overall rating down by 10 points... now if you had given me a fixya,or even a helpful, i may then have made the time to follow up with you, change the rating and perhaps I will :)
    regards
    Graeme
  • Graeme Ross
    Graeme Ross May 04, 2008
    would have been happy to for a rating appropriate to advice given ... good luck with your problem mate:l
Aiwa NSX-A888 Stereo System CD Player
Cleaner disks are a waste. You're better off cleaning the lens with a cotton swab and rubbing alcohol
Apr 14, 2013 | Aiwa NSX-A888 CD Shelf System
It is possible to connect a "AIWA NSX V70" as a
Use VIDEO/AUX instead. MIC is for the smaller input signal that a microphone would typically produce.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Aiwa-NSX-V70-manual/id/1076ci461/t/2/
Use your PC soundcard controls to adjust the output to something useable (max?).
Apr 30, 2011 | Aiwa NSX-AJ300 CD Shelf System
Good morning, I need your help for my Aiwa NSX-SZ50 digital audio system .... It went in demo mode, what can I do to start again ???? It is possible to have another manual ??? Many thanks for your...
you can order new owners manuals online in many places. Search for Aiwa NSX-SZ50 owners manual.
I would try unplugging it, and then play a cd... it should snap out of it. if not, look through any menus you can access.
Aug 19, 2009 | Aiwa Audio Players & Recorders
CD is skipping
Probably need to clean the lens inside the player. If you have compressed air you can GENTLY spray inside the tray to remove dust, otherwise go to Walmart and buy a CD cleaning kit to clean your lens. If it still skips then you might have a bad disc or player
Hope this helps
TankMurdock
Apr 27, 2009 | Aiwa NSX-D30 CD Shelf System
AIWA NSX-A555 Disc player/changer won't work.
dirty/dusty lens, try a lens cleaning disc... or remove the casing and gently clean the lens with a cotton bud and some alcohol (surgical spirit, window cleaner, Whiskey or Vodka also worked for me).
i hope this helps, please don't forget to vote on your answers to help keep the site free.
Sep 04, 2017 | Aiwa NSX-DS55 CD Shelf System
Aiwa nsx k570
i need the circuit diagram for the CD player in NSX K 570 Aiwa 3 CD changer music system . I am Located in mumbai colaba. 9819890987
Mar 18, 2008 | Audio Players & Recorders
I have an aiwa nsx 5200 mini system the cd player broke
Soooooooo many people have complained about this system not reading discs properly, yet the solution is incredibly simple. All you need to do is calibrate the lens, and you can do this without even opening the stereo! Here's how:
With the stereo all unplugged, turn it around so the back is facing you.
Now use a flashlight and, looking through the grating on the back, approximate where you think the cd lens mechanism would be. You should see 2 8-pin connector wires side by side (one red and one white) and to their right a small black circle screw type thing.
Using a screw driver, turn the screw thing about 1/10 of a revolution clockwise.
Plug in, and test with a clean cd. If nothing happened, repeat the procedure turning the screw thing in tiny increments (don't over do it.) Eventually, the cd player should recognise the cd. Keep fine tuning and testing until you've found the "sweet spot" where it recognizes and plays cds optimally.
Overall, you should NOT have to turn any more than a full revolution, and even half a revolution is pushing it. What you are really doing by turning this screw is fine tuning the "data reading point" of the laser. Too close and it will focus on the area between the cd and the lens, causing failure to recognize the disc. Too far and it will focus past the data perhaps recognizing the disc but not being able to read it. I believe the major problem with these players is that as they settle in, the area between the lens and cd changes. This would cause a gradual degrading in performance until the player finally failed to recognise any data at all (which is exactly how mine went personally.) There isnt a problem with the quality of the lens itself, therefore it is very fixable!
I have heard that all 3cd Aiwa Mini-systems share this problem so, as long as the calibration tuning screw is exposed through the grating on the back, this fix should work for any of the Aiwa mini-systems with this particular problem. If the screw isnt exposed, it is still possible to get at by opening and dismantling the player. (Unfortunately, i did not originally notice that the screw was accesible through the grating, so i went about pulling the entire system apart and wasting hours of my life. You can thank me later for saving you this tedious trouble as you're listening to cds on your newly fixed player ;-) )
If this doesn't work, or doesn't fix the problem completely, try cleaning the lens. You can do this by either by using a cd lens cleaner (looks like a cd with a brush built into it) or opening up the stereo and using a soft cloth on the lens. You may also want to try putting the screw back to its starting point and using the same procedure but turning the screw counter-clockwise. (I personally had to turn clockwise but who knows, maybe your player settled in differently.)
As for the mechanism itself, i have no idea. I did notice, however, that the lifting mechanism sometimes picks the cd up off-centered causing failure to play. You can semi-fix this by holding the stereo at an angle while it picks up the cd or placing it off-centered in the tray. Its annoying, but it works :)
Feb 19, 2008 | Audio Players & Recorders
CD-R Playback Issue
check the laser eye of your player clean or replace.
Aug 28, 2007 | Aiwa NSX-A115 Shelf System
119 people viewed this question
 Grubhead
Grubhead
