Question about Emerson EWL20S5 20 in. EDTV-Ready LCD Television
Parts for EWL20S5
Need a power cord for my EWL20S5. Where can I buy one?
    Novelist:
    Champion:
  • 254 Answers
By chance does it use the same type of cord as a computer or monitor? These cords can be found at local Radio Shacks, or if you live near a business which has a number of computers, and upgrades machines regularly, they might have extra cords lying around in their closet.
Otherwise, take a pic of the connection on the TV, take it to Radio Shack, and make a match there.
You could look in the TV's documentation- maybe get help there too.
Posted on Apr 14, 2008
I have an Emerson 20" LCD EWL20S5. I am trying to
Contact the authorized dealer for Emerson.
Jul 19, 2013 | Televison & Video
We have lost our manual for this TV. Is it possible to print one from online or to have one mailed to us?
Emerson TVs are built by Funai. You can get the manual from the Funai site, http://www.funai-corp.com/support/manuals.aspx . Search for your TV model to find the manual as a PDF and then print the file.
The direct link to the manual for the EWL20S5 is http://www.funai-corp.com/6pdf/om/EWL20S5.pdf . For the best results when you want to print the file, save it to your computer and then open it in Adobe Reader (instead of using the plugin). You may need to change the scale at which the document is printing. Use the Print Preview feature to guide your printing choice.
I hope this helps.
Aug 09, 2011 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
TV was unplugged for a little while and now won't power up and is making a buzzing sound. What can cause this?
How old is the tv? This is a power supply symptom. You will need to take the back of the tv off and check for puffed capacitors on the power pcb. This is the board where the power cord plugs into. Lay tv face down on a cushioned surface large enough to support the tv frame. You do not want to damage the panel. Then remove the back. If there are puffed capacitors, replace them with equal or slightly higher valued capacitors. The value rating for capacitors are mf and voltage, printed on the capacitors. If they look good, you will need to check the dc voltage output from the pcb usually about three connectors in the same area. One way or another, it is a power supply problem, usually corrected by replacing caps, but if that doesn't work, you will need to replace power pcb
Apr 03, 2011 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
Is emerson ewl20s5 tv digital or do I need a converter box?
The set can recieve analogue transmissions or cable signal only, for digital transmission a converter box would be needed
Mar 05, 2011 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
Tv automatically shuts off after being on for a few seconds EWL20S5
The most common problem for this set that will cause shutdown after a few seconds is the inverter board. Looking at the set from the back, it is the long slim board that is normally located on the far left side of most lcd tv's. There are 3 electrolytic capacitors located on this board, and changing them will fix a lot of these sets for this problem. The location numbers of the caps are c330, c350, and c370. If you have any experience working on electronics, I would start by changing these caps. They are very inexpensive. If you would rather just change the inverter board, try shopjimmy.com. That is a good place to buy boards for flat screen tvs.
Jul 29, 2010 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
I don't have any power to the t.v. even though it's pluged in to the outlet. It's a emerson model EWL20S5B?
Small TVs like this almost always are made up of two boards inside - a power board and a main TV board.
And almost always there's a fuse on the power board, near where the power cord goes in.
Checking that fuse is the only thing you can do by yourself.
Your next option is to give the TV in for repair to someone who fixes such things. Chances are high the problem is in the power supply board and is repairable.
However, the cost for doing so can be prohibitedly high as cost of the TV itself is prohibitedly low. I mean you may be better off selling it on eBay for $50 and buying a new one.
I know I'd buy it for $50 there.
Nov 17, 2009 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
TV will not stay powered up. The light comes on for a second, then powers off again.
you have a bad transfomer on your inverter board you need a tech to find which one or just replace the board
Sep 24, 2009 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
Back panel black circular control button
that connection is the "S - VIDEO" connection which will over ride the yellow video input if used
this can be seen here http://www.emersonaudiovideo.com/pdf/om/EWL20S5.pdf
page 2 of 8 , and zoom in
Mar 27, 2009 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
Ewl20s5 Will not power on
Google bad or blown capacitors image and you will see what you need to look for on the boards primary bad caps are on the power board where the power comes into the computer. inverter board can also be issue but rare.
May 15, 2008 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
Emerson EWL20S5 20 in. EDTV-Ready LCD Television Logo
67 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
