I have Electronic Brother type writer, i want to decrease the space of each letters because sometimes it wont fit to the papers because of wide space
    Problem Solver:
  • 5 Answers
Have u tried decreasing the font type or margin
Posted on Apr 14, 2008
Printing too small
Go to file print preview and at the top of the screen that pops up there is a place where you can bring up a drop down list which lets you choose shrink to fit as well as a wide variety of percentage increase or decrease if this doesn't help go to file>Print>anthen click on preferences on the screen that comes up check your printers settings don't forget to look at what size paper the printer thinks you are using and see if your printer has settings for how many pages to fit the document to.
Still having Problem Then follow Us For
Brother Printer Support
Feb 24, 2014 | Brother DCP 115C All-In-One InkJet Printer
How do i get my Brother A X 250 Eletric Type writer to type the correct letters ?
"If your unit is not printing properly:
1.Ensure the ribbon cartridge has not run out of ribbon. If your ribbon appears silver or gray, install a new cartridge.
2.Ensure the black lever in the center of the carriage is pressed to therear towards the paper. If not, press it to the rear to lock the Daisy Wheel into place.
3.Reset the unit by holding down the [CODE] Key and pressing the [SHIFT]Key and the [WORD OUT] Key.
4.Release all three keys.
5.Try typing.
If the problem continues, your unit will need servicing. You can locate a Brother Authorized Service Center in your area:
http://www.brother-usa.com
Feb 27, 2013 | Brother SX-4000 Typewriter
Correction bar not working. When I type in a word and hit correct, instead of lifting the lettter off the paper it types the letter I typed in bold. Is there a button I can push to correct this from...
The correction tape may be installed wrong, or it may be a tacky L/o that will stick nand not raise up..
You can find a manual at BROTHER.COM, click on support.
DickyO
Sep 02, 2010 | Brother EM-530 Typewriter
I OPERATE A BROTHER GX6750 TYPEWRITER. i NEED TO CLOSELY COMPACT MY NUMBERS TO FIT A TYPE SPACE. HOW DO I ACHIEVE CLOSE TYPING? THANKS
There is either a slide switch labeled 10, 12 & 15 or a botton you press that changes indicator lamps to those numbers. Go to 15
(15 letters per inch} tou may also want to get a 15 pitch printwheel.
DickyO
Jul 30, 2010 | Brother GX-6750 Typewriter
Hi
Many brother type writers have two cam assemblies under ribbon holder. One operates the print hammer and the other operates the correction ribbon lift. sometimes they gets stuck or lock themselves up. turning on and off a few times will take care of it, but sometimes it needs to be worked on by a tech. If you look when you type a character, most likely the print hammer is not firing or it is striking the correction ribbon instead of the black ribbon.
Let us know if you want to know something more else please accept the suggestion.
Thanks for contacting Fixya.com
Apr 08, 2010 | Brother EM-530 Typewriter
How do i get bold letters on my computer,i do not want to purchase program
Without having the operator manual what I recall on these types of type writers, they have a key next to the space bar called "Features Key."
Most keys are color labeled.
Select the bold feature, it's color origin,
1. Press and hold that features key
2. Touch the bold key, now you are in bold typing mode.
3. When you finish bold typing, press the features key and hold, then touch the bold to turn it off.
Oct 16, 2009 | Brother ML-100 Typewriter
Whenever i try to type the type writer types the wrong letters.
The silver guide is touching the fontwheel and keeping it from resetting properly. You need to adjust the guide away from the fontwheel by loosening one screw on each side of the guide and set for 2 pieces of paper on the platen.
Jul 17, 2009 | Brother SX-4000 Typewriter
BROTHER ELECTRONIC AX-22 RANDOM LETTERS
Check to see if there is a switch on the left side of keyboard for international or symbol printwheel selection.
Jun 17, 2009 | Office Equipment & Supplies
Problem: Typewriter isn't typing any letters on the paper.
Is the platon properly seated? Sometimes the platon (the rubber tube thing that you crank the paper around) has been removed and then not returned all the way down into its cradle. Try pushing both sides down with equal pressure and see if it drops down and tightens. Good luck!
Apr 03, 2007 | Brother ML-100 Typewriter
35 people viewed this question
jasbo
jasbo
